Old 09-10-2010, 02:56 PM   #26
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Awesome sticky since just doing my inner and outer tierods my alignment is so off.
SubaruImpreza_power is offline   Reply With Quote
Old 01-25-2011, 03:00 PM   #27
lupohki
Member#: 3457
2008 STi
Anyone know of a good way to measure caster?
lupohki is offline   Reply With Quote
Old 01-25-2011, 05:02 PM   #28
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
With a macstrut suspension, the angle of the strut relative to vertical is the caster angle. Put a magnetic digital level on the side of your strut tube. It'll likely measure around 84* on your car (meaning 90-84 = 6* of caster).
09rexwagon is offline   Reply With Quote
Old 03-22-2011, 01:45 AM   #29
creator1322
Member#: 275530
2006 OBXT
Thanks! Helped alot.
creator1322 is offline   Reply With Quote
Old 08-25-2011, 03:23 AM   #30
gc6sti
Member#: 292465
awesome write up, will use this in the future!
gc6sti is offline   Reply With Quote
Old 11-06-2011, 10:08 PM   #31
Squaddron
Member#: 300219
Default Alignment, camber issues
My car has a 4 inch lift by SJR and the rear wheels now have too much camber,,,is there any way to adjust camber on the rear with a lift kit on it? also the car pulls to the right, and I am wondering more about the diy approach to that one...Thanks~
Squaddron is offline   Reply With Quote
Old 12-14-2011, 01:39 PM   #32
80807STI
Member#: 183266
2004 Impreza WRX STI
Default advice on alignment issues
Aloha Guys! I recently bought a 2004 sti with a recon title and have been fixing it up. I took it in for alignment and found that the rear driver side was off, causing a slight occasional pull to the left. THe tech couldn't adjust the rear because of the stock tophats. Should I buy coil overs that are adjustable or just rear camber plates? Thanks for your help!
80807STI is offline   Reply With Quote
Old 12-14-2011, 07:15 PM   #33
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
Try camber bolts? Assuming you're a gd chassis.
(And no, I can't see your veh info ... I'm using teh nasioc android app)
What was off? The camber? Toe?
I reccommend coilovers (stance, bc, etc) that come w/ rear camber plates, it makes adjusting them easy as hell compared to camber bolts (which requires taking the wheels on/off)
Evilchargerfan is offline   Reply With Quote
Old 05-17-2012, 07:48 PM   #34
j.ditommaso
Member#: 298740
thanks for the info
j.ditommaso is offline   Reply With Quote
Old 12-20-2012, 02:58 AM   #35
angelaperkinson
Member#: 341120
good one
angelaperkinson is offline   Reply With Quote
Old 02-10-2013, 01:25 PM   #36
sonic_wrx189
Member#: 207905
2003 subaru wrx
sonic yellow
Does anybody happen to know the length of an OEM 2003 wrx sedan trailing arm? My searching only finds wagon posts.
sonic_wrx189 is offline   Reply With Quote
Old 07-07-2013, 09:34 AM   #37
bonestockwgn07
Member#: 349844
awesome
bonestockwgn07 is offline   Reply With Quote
Old 09-18-2013, 07:23 PM   #38
notectasi1
Member#: 366277
thats right, the shop i went too did my camber wrong had to adjust it myself
notectasi1 is offline   Reply With Quote
Old 04-12-2014, 04:25 AM   #39
jy_jelly
Member#: 387523
thank you, going to give it a try. my cousin pays about $75 every couple of months to get
an alignment because of all his mods. maybe i'll charge him $50
jy_jelly is offline   Reply With Quote
Old 06-10-2014, 12:10 PM   #40
Roxy WRX
Member#: 391641
2007 WRX Limited TR
would not having the front end properly aligned cause the steering wheel to shutter while braking? It will not shutter at lower speeds but at 78 and above it shutters...
I just put on new 4 Calipers, pads, and rotors... sooo
07 WRX TR Limited.
Roxy WRX is offline   Reply With Quote
Old 08-22-2014, 09:35 PM   #41
M0d3STi
Member#: 399544
I adjusted the front camber on my mom's 2010 Impreza OBS, the tires were wearing significantly on the inner edges so turned the camber bolts out a few marks. Will keep an eye on and adjust as necessary. The tires are shot so it's pretty much a stop gap measure until new tires and alignment.
M0d3STi is offline   Reply With Quote
Old 01-30-2015, 03:33 AM   #42
Dub arr exx
Member#: 412218
95 Wrx ra non sti
Wil this work on my 95?
Dub arr exx is offline   Reply With Quote
Old 02-05-2015, 07:54 PM   #43
bluesguyej25
Member#: 296643
2008 Impreza 2.5i
SS
Originally Posted by chimchimm5 View Post
How do you guys reach the toe adjusters with the car on the ground and no lift available?
old cookie sheets!!!!!
bluesguyej25 is offline   Reply With Quote
Old 02-05-2015, 08:16 PM   #44
bluesguyej25
Member#: 296643
2008 Impreza 2.5i
SS
07 WRX TR Limited.
Have you check the balls joints, the control arm bushings? Usually when you get juttering/shaking while braking it is a warped rotor. but if you have just changed them and they are still shaking while braking...i would check for something loose on your front end. Good Luck bro
Old 02-17-2015, 06:18 PM   #45
Muddy Creek
Member#: 413767
Just had my bushings replaced and had shop align it. May try this next time.
Muddy Creek is offline   Reply With Quote
Old 03-22-2015, 05:58 PM   #46
AlaskaGriz
Member#: 400413
2013 WRX
Cobalt Blue
Nice write up. I will use this in the future! I live on a paved road that has lots of frost heaves. I need to stiffen the suspension up some as the car bottoms out too easy.
AlaskaGriz is offline   Reply With Quote
Old 08-25-2016, 06:58 PM   #47
b3nelson
Member#: 453335
I just had a short block replacement on my 11 Fozzy just got it back yesterday and I noticed that it's pulling pretty hard to the right after the swap. Do they usually mess with suspension or steering to pull an engine?
Just want to know before I go blame the dealership for screwing up the alignment.
b3nelson is offline   Reply With Quote
Old 11-13-2016, 10:31 PM   #48
highfidelitie
Member#: 386319
super helpful. Thank you!
highfidelitie is offline   Reply With Quote
HAHA! OT sez, "Do your own homework, loser!" Strider Off-Topic 3 11-13-2007 05:31 PM
The ultimate tax shelter: Owning your own business fuzzycuffs Off-Topic 78 02-19-2007 10:59 AM
You think "Do your chain hang low" is bad...get a load of this: BigWrecKs Off-Topic 28 09-11-2006 06:36 PM
own your own repair shop credit xtc Tri-State Area Forum 16 02-13-2002 09:54 PM
('93-'01) Do not have your own brain? Get one for your battery then. 25psi Impreza Forum 3 04-16-2001 11:38 AM
