Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 09-17-2013, 06:49 PM   #51
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by CLL_OBP View Post
Wow, they are really putting you through the wringer. If all the old tires wore unevenly , I don't see why it's such a hassle to put your car up on the rack and check it.
I have no idea. They also said to put the car on the rack it would be 69.99. If there is something even 0.2 different between the 2 sides I am going to make them adjust it. Especially since I'm paying for it. Hopefully it is further out, so it will be easier to have covered. I took a pic of 1 of the tires, but not all of them.
Also going to find exact warranty verbiage tonight to see what it says. My take is if it is out of spec in under 36k, it should be covered......
Edit:I can't find anything in the warranty that says it covers it, maybe it is in the actual book in the car?
flyboy1100 is online now   Reply With Quote
Old 09-18-2013, 08:50 AM   #52
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
If possible. There is one adjustment in particular (rear camber, I believe, but I might be remembering incorrectly) that isn't adjustable.
Old 09-18-2013, 09:01 AM   #53
79letour
Member#: 302570
2013 XV
DGM!
Rear cannot be adjusted.
Old 09-18-2013, 11:30 AM   #54
CLL_OBP
Member#: 310435
2012 Sport Limited
PUP 5W20 93,516 miles
See under "What is Covered", third bullet.
https://www.subaru.com/my-subaru/warranties-2012.html
CLL_OBP is offline   Reply With Quote
Old 09-18-2013, 01:53 PM   #55
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Adjustment services, I will point that out tomorrow
Old 09-18-2013, 05:53 PM   #56
CLL_OBP
Member#: 310435
2012 Sport Limited
Yup and that's exactly what an alignment is, an adjustment. Tell'em they're supposed to bill Subaru and not you. They can call and find out for themselves, which I'm sure what will happen.
Old 09-18-2013, 06:39 PM   #57
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
catch all however?
What is Not Covered:
Maintenance and Adjustment Services; Normal Deterioration
These warranties do not cover the cost of parts or labor involved in performing any normal maintenance services. There is also no coverage for normal deterioration or fading of paint, soft trim, cosmetic and appearance items.
Old 09-18-2013, 07:10 PM   #58
CLL_OBP
Member#: 310435
2012 Sport Limited
catch all however?
I take that to mean it's not covered after the "one time only". That's what Martina @ SOA told me. Jetes got his done, jr0bb5 and myself got refunds, so the best thing to do is have them call.
Old 09-18-2013, 07:12 PM   #59
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
will do
Old 09-19-2013, 11:28 AM   #60
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
At dealer now, they said they should be able to bill it to warranty. No fight on my part, will report when done
Old 09-19-2013, 12:12 PM   #61
CLL_OBP
Member#: 310435
2012 Sport Limited
Good to hear :thumbs up:
Old 09-19-2013, 01:37 PM   #62
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
billed to warranty
steering is much more neutral now, ie i can turn the wheel and it won't start to turn back by itself.
Old 09-19-2013, 01:59 PM   #63
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
But isn't the steering wheel supposed to be self-centering by design?
Old 09-19-2013, 03:13 PM   #64
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Yeah I don't know what his problem is. You could kill someone if they're not ready for your car to continue a sharp turn when they release your steering wheel.
goregasm is offline   Reply With Quote
Old 09-19-2013, 03:19 PM   #65
79letour
Member#: 302570
2013 XV
DGM!
Yes it is, unless you're driving a forklift!
Old 09-19-2013, 03:51 PM   #66
CLL_OBP
Member#: 310435
2012 Sport Limited
billed to warranty
Wow! You definitely needed that.
Old 09-19-2013, 06:26 PM   #67
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It will recenter if you turn more then just a slight turn. I.e. most won't notice it, but I was being critical of the alignment
Old 09-19-2013, 06:29 PM   #68
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yup, weird thing is all 4 tires were worn the same, I had performed 4 rotations. So it must of been that way on delivery
Old 11-21-2013, 09:21 PM   #69
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
billed to warranty steering is much more neutral now, ie i can turn the wheel and it won't start to turn back by itself.
Nothing in this printout shows an alignment that's out bad enough to cause dangerous steering situations like was described.
Old 11-21-2013, 10:10 PM   #70
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
only with very slight movements, anything "normal" the wheel will self correct as it is supposed too
Old 03-02-2014, 08:07 PM   #71
ausubimpreza
Member#: 245054
2013 Impreza 2.5
Charcoal
Put new tires on my impreza sport 2013 and had it aligned. They said they couldn't align the rear left tire. Is this a problem I should go to Subaru about?
I don't know if this might help.
ausubimpreza is offline   Reply With Quote
Old 03-02-2014, 10:33 PM   #72
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by ausubimpreza View Post
Put new tires on my impreza sport 2013 and had it aligned. They said they couldn't align the rear left tire. Is this a problem I should go to Subaru about? I don't know if this might help.
Nope! Camber is not adjustable on our cars from the factory! All the more reason to stick to a strict rotation schedule! Also another reason I don't like uni-directional tires!
Old 03-03-2014, 06:57 AM   #73
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I will be curious to hear what the dealership will do about a non-adjustable settings that's out of spec.
Old 03-03-2014, 10:30 AM   #74
Xilikon
Member#: 382821
2014 Impreza Touring
Dark gray metallic
Usually, if that setting is out of whack, it mean that a suspension part is defective and should be replaced under warranty. When the suspensions parts is ok, the numbers should be ok as well.
Xilikon is offline   Reply With Quote
Old 03-08-2014, 04:09 PM   #75
jsteg
Member#: 329271
Ice Silver Metallic
Any updates??
