Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 12-18-2007, 01:25 PM   #376
Import Car Center
Vendor
Member#: 162594
04 WRX STG 4+
Originally Posted by NITROS View Post
I'll try and answer some of these Q's
1) If you run speed density you can remove all the junk thats comes before the turbo (run open turbo, no airbox, or other piping) and still have the engine run properly.
you still have to have the maf sensor somewhere in the piping, otherwise it wont run.
Import Car Center is offline   Reply With Quote
Old 12-18-2007, 02:49 PM   #377
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Yes this is true. The car needs the maf as it uses the maf below the OFL cross over point.
IIRC you can set the OLF cutover point to 0 tps. Thus, this would mean (I am speculating here) you will not need a MAF to run the car, but a IAT is necessary, and with suby they come with the maf.
NITROS is offline   Reply With Quote
Old 12-22-2007, 01:39 PM   #378
russian_kz
Member#: 167303
turbo xs better e-manage ultimate?
russian_kz is offline   Reply With Quote
Old 08-11-2008, 04:02 AM   #379
usmc 04sti
Member#: 185443
2004 sti
how much horse power would i b looking at if i add utec?? and methanol injections??
usmc 04sti is offline   Reply With Quote
Old 10-02-2008, 07:50 PM   #380
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
It all depends on what other mods you have, how good your gas is, what elevation you are at, and what dyno you are on. As well as how good the tune is.
Defiant Autospeed is offline   Reply With Quote
Old 02-08-2009, 11:58 AM   #381
kefalonitis
Member#: 121396
i just did some major upgrades to my car and i'm running UTEC, now i have to get it tuned but i'm afraid to drive the car to the tuner cause its so different i.e. went from sti pink injectors (565cc?) to deatchwerks 850cc and a vf34 to a fp Green, also running a 70mm cold air intake as opposed to the stock size of 65mm. Any reccomendations? anyway i can get like a basic map and parameters? i'm running the latest version of utec
kefalonitis is offline   Reply With Quote
Old 02-09-2009, 05:07 PM   #382
zaxrex
Member#: 9898
Water Injected Blue
Wowwee, you weren't kidding around, were you?
The good news is that if you can get your car to start, it will be running rich. The turbo choice should not matter unless you get out of manifold vacuum, so keep the load off and have a light foot.
The problem is going to be your MAP readings with that wider cross-section intake. It is not a simple scalar or multiplier issue like the injectors are.
My best guess would be to look for people who have used the APS CAI in the old days when they were maxing out the 5v limit on the stock MAP sensor. They got around it by going with the larger diameter pipe and had to recalculate all the fueling curves. There might be an early version UTEC map in the Ausie forums where they had time to work that issue.
If I were in your position, I would start with a parameter set for running the pink injectors. Lower the injector scaling in steps of 10% or so until the car can start. Then up the idle. Running rich is going to be less bad than running lean. If you are just driving 10 miles or so to the tuner, let them deal with it. More than that the cats(?) and plugs will start growing bad gunk.
zaxrex is offline   Reply With Quote
Old 03-27-2009, 10:14 PM   #383
thelunchbox7
Member#: 185852
2003 WRX
blue
what other programs do you suggest using besides hyperterminal to connect to the utec?
im having alot of trouble getting vista to connect to it..
thelunchbox7 is offline   Reply With Quote
Old 05-04-2009, 09:51 AM   #384
04MODWRX
Member#: 210363
2004 Modded WRX
Default 1150 CC injectors and tuning
A local race team and tuner is having a problem tuning my car. he said the 1150 cc injectors are not large enough to give the motor enough fuel. At full throttle the computer is telling him the incjectors are between 96% and 100% usage. he said this should be no more that about 88%. he said to run safely I need 1600 cc injectors. Is this going way overboard??? Here is a list of the mods
Crawford S2 2.5 liter short block
Manley H-Beam Rods
ARP Rod Bolts
APR headstuds
DPR Stage 4 cams
DPR Valvesprings and titanium retainers
AR Fab modified sti oil pump
AR Fab Crankshaft Harmonic Balancer
Peakboost 2.5" rotated mount uppipe
Custom downpipe
Precision 6265 Turbo with 4" Anti-surge compressor inlet
Helix 3" Cat-Back Exhaust
Custom Blow through maf intercooler pipes
Balanced and Polished Crankshaft
Turbohoses couplings, bends, and clamps.
Perrin Big Maf adapter
Aeromotive Fuel Rails
Fuelab Fuel pressure regulator with gauge
Stainless Braided Custom Fuel Lines
TGV Delete
DCCD pro DCCD controller
Gruppe-S headers
ACT 6 puck clutch
4" inlet K&N Filter
Custom intake
Relocated Radiator Resovoir
Paranoid Fabrications Grounding kit
Turbo XS UTEC Engine Managment System with Speed Density
Turbo XS Front Mount Intercooler
Turbo XS Tuner
Turbo XS 4 Bar Map Sensor
Apex'i AVCR Electronic Boost Controller
Helix Oil catch can
Deastchworks 1150cc injectors
Dual Walbro 255 lph high-pressure fuel pumps
fuelpump hotwire kit
STi 6 speed Transmission
STi tranny mounts
STi short shift linkage
STi flywheel
STi Group-N motor mounts
STi Coilpacks
PE timing belt
Cometic head gasket
NGK Iridium BKR7EIX spark plugs
Coolingmist Methanol Injection kit
RCI one gallon fuel cel for methanol
Tial 44 mm wastegate
Tial 50mm Blow Off Valve
04MODWRX is offline   Reply With Quote
Old 05-04-2009, 12:39 PM   #385
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
well you could keep the DW 1150 and bump your pressure from 43.5 to 85psi and you could flow just over 1600cc. Not sure if this is the best way to go but it would work. Maybe someone else can chime in here with more experience.
A good thread to look into about big injectors and raising fuel pressure:http://forums.nasioc.com/forums/show....php?t=1702099
BlackJavaPearl04 is offline   Reply With Quote
Old 06-30-2009, 02:53 AM   #386
glennster
Member#: 212100
03 wrx wagon
can anyone help me get my utec to work
glennster is offline   Reply With Quote
Old 09-27-2009, 06:50 PM   #387
ozzy2184
Member#: 194327
2002 impreza wrx
whit and black
i was wondering if someone had a utec with 750 inj. just got done rebuilding and want to put a decent base map in for break in
ozzy2184 is online now   Reply With Quote
Old 09-27-2009, 06:51 PM   #388
ozzy2184
Member#: 194327
2002 impreza wrx
whit and black
i was wondering if someone had a utec with 750 inj. just got done rebuilding and want to put a decent base map in for break in.
pm me thanx
Old 04-26-2010, 06:34 PM   #389
becoolyolanda
Member#: 245151
04 STI
Hey i jus installed utec and put a pretty decent map on but now my cruise control isint working anybody know why??
becoolyolanda is offline   Reply With Quote
Old 09-12-2010, 01:33 PM   #390
asilaydyingx6
Member#: 257588
2006 sti
white
i have a utec in my 02 wrx. mods are big MAF 18g turbo tgv deletes turbo xs TBE and some uppipe.
With out the utec my car wont even idle (too lean).is this normal? im assuming it because of the big maf. so i have my 0% column on about 25. is that normal?
asilaydyingx6 is offline   Reply With Quote
Old 09-12-2010, 11:56 PM   #391
Tgui
Member#: 44771
Its normal that your car wont run without the UTEC with your big MAF.
Tgui is offline   Reply With Quote
Old 09-13-2010, 09:22 AM   #392
asilaydyingx6
Member#: 257588
2006 sti
white
thanks alot man
only other question i have is how do u go about doing fuel trim with a obd2. all they have is freeze frame and for that to work you have to throw a cel. ive been pulling my idle sensor off but i no there has to be a better way.
Old 09-14-2010, 01:22 PM   #393
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
now that WRX hackers is gone where do you go for Mick's updated version of the UTEC tuning guide?
Second time I searched I found it on here
cky211 is offline   Reply With Quote
Old 09-16-2010, 07:40 AM   #394
asilaydyingx6
Member#: 257588
2006 sti
white
does anyone know why when i start my car (when it warmed u) it will run full rich barley idle but then comes back down to good idle. i use a utec delta and have 10 in my 0% column for 750 and 1000 rpms?
Old 09-16-2010, 10:55 AM   #395
asilaydyingx6
Member#: 257588
2006 sti
white
i might of figured it out. i have stock modified injectors and perrin fuels rails but im still using the stock fuel pump? i think when i turn the car off because of the lower pressure some fuel might drip into the engine. when i let it sit for like 5 mins it starts up fine. like the fuel drys up.
im pretty sure it said u need a bigger fuel pump for stock modified injectors.
Old 11-16-2010, 01:40 PM   #396
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
just a quick question. if im currently opensource tuned on my 05 wrx can i buy a utec just to use the launch control and ffs but not lose my opensource tune? like i said just trying to use it for lc and ffs.
under0athh51189 is offline   Reply With Quote
Old 11-17-2010, 03:47 PM   #397
cky211
Member#: 31129
02 WRX MPB
have you logged you ST & LT fuel trims to set up the idle for the bigger injectors?
that is a good question
i've tuned a UTEC on 4 cars and I love what it can do myself I would go with a stock ECU & utec talk to Mick the ginge on the utec opensource combo
Old 11-23-2010, 08:35 PM   #398
azureal79
Member#: 264758
2013 Subaru WRX
WR Blue
Default UTEC error
Hello fellow suby owners!
I recently purchased an 02 WRX (with v7 STI swap) and a TurboXS Utec piggyback computer. When I start the car the UTEC counts down, flashes "gAS" then goes to "Err". I suspect that maybe the O2 sensor?? isn't connected and/or reading properly?
Any suggestions on where to start troubleshooting? I am able to upload maps and change them on the fly with the remote switch...though I suspect the error will hinder my tracking and logging abilities.
Thanks all!
Eli
azureal79 is offline   Reply With Quote
Old 02-02-2013, 01:17 PM   #399
BoxoB
Member#: 344269
Default Data Log Question
Don't mean to hijack this thread but I can't start a new one yet so ..... what am I supposed to do NASIOC? you forced me to do it ..
Can someone check out this LOG for me .. 4th gear pull stock 2.0L .. Any tips and or advice would be appreciated
3280 +8.6 3.3 50 60 00 rich +16.5 46.2 +15.7 103 247.50 3.3
3261 +9.0 3.4 60 60 00 rich +15.7 47.2 +15.5 104 286.00 3.4
3350 +10.0 3.5 82 60 00 rich +14.7 52.7 +14.9 104 335.00 3.5
3363 +11.3 3.5 96 70 00 rich +12.3 56.5 +14.0 104 350.00 3.5
3418 +12.3 3.5 103 80 00 rich +10.4 60.7 +14.0 104 475.00 3.6
3450 +13.7 3.7 103 90 00 rich +10.5 66.5 +14.0 104 475.00 3.7
3527 +14.3 3.7 103 90 00 rich +10.6 67.7 +14.0 104 475.00 3.7
3542 +14.5 3.7 103 90 00 rich +10.2 69.4 +14.0 104 475.00 3.7
3588 +14.5 3.7 103 90 00 rich +10.1 70.4 +14.0 104 475.00 3.7
3599 +14.5 3.8 103 90 00 rich +10.1 70.6 +14.0 103 475.00 3.8
3745 +14.3 3.7 103 90 00 rich +10.8 70.8 +14.0 103 475.00 3.7
3716 +14.3 3.7 103 90 00 rich +11.0 72.5 +14.1 103 475.00 3.8
3724 +14.3 3.7 103 90 00 rich +11.9 72.6 +14.0 103 475.00 3.8
3831 +14.3 3.8 103 90 00 rich +11.8 73.2 +14.4 103 475.00 3.8
3835 +14.3 3.8 103 90 00 rich +12.6 73.3 +14.7 103 475.00 3.8
3871 +14.1 3.8 103 90 00 rich +12.9 73.8 +15.5 103 475.00 3.8
3921 +14.1 3.8 103 90 00 rich +13.2 75.7 +16.0 103 475.00 3.8
3987 +14.1 3.8 103 90 00 rich +13.5 75.4 +15.8 103 475.00 3.8
4050 +14.3 3.8 103 90 00 rich +13.7 76.9 +16.5 103 475.00 3.8
4055 +13.7 3.9 103 90 00 rich +13.4 77.6 +16.5 103 475.00 3.8
4095 +13.9 3.8 103 90 00 rich +13.4 76.7 +16.6 103 475.00 3.9
4125 +13.9 3.8 103 90 00 rich +13.4 77.7 +16.8 103 475.00 3.9
4177 +13.7 3.9 103 90 00 rich +13.6 78.6 +17.1 103 475.00 3.9
4214 +13.5 3.9 103 90 00 rich +13.8 78.9 +17.2 103 475.00 4.0
4312 +13.7 3.9 103 90 00 rich +13.8 79.6 +17.3 103 475.00 3.9
4357 +13.9 3.9 103 90 00 rich +13.8 81.6 +17.3 103 475.00 3.9
4363 +13.7 3.9 103 90 00 rich +13.5 81.7 +17.3 103 475.00 4.0
4444 +13.9 4.0 103 90 00 rich +13.4 81.7 +17.3 103 475.00 4.0
4456 +13.9 4.0 103 90 00 rich +13.4 83.8 +17.5 103 475.00 4.0
4492 +14.1 3.9 103 90 00 rich +13.8 84.0 +17.4 103 475.00 4.0
4486 +13.9 4.0 103 90 00 rich +14.0 85.3 +17.3 103 475.00 4.0
4610 +14.1 4.0 103 90 00 rich +14.0 86.6 +17.9 102 475.00 4.0
4610 +13.9 4.0 103 90 00 rich +14.3 86.5 +18.0 102 475.00 4.0
4610 +13.9 4.0 103 90 00 rich +14.5 86.9 +18.5 102 475.00 4.0
4728 +13.9 4.0 103 90 00 rich +15.0 86.1 +18.7 102 475.00 4.0
4803 +13.9 4.0 103 90 00 rich +14.9 87.8 +19.1 102 475.00 4.0
4728 +13.9 4.0 103 90 00 rich +15.3 88.5 +19.2 102 475.00 4.0
4816 +14.1 4.1 103 90 00 rich +15.0 90.3 +19.2 101 475.00 4.0
4916 +13.9 4.1 103 90 00 rich +15.4 90.3 +19.6 100 475.00 4.0
4938 +14.3 4.1 103 90 00 rich +16.4 90.2 +19.5 100 475.00 4.1
4916 +14.1 4.1 103 90 00 rich +16.7 90.4 +19.6 100 475.00 4.1
5005 +13.9 4.1 103 90 00 rich +17.5 91.3 +20.0 100 400.00 4.1
4990 +14.1 4.1 103 90 00 rich +16.7 93.6 +20.3 100 400.00 4.1
5089 +13.7 4.1 103 90 00 rich +17.8 92.3 +20.5 100 400.00 4.1
5005 +13.7 4.1 103 90 00 rich +18.5 91.1 +20.1 100 400.00 4.1
5167 +13.9 4.1 103 90 00 rich +18.6 92.7 +20.3 100 400.00 4.1
5096 +13.5 4.1 103 90 00 rich +19.0 93.8 +20.8 100 400.00 4.1
5249 +13.5 4.1 103 90 00 rich +19.5 94.2 +21.0 100 400.00 4.1
5151 +13.5 4.1 103 90 00 rich +19.4 91.9 +21.0 99 400.00 4.1
5274 +13.3 4.1 103 90 00 rich +19.6 92.2 +21.0 99 400.00 4.1
5224 +13.5 4.1 103 90 00 rich +19.5 94.5 +21.0 99 400.00 4.2
5420 +13.5 4.1 103 90 00 rich +19.5 91.6 +21.0 99 400.00 4.2
5324 +13.3 4.1 103 90 00 rich +19.6 94.7 +21.0 99 400.00 4.2
5367 +13.1 4.1 103 90 00 rich +19.6 93.7 +21.0 99 350.00 4.2
5473 +13.1 4.2 103 80 00 rich +20.2 94.6 +21.0 99 350.00 4.2
5385 +12.7 4.2 103 80 00 rich +20.4 91.8 +21.0 99 350.00 4.2
5592 +12.3 4.2 103 80 00 rich +20.4 93.9 +21.0 99 350.00 4.1
5640 +12.7 4.2 103 80 00 rich +21.3 95.0 +21.0 99 350.00 4.2
5546 +12.3 4.2 103 80 00 rich +21.7 91.8 +21.0 99 350.00 4.2
5592 +12.1 4.1 103 80 00 rich +21.8 92.6 +21.0 99 350.00 4.1
5678 +11.9 4.2 103 80 00 rich +21.8 92.5 +21.0 99 350.00 4.2
5583 +11.7 4.2 103 80 00 rich +21.4 92.4 +21.0 99 350.00 4.2
5698 +11.7 4.2 103 80 00 rich +21.6 92.7 +21.0 99 350.00 4.1
5640 +11.3 4.1 103 70 00 rich +21.9 91.6 +21.0 99 350.00 4.2
5707 +11.5 4.2 103 70 00 rich +21.6 93.0 +21.0 99 350.00 4.1
5757 +11.3 4.1 103 70 00 rich +22.4 93.5 +21.0 99 350.00 4.2
5747 +11.3 4.2 103 70 00 rich +22.0 92.5 +21.0 99 350.00 4.2
5727 +11.3 4.2 103 70 00 rich +22.1 93.8 +21.2 99 350.00 4.2
5757 +11.5 4.2 103 80 00 rich +22.0 95.3 +21.3 99 350.00 4.2
5827 +11.3 4.2 103 70 00 rich +22.2 95.3 +21.4 99 350.00 4.2
5878 +11.5 4.2 103 70 00 rich +22.5 97.0 +21.5 99 350.00 4.2
5847 +11.5 4.2 103 70 00 rich +22.2 96.7 +21.6 99 350.00 4.2
5941 +11.0 4.2 103 70 00 rich +22.2 96.1 +21.6 99 350.00 4.2
5963 +11.0 4.2 103 70 00 rich +22.4 95.9 +21.7 99 350.00 4.2
5973 +11.3 4.2 103 70 00 rich +22.1 96.3 +21.7 99 350.00 4.2
6071 +11.3 4.2 103 70 00 rich +22.8 98.2 +22.0 99 350.00 4.2
6038 +11.5 4.2 103 70 00 rich +22.6 98.8 +22.0 99 350.00 4.2
6016 +11.3 4.2 103 70 00 rich +22.8 ---.- +22.0 99 350.00 4.2
6082 +11.3 4.2 103 70 00 rich +22.6 97.5 +22.0 99 350.00 4.2
6038 +11.5 4.2 103 80 00 rich +22.5 98.9 +22.0 99 350.00 4.2
Yes I saw that I maxed out my injectors .. that's why i stopped before redline .. It says rich all the way thru the pull can I scale the injectors back to lean the entire map? what's the best way to take out some fuel?
BoxoB is offline   Reply With Quote
Old 09-21-2013, 04:37 PM   #400
GhostEJ25
Member#: 368646
2008 WRX Impreza
WR Blue
Do I a tune on my 08 Subaru WRX Impreza 2.5 if I change stock air intake and blow off valve?
GhostEJ25 is offline   Reply With Quote
UTEC fuel tuning question Davenow Engine Management & Tuning 2 02-27-2003 01:46 PM
New UTEC software/tuning questions RIDEwrx Engine Management & Tuning 48 01-23-2003 02:20 PM
UTEC Fuel tuning question? muddywaters Engine Management & Tuning 2 01-17-2003 08:44 PM
TXS UTEC sowtware/tuning question RIDEwrx Engine Management & Tuning 1 01-12-2003 06:47 PM
UTEC fuel tuning question rwroth Engine Management & Tuning 2 01-02-2003 06:25 PM
