Old 01-24-2013, 04:00 PM   #51
EM101
Member#: 324428
2013 Impreza
Marine Blue Pearl
Originally Posted by tsigeoff View Post
I just got new wheels from tirerack with new tpms installed for my 12 wrx. I just went to my local Monroe brakes and they did it for free. Took about 5 mins to get the codes into their handheld machine then programmed into the ecu. Easy as pie
It's not the '12 that has the issues, its the '13 model Impreza. Every tire place other than the dealer can read the sensors but can't write them to the car.
EM101 is offline   Reply With Quote
Old 01-24-2013, 04:31 PM   #52
tsigeoff
Member#: 314721
2012 WRX Limited
whoops sorry!
tsigeoff is offline   Reply With Quote
Old 01-26-2013, 04:51 PM   #53
Mgeorge8
Member#: 342878
Originally Posted by Mgeorge8 View Post
I got winter tires put on with tpms and tirerack said they MUST be programmed by dealer. I learned this the hard way by spending a few hours at STS while they tried to figure it out. The Subaru dealer wants $50 to program all four tires.
Had this done today at the dealership. Cost:$47 Paid: $0 . Thanks to Subaru Dollars from Mastercard.
Mgeorge8 is offline   Reply With Quote
Old 02-13-2013, 06:43 PM   #54
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
good deal tsigeof.
i just got the ATEQ-Quickset set up today with my snows / steelies (winter). i have two options at this point because I had the Subaru dealer program my snows.
1. check with the tire places to activate my OEM wheels / summer tires once the light comes on in the spring...
2. get them from Subaru. you would think they would include those codes with your Invoice or Manual, kinda like the roadside assistance cards with the VIN.
the set up was pretty easy on Windows 7, 64 bit - just make sure you download the drivers from the website.
i'm NOT sure if this step is actually needed, but if you have a Cobb AP or Tune, you may want to uninstall it before you try to pull your existing codes from the ECU. i asked cobb right here on NASIOC about it and they suggested to do it. so i did.
1. uninstall Cobb AP.
2. pull codes using ATEQ Quickset
3. reinstall Cobb AP
4. connect ATEQ Quickset to your computer and save the codes into the software. PRINT the sheet. *highly suggested just incase you loose the data or the software for whatever reason.
done. i'm very excited i won't have to go back to the dealer or anywhere else for TPMS for as long as I own this car.
Also, it works with other cars and you can have up to 4 vehicles sensor info with one device... (print all codes).
hope this helps. it's well worth the $150 to me. no more hassle and no more stupid light.
PS: i set up my 2012 WRX as a 2011 Impreza. there aren't any options passed 2011 IIRC.
ChesterWRX is offline   Reply With Quote
Old 03-08-2013, 04:06 PM   #55
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Ateq tpm Quickset works with 2012 and 2013 subaru impreza 2.0i NA
I have aftermarket sensors in the wheels: TPMS: 315 MHz Tire Pressure Sensor
I was able to retrieve the sensor id for winter tires and then I entered in the summer wheel sensor ids and then updated the cars ecu.
I then retrieved from car's ecu to confirm that the new codes for the summer wheel were in the computer.
The total for the tpms sensors was 144, the tpm quickset was 150, Dealerships sometimes charge 100 or more to do the
switch over.
ATEQ QuickSet TPMS Reset Tool : Amazon.com : AutomotiveATEQ QuickSet TPMS Reset Tool : Amazon.com : Automotive
ateq quickeset version 3.02 Beta 8
Version 3.02 Beta8 - V
quickset firmware: QD1-45
Database version: 20130108
OS: windows 7 64bit
Installed the drivers first, then installed the ateq software.
After software install ran update with tpms device plugged in.
Updated database and device
Choose 2012 subaru impreza even if you have a 2013 as they are the same car
NOTE: WHEN ORDERING FROM TIRERACK HAVE THEM SEND YOU THE SENSOR IDS, YOU HAVE TO TELL THEM THIS WHEN YOU ORDER AND ALSO WHEN THEY CALL TO TELL YOU THAT YOU HAVE TO GO TO THE DEALERSHIP TO INITIALIZE THE NEW SENSORS.
FYI:TPMS provisions were updated end of 2011
http://www.dunntireblog.com/consumer...ct-tpms-ruling
http://tires.about.com/od/Tire_Safet...ng-Sensors.htm
http://www.tirereview.com/Article/95...tpms_regs.aspx
Old 03-09-2013, 04:16 AM   #56
hi5.0
Member#: 340456
2013 Impreza
good info! should save some coin when changing wheel/tire combo.
hi5.0 is offline   Reply With Quote
Old 03-22-2013, 11:25 PM   #57
N.G.S.
Member#: 334310
2012 Mitsu Evo X
I might have a solution for the tpms issue. I am looking for someone in the NYC/ NNJ area to be a guinea pig. Here is a link to an Evo forum thread that explains it.
http://forums.evolutionm.net/evo-x-t...oven-work.html
N.G.S. is offline   Reply With Quote
Old 03-23-2013, 11:36 AM   #58
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
subscribing for future reference
Old 08-30-2013, 08:35 PM   #59
dhlee528
Member#: 337395
2014 Impreza SP Ltd
ISM
sorry to bump old thread
I want to do tire rotation, can I just take it to firestone or something and ask for it?
if tires get rotated, do TPMS needs to get reset?
can they reset TPMS or do I have to go to dealer for it? (earlier in the thread states that firestone can't do it, but since it's been a year or so, I'm guessing they might be able to do it now?)
also, if I got to dealer and ask for tire rotation only, what's the average price for just tire rotation? (possible plus tpms reset fee)
if I get that quickset tool, can it reset stock TPMS ?
I just need rotation because I do my own oil change, and still on stock tires
dhlee528 is offline   Reply With Quote
Old 08-30-2013, 09:25 PM   #60
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
TPMS should not need adjustments for tire rotations as long as you are using the same tires, etc...
Old 09-11-2013, 12:19 PM   #61
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Didn't your car come with TMPS sensors? I bought new wheels and tires for my car and they just used the same sensors and re-built them. Cost like $7 for the re-build kits for each wheel I think. Never had an issue with it.
VegasSubie is offline   Reply With Quote
Old 09-11-2013, 02:43 PM   #62
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Subaru's TPMS is dumb. It just lets you know if a tire is below 26 psi. It doesn't care about the tire location. It would be nice to be able to read TPMS data through OBDII, but as far as I know you cannot. It would also be nice if Subaru could be as advanced as someone like Chevrolet, who tell you the real time pressure of each tire in your dash. But Subaru is not a technology minded company. Chevrolet isn't either, but come on man.
foghelmut is offline   Reply With Quote
Old 09-11-2013, 03:15 PM   #63
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
The only Chevy I've read about that provides that kind of TPMS data on the dash is the new Corvette Stingray. Not quite in the same league as our Imprezas, right?
Old 09-11-2013, 03:36 PM   #64
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Would be a nice to know which tire it is. I would think it could cause some issues and make you have to take the car to the dealership to get your tires rotated. If you move a wheel around it would need to have the TPMS re-programmed to match which wheel is where.
Old 09-11-2013, 06:15 PM   #65
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i drove a Cruze rental for work and it could tell you
Old 09-11-2013, 06:53 PM   #66
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i really with Cobb or a 3rd party could find a way disable that stupid light. the money spent on my Quickset & the extra sensors for my winter wheel & tire package could have gone into better mods.
**yes, i know, i could have just ignored the light... but i'm OCD. not gonna drive around with that stupid light on for xxxx amount of months per year.
Old 09-11-2013, 07:04 PM   #67
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
shute, i just remembered that when I rotated back to my OEM wheels / tires, I went to the my dealer to get the reprogramed as i didn't have the codes of them. *see post # 54 for my history.
guess what? they were ready to order a new door lock relay (transmitter maybe) because they could NOT get any of my OEM sensors to register.... ***i will try and dig up the paperwork, but i don't really save them because they update it on subaru.com/owners anyway.
I'd uninstalled my Cobb AP as well...
so i said cool, they said they'd call me when the part came in.
we'll... waddya know? no TPMS light after 2 days, where usually it comes on within 10-15 min or a few miles, right?
i got home, pulled the codes for my OEM Wheels / Tires w/o issues.
when my dealer called me i told them the TPMS was NOT on and that if they still wanted me to bring the car in? they said "nope, if it comes on, let us know"
-chet
Old 09-11-2013, 07:04 PM   #68
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
-chet
Old 09-16-2013, 03:36 PM   #69
foghelmut
Member#: 328414
2012 Impreza SP 5MT
My fiance has a 2008 Cobalt which does this. I'd say that's not quite in the same league as our Imprezas.
It's done with a TPMS tool, or can be done manually by putting the car into a learning mode. It's not a big process.
Old 09-24-2013, 04:56 PM   #70
wuzin
Member#: 368795
2013 Impreza Premium
Dark Gray Metallic
Did anyone try to disconnect the TPMS module?
I have 2013 Impreza, and going to put new wheels without TPMS.
From the dealer service manual, it states that module controls both TPMS and Keyless entry system.
Since I don't have Keyless entry, I should try disconnect the module and see whether it still lights up the TPMS light on the cluster or not.
wuzin is offline   Reply With Quote
Old 09-24-2013, 05:14 PM   #71
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
You don't have keyless entry?
Old 09-24-2013, 05:18 PM   #72
wuzin
Member#: 368795
Dark Gray Metallic
Ouch, my bad!!
I was confused with keyless start
Old 11-10-2013, 12:52 AM   #73
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Small update: I don't remember seeing a pictures of someone etaping the TPMS light but...
I got a smoking deal on a full set of Subaru alloys with General Altimax Artic tires on them, 90% tread left. I was originally planning to eventually get a set from Tirerack, but then these came up.
Bottom line is, they don't have TPMS, and I didn't want to look at the light all winter. I thought of just putting the e-tape on the glass, but then I'd see reflection, and probably light at night.
6 screws, and 15 minutes later, voila! The TPMS light is on there, but now you can't see it, and unless you shine a flashlight right at the e-tape, you can't even tell it's there.
1. Disconnect the battery (because really, what procedure in the manual doesn't call for this).
2. Remove the 2 screws holding the face plate on. The bottom of the face plate is held in with tabs. They don't require releasing, just gently wiggle them out.
3. Remove the 4 screws.
4. Disconnect the instrument cluster wire bundle in the back (for ease of the next step)
5. Gently remove the cluster glass (plastic). I found it easiest to release one tab, and gently wedge it apart, going all along the outside.
6. Cut about a 0.5 cm sq piece of etape, and put it in place.
7. Reassemble everything.
Xafen is offline   Reply With Quote
Old 11-10-2013, 05:54 AM   #74
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^Are you planning to leave the tape on there all the time, or will you be removing the tape in the spring?
Old 11-10-2013, 11:11 AM   #75
Xafen
Member#: 306398
Camellia Red
I plan to remove it. It was very easy to do. It was only 6 screws and some tabs to spread apart, even being my first time doing it, having no idea what I was doing, I had it done in ~15 minutes.
TPMS is nice to have, even for someone who checks the air pressure all the time like me, because who knows when a nail might hit you in the middle of a long drive.
Until I sell this set of winter tires, which will be several years, I'll just make this a part of my tire swap routine when i change to summer/winter tires.
