Welcome to the North American Subaru Impreza Owners Club Monday September 1, 2014
Old 09-26-2013, 08:56 PM   #2776
Crash00527
Member#: 367123
2013 Impreza Premium
Marine Blue Pearl
There's also cusco for 150.
Crash00527 is offline   Reply With Quote
Old 09-28-2013, 07:29 PM   #2777
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
What spacers could you use to lift the car and how much lift would you get?
goregasm is offline   Reply With Quote
Old 09-28-2013, 10:15 PM   #2778
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Subtle solutions. Put 1" in front and 1 5/8" in back. Check out my thread.
SIA_worker is offline   Reply With Quote
Old 09-29-2013, 02:26 PM   #2779
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I so want to put those on my wife car,but worried about warrenty
subaru222 is offline   Reply With Quote
Old 09-29-2013, 02:37 PM   #2780
kinger37
Member#: 324423
2012 Impreza Sport
ISM
How difficult was it to put these on? I wouldn't mind a little extra ground clearance
kinger37 is offline   Reply With Quote
Old 09-29-2013, 02:58 PM   #2781
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
It took three hours. Had to remove front struts assembly and then compress springs to remove top hat and pound out studs to replace with longer bolts. I would say it's somewhat of an advances DIY mod because of the springs. Autozone rents tool for free
Old 09-30-2013, 02:22 PM   #2782
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Aftermarket parts don't legally affect warranty unless the dealer proves that the part caused the problem. I suppose they could do something general like void the entire warrant with a bolt on turbo, but for things like this they can't deny warranty claims.
Old 09-30-2013, 03:58 PM   #2783
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Exactly. They can't be like "oh, you put an exhaust on, which obviously caused your brakes to malfunction." lol Conpletely unrelated.
Old 10-03-2013, 08:29 PM   #2784
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Do you guys think I would have any luck getting this lip to fit my car? I know its for the WRX/STI, but it's only $65 and might be sweet if i could make it work...
Old 10-04-2013, 09:29 PM   #2785
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
But if i add the lift and a shock blows out,there goes the warrenty
Old 10-04-2013, 09:58 PM   #2786
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Unless it's something major, most of the time they try to get out of warranty work anyway. Screw it.
Old 10-04-2013, 10:44 PM   #2787
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Just go for it. I shock is cheap if it blows. If your that worried take lift off b4 any major warranty service is performed.
Old 10-04-2013, 11:02 PM   #2788
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Or if a shock blows, just buy a better aftermarket one. lol More reason to build your suspension.
Old 10-10-2013, 05:16 PM   #2789
tenaciousZ
Member#: 342279
2012 Impreza Sport
http://www.vleds.com/cxa-led-headlights.html
I'm hesitant, but I thought I'd share..
tenaciousZ is offline   Reply With Quote
Old 10-10-2013, 05:41 PM   #2790
Rememo
Member#: 340728
2013 Impreza 5-spd
I think you'll be fine. While researching LED headlights for my motorcycle, I found that the type you listed were the only kind recommended by various automotive forums. The LED replacement bulb type are pretty much useless. The only downside of these is the length. Gotta have the room for them.
Others:
http://philipshidkits.com/20w-rsi-h7...onversion-kit/
Here is an eBay listing that I was considering (it has ended):
http://www.ebay.com/itm/310668582173...84.m1438.l2649
Rememo is offline   Reply With Quote
Old 10-11-2013, 09:10 AM   #2791
Algreen
Member#: 268369
2012 Impreza Premium
Ice Silver
I used the paranoid fabrications spacers on 2012 and it was a very easy install. I used 1" rear, 1/4" front, and it till me a total of 1.5 hours. The fronts probably took me 20min because I didn't have to remove the wheels, struts, etc. Very happy with the look. Combined with my 215/55/17 Pirelli P7's, I got 1.66" lift rear, and .91 front.
Algreen is offline   Reply With Quote
Old 10-11-2013, 09:51 AM   #2792
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Did you need longer studs to install these on the rear?
Old 10-11-2013, 09:54 AM   #2793
TRSAndrew
Member#: 360634
2013 XV Crosstrek
Orange
Others:
Actually all of these are useless optically. We've tested them and a single chip won't do anything for you, nor will some tower of LEDs.
TRSAndrew is offline   Reply With Quote
Old 10-11-2013, 10:05 AM   #2794
tenaciousZ
Member#: 342279
2012 Impreza Sport
I believe they have two arrays, top and bottom.. either way, please share your insight and methods.
Like i said, I'm hesitant but am in the process of doing my due diligence. would you say they yielded no improvement over the halogens or produced less usable light?
Old 10-11-2013, 10:56 AM   #2795
TRSAndrew
Member#: 360634
2013 XV Crosstrek
Orange
They produce about 2/3 the light output of an HID bulb, but only in one or maybe two (if you're lucky) directions.
Also anything with active cooling is bound to fail. You need something with passive cooling like a big aluminum heat sink.
In a projector, the lower LED is useless anyway, as is the unidirectional LED chip, so we made a triple layout LED bulb:
It also has a copper core in the center to help get the heat away from the chips and out the back:
Old 10-11-2013, 12:27 PM   #2796
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Algreen, did you have a shop paint your fog surrounds, or was that a DIY? Prep? Was thinking of color-matching mine as well.
Old 10-11-2013, 12:56 PM   #2797
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
It's actually difficult to even tell that your lifted at all cause those tires fill in the wheel gap very nicely! I'm also curious as to whether or not you had your fog light surrounds professionally painted or not.
jr0bb5 is online now   Reply With Quote
Old 10-11-2013, 06:22 PM   #2798
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Looks good man! I went with 215/50-17 got 1 1/2 inch total in front and 1 7/8 in back
Old 10-11-2013, 06:32 PM   #2799
bradze
Member#: 103208
2011 Outback
Azurite Blue
looks good, might do that to my wife's impreza
bradze is offline   Reply With Quote
Old 10-11-2013, 09:51 PM   #2800
jr0bb5
Member#: 315353
5MT OBP/DGM
I really need to invest in some "saggy butt" spacers. The stance of my car looks stupid with the a$$ end so much lower looking than the front. I wonder why they come from the factory like that??
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
