Tire & Wheel Forum sponsored by The Tire Rack |
09-25-2013, 03:39 PM | #2326 |
Member#: 321857
Further into the wheel well, as in in the tires might rub on the strut.
09-25-2013, 04:49 PM | #2327 |
Member#: 362867
Vehicle:2013 WRX WRB |
Further in. The larger the number the further into the wheel well. The lower the number the further out. Offset is mms that the center of the wheel is from the hub. A zero offset, the center of the wheel would be dead center on the hub/brake disc. (More lip) a +38 would mean the center of the wheel is 38 mm off center to the car. A +48 would be 10mms further toward center. It is "offset" from center. This is why different widths with the same offset sit different. Because offset is from center.
09-25-2013, 05:55 PM | #2328 |
Member#: 324709
Vehicle:2012 WRX Sedan SWP |
Just for reference, the link below is an sti with 18x9 +63. Which is 12mm further in than a 18x9.5 +45 or 9mm further in than a 18x9.5 +48. I don't know how much the strut clearance varies on the GR WRX vs GR Sti but with minimal negative camber I'd guess you'd be ok.
http://www.iwsti.com/forums/gr-tires...ring-rf-2.html |
09-25-2013, 06:10 PM | #2329 | |
Member#: 97135
NWIC
realistically, there is such an assortment of wheels in the low to mid 40's that fit without issue, that an offset that high should not be considered. |
09-25-2013, 06:36 PM | #2330 | |
Member#: 337792
South East
Vehicle:2013 WRX SWP |
09-25-2013, 07:51 PM | #2331 | |
Member#: 324709
Sidenote: I have seen guys running 18x9.5 +45 with 255/35R18 and -1.5 camber |
09-25-2013, 08:04 PM | #2332 | |
Member#: 97135
NWIC
The reason you can gain clearance with coilovers is through the use of camber plates which will actually angle the strut vs the hub (like with bolts). This is all based purely on how they're setup though. |
09-25-2013, 09:01 PM | #2333 |
Member#: 324129
Tri-State
Vehicle:2015 Evo |
I have a 2013 WRX and I'm trying to figure out if a set of 225/50/17 Tires on 7-8" wide wheels will fit (stock is 235/45/17). I read the stickies and this thread but I just want to make sure before I spend a couple hundred bucks. It doesn't seem like a huge difference but the calculator I'm using says the tires will fill out the wheel well by an extra 7mm. This should fit, right?
Thanks |
09-25-2013, 09:08 PM | #2334 |
Member#: 97135
NWIC
sure it'll fit, but a 225/45 would be better.
09-25-2013, 10:03 PM | #2335 |
Member#: 255232
MWSOC
Vehicle:2011 WRX Sedan Ltd Spark Silver Metallic |
The general rule is that you dont want to bemore than 3% taller or shorter thank stock
09-25-2013, 10:13 PM | #2336 |
Member#: 351622
South East
Vehicle:2013 Wrx White |
09-26-2013, 10:12 AM | #2337 | |
Member#: 12029
MAIC
For a couple reasons. First, if you change tire diameter your speedometer and tachometer will be off by the same amount, and after 2% it starts to be enough to actually be a nuisance. Secondly, you're changing the car's final drive by the same amount, which will affect cruise RPMs, mileage, and driving behavior. Finally, if the tires get too small you are losing ground clearance, and if they get too big in diameter you are risking contacting the bodywork. SO: Generally speaking, if possible, stay within 2% of the factory diameter. Now, one thing to keep in mind is that the GR/GV WRX and STI cars share the same chassis and bodywork, but the WRX comes with a smaller stock tire than the STI. (WRX = 235/45R17 = 25.3" diameter; STI = 245/40R18 = 25.7" diameter, 1.5% taller.) So you know there's at least 1.5% of headroom on the WRX in terms of up-sizing. I don't think I'd go much taller than that STI tire, though. --Dan Mach V |
09-26-2013, 10:51 AM | #2338 | |
Member#: 300848
MWSOC
Vehicle:2012 WRX LR |
09-26-2013, 11:01 AM | #2339 |
Member#: 327511
MWSOC
Vehicle:13' WRX 6 Speed 11sec VF52 EL-EWG-E85 |
09-26-2013, 08:11 PM | #2340 |
Member#: 271749
Vehicle:2015 STi Launch Ed. WRB |
2012 WRX hatch
Suspension: stock everything Wheels: Miro 111 (machined silver finish) - size: 18x9.5 - offset: +40 Tires: Yokohama Avid 255/35/R18 Fenders: no roll or pull So far no rubbing, but we'll see! |
09-26-2013, 08:45 PM | #2341 |
Member#: 351622
South East
18x9.5 +35 rota G force wheels with 245 45 18 tires stock suspension rear fenders had to be rolled but not rubbing after that.
09-26-2013, 10:06 PM | #2342 |
Member#: 367713
Tri-State
Vehicle:2014 WRX DGM |
Great thread!
I'm planning on going with a spring/shock combo. Possibly Koni Inserts with swift springs, or billstien shocks with swift springs. (STill haven't nailed it down) I plan to get the suspension dialed in before I make a final wheel choice, but I'm generally curious about enkeis. I really like the RPF1's What's the general consensus on wheel size with this wheel on lowered cars? I've seen 17x9 et35 as a common place, but I want to avoid rolling fenders. Would 17x9 or 18x9 (et35) cause any rubbing on the fender with a spring/shock combo if the fenders are not rolled? |
09-26-2013, 10:31 PM | #2343 | |
Member#: 351622
South East
09-26-2013, 10:34 PM | #2344 |
Member#: 367713
Tri-State
09-26-2013, 10:37 PM | #2345 |
Member#: 351622
South East
I did a minor roll and it stopped. Don't be scared about rolling your fenders. Go to a shop that does it right and you will be fine. Make sure they heat the paint and it will all be good I have had no issues with my paint
09-27-2013, 09:17 AM | #2346 | |
Member#: 321857
09-30-2013, 01:58 PM | #2347 |
Member#: 353305
MAIC
Vehicle:2011 premium wrx swp |
I have 18x9.5 et 38 with stock suspension and a rear fender roll, and I have no issues. I've tracked my car @ summit point main(Jefferson circuit) as well I just got home from VIR and had no issues there. I run a 255x35 re11's pretty square set up.
10-04-2013, 12:00 AM | #2348 |
Member#: 302186
Tri-State
Vehicle:2011 wrx pearl white |
So im going with a 18x8 but cant decide on offset.. The wheel im getting comes in +35 or +48.. I kind of want the 35 but if this is going to compromise anything negatively or hurt anything i dont want to do that.. Any quick input?
10-04-2013, 09:45 AM | #2349 |
Member#: 321857
The +48 will sit almost exactly like stock (completely sunken), it's the same width and only 5mm more offset. The +35 will work fine and at least provide some visual offset change.
10-04-2013, 09:48 AM | #2350 |
Member#: 302186
Tri-State
Similar Threads | ||||
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
