Old 09-20-2013, 10:47 PM   #1
Essem
Member#: 287931
2013 Sport Premium
Default Am I being paranoid about my engine noise?
I've got a 2013 Sport Premium. I don't know if i'm being paranoid, but when it's quiet enough to really listen to the engine, I can hear what I can described as a slight rattling. It's kind of like a higher pitched rev sound when accelerating, pretty much undetectable while coasting or idling.
It's quite possible that it's nothing and it's simply me learning to focus more on the sounds my engine makes, as this is my first boxer engine and first subie (coming from a jetta).
I've heard about the piston slap of boxer engines but I'm not sure if that's what i'm hearing. The car only has 4000 miles on it and the dealer told me not to bother with my first oil change until 7500ish.
Essem is offline   Reply With Quote
Old 09-21-2013, 12:14 AM   #2
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I'd go ahead and change first oil now. Not sure your sound, but injectors are loud on these. Same as my bro's new Tacoma.
G2Spfld is offline   Reply With Quote
Old 09-21-2013, 03:57 AM   #3
Essem
Member#: 287931
2013 Sport Premium
Yea i'm planning on it. Naive question but is there anything special about a subaru oil change if I do it myself? I was going to just take it to the dealer but $60+ for synthetic is kind of a rip off when I can do it myself for $30-$40.
Old 09-21-2013, 06:07 AM   #4
79letour
Member#: 302570
2013 XV
DGM!
Juat get a filter, crush washer and some 0w20 from walmart or somewhere. Its easy. oh and you'll need some boards or ramps.
Old 09-21-2013, 06:08 AM   #5
79letour
Member#: 302570
2013 XV
DGM!
Ive changed mine at least a half dozen times and its really easy.
Old 09-21-2013, 01:26 PM   #6
Essem
Member#: 287931
2013 Sport Premium
I always did it myself on my old car but was just hesitant on the brand new car. But i guess the consensus is i'm probably just being paranoid about the sound? haha
Old 09-21-2013, 02:38 PM   #7
LGA2011
Member#: 321173
Just let the dealer test drive it at the next appointment. It's under warranty if something fail.
LGA2011 is offline   Reply With Quote
Old 09-21-2013, 08:16 PM   #8
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Or get in another Impreza and see if you hear the same sound. And yes, oil changes on the Impreza are easy. Have you seen where the filter is on these cars? Awesome.
Old 09-23-2013, 10:52 AM   #9
IveBeenRued
Member#: 305466
2012 Sport Limited
Oil changes are extremely simple on these cars. While the crush washer is supposed to be replaced at each oil change I've done 8 changes without replacing it and I have yet to have any issues. Just use a high quality oil and a good filter and you will be fine.
IveBeenRued is offline   Reply With Quote
Old 09-23-2013, 12:35 PM   #10
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
^Fumoto valve... just sayin...
Easy install, easy oil changes, $25 mod, never have to make a mess or buy washers again.
Old 09-23-2013, 08:41 PM   #11
PA452
Member#: 346220
2013 Impreza Premium
MT Dark Gray Metallic
I've been changing oil on vehicles my whole life since I was a kid. I've never replaced a washer on an oil change and I've never had any problems as a result. Replacing it every change is pointless.
PA452 is offline   Reply With Quote
Old 09-23-2013, 08:50 PM   #12
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Regardless, the Fumoto valve with a nipple is a good way of making the oil change a neater job. You connect a tube to the nipple, which allows you to direct the oil into the pan.
Hot 0W20 flows VERY FAST, and makes a big splash when using the drain plug. The Fumoto fixes that problem, and also prevents the need for crush washers, prevents you from accidentally over-tightening the plug and stripping the threads out of the aluminum oil pan, and so on.
It's a great mod.
Old 09-26-2013, 11:28 PM   #13
subygahhhhh
Member#: 364807
prob inside your trans mine made noises
subygahhhhh is offline   Reply With Quote
Old 10-12-2013, 03:32 PM   #14
spikcdr
Member#: 370758
Mine car the time belts were loose and I still hear odd sounds I'm paranoid any sound I hear I worry I don't want my car to.have issues. Look at ur engine when its on see if a belts are all good.
spikcdr is offline   Reply With Quote
