Old 09-16-2013, 08:45 PM   #26
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Originally Posted by RickyD View Post
like i said the tires are 215 but run as a 223 and simple math shows that 9 inches is 228.6 mm which is a 5.6mm stretch.
Except... if you measured... your 9" wheels are actually 10" wide from edge to edge... So yeah. That's a lot of stretch.
Generally, 255 is proper fitment for no stretch on a 9" wheel. I run 245s and have a slight stretch.
gsrcrxsi is offline   Reply With Quote
Old 09-16-2013, 08:47 PM   #27
sc00by4life
Member#: 97135
depends on the tire :P.
Old 09-16-2013, 09:43 PM   #28
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yeah....this whole concept of the fact that all tires are NOT all the same size as they say they are just does not make it into the heads of so MANY
Old 09-16-2013, 09:53 PM   #29
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I'm speaking generally here. Talking standard sized tires.
But even with the "omgtehsuperwidez" tires you nut swingers get all wet over, 215 will STILL be quite stretched on the 9" wheel.
OP, stop with the "math". Like I said. A 9" wheel doesn't measure 9" from edge to edge. It's from the inside of the bead. Edge to edge is closer to 10".
Old 09-17-2013, 12:41 AM   #30
Xs420240sX
Member#: 368566
pull fenders
Xs420240sX is offline   Reply With Quote
Old 09-21-2013, 02:35 AM   #31
RickyD
Member#: 307098
thanks for the input!
RickyD is offline   Reply With Quote
Old 09-24-2013, 01:48 PM   #32
Ikkitousen
Member#: 354304
2012 WRX
That's super aggressive esp for a 08 without the wide body. I think even if you get -2.0+ camber and roll/cut/pull you'll still hit the fender once you go over a bump anyways. Might work if you don't lower it?
I personally researched many times before pulling the trigger on my setup to make sure it wouldn't rub under any situations.
Bottom line : won't fit, get different wheels. IMO.
Ikkitousen is offline   Reply With Quote
Old 09-24-2013, 01:58 PM   #33
besthaticouldo
Member#: 279660
Yeah, you're going to need to pull, run about 2.7-3* camber to get those wheels to fit properly. Even then, you'll likely need to cut and have a custom flare done to get them to fit properly, and I'd imagine that they aren't the most high quality wheels, so why bother.
Why on earth didn't you get a better offset?
Also FWIW I run a 265 on my 18x9 and they are solid, a 215 is a **** load of stretch, if you think it's not that's why you're having problems. You'll be lucky if you don't pop a bead.
besthaticouldo is offline   Reply With Quote
Old 09-26-2013, 10:32 AM   #34
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
This is just silly. Work harder and a remotely proper tire will work.
colin1234567 is offline   Reply With Quote
Old 09-26-2013, 11:44 PM   #35
RickyD
Member#: 307098
lol cause fatter tires will definitely make it fit
