Closed Thread
Old 09-26-2013, 01:54 PM   #4151
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by chubs73 View Post
No block replacement unless walls scored too much. They have standard ring. 0.25 and 0.50 oversized rings available
Unless I misunderstood I thought this was part of the fix
Angelus911 is offline
Old 09-26-2013, 03:06 PM   #4152
john_coctostan
Member#: 369384
2014 Impreza SL
Originally Posted by Angelus911 View Post
I wonder if they manufacture the new cars with these larger rings
This is the million dollar question for me. Are the '14s going to be "fixed"?
First post, but have been following this thread for a while.
I really need to downsize vehicles and knock the gas mileage out of the park due to a significant change to my length of commute. I also need at least AWD where I live. Impreza fits this bill like no other car, really. Test drove it and like it. But I'm coming from an Xterra, which is essentially bullet-proof, and if I have to baby-sit oil consumption like a bratty kid, I'm going to be ticked.
john_coctostan is offline
Old 09-26-2013, 04:12 PM   #4153
79letour
Member#: 302570
2013 XV
DGM!
Well they have a tsb for the PAPER wrapped seat springs sqeaking, yet they still dont put the bushings on the seat frames. You have to complain about your cheapo seat and wait to get it fixed.
Why did subaru go so far with their denials of the rings being a problem?
Its not a vin-range, its every fb except the first year of foresters with that engine.
From what techs have told me the 11' fozzys are the worst fb oil burners.
This will, imo, most likely take some of that "legendary resale value" away,but rightly so. I would never buy a used fb or fa engined subaru. the warranty is pretty hard to cash in on a BRAND NEW car a month old,I couldnt even imagine if it had 30k on it...
79letour is offline
Old 09-26-2013, 04:14 PM   #4154
79letour
Member#: 302570
2013 XV
DGM!
There is one thing for sure- It most definitely isnt just some ''unique individuals" anymore.
I guess the dealer people werent kidding when they said subaru was starting to admit the problem was real.
79letour is offline
Old 09-26-2013, 05:24 PM   #4155
ocellaris
Member#: 302559
The larger the scope, the longer it takes for companies to admit a problem. Since this covers almost every FB engine, I suspect they were really dragging things out to see if there was any way to avoid actually dealing with the problem.
ocellaris is offline
Old 09-26-2013, 05:30 PM   #4156
nels0300
Member#: 331332
2014 Camry SE V6
Originally Posted by ocellaris View Post
You are dealing with extremely small mechanical tolerances on an assembled engine. Thousandths of an inch can be the different between losing oil and running file. Also it could be an issue with material quality, not all the rings or engine blocks are manufactured at the same time in the same plant with the same stock material for construction. During parts production, the tools needed to make parts get replaced at well. Parts can each be within tolerance but still cause a failure when combined with other parts.
As far as I understand, all fb20 engines for north america are made in the same plant. If I'm reading the TSB correctly, the issue is the coating on the rings which shouldn't have anything to do with tooling issues. There still seems to be pieces missing to the puzzle.
How does this cover only a "limited" number of vehicles but the TSB doesn't specify which vehicles it's limited to, only saying 2012-2013? Were they experimenting with ring coatings? Did they have more than one vendor supplying rings? Did the ring vendor(s) have an issue? OR does this really affect ALL 2012-2013 N/A Imprezas with "limited" meaning limited to 2012 and 2013s?
nels0300 is offline
Old 09-26-2013, 05:33 PM   #4157
ocellaris
Member#: 302559
Tools apply the coating, one way or another.
Old 09-26-2013, 05:41 PM   #4158
79letour
Member#: 302570
2013 XV
DGM!
Tools work at SOA!
79letour is offline
Old 09-26-2013, 05:44 PM   #4159
nels0300
Member#: 331332
2014 Camry SE V6
True.
My main question is how Subaru can say it applies to a "limited" number of vehicles without specifying which vehicles. They would have to know which vehicles in order to be able to say "limited".
nels0300 is offline
Old 09-27-2013, 03:09 AM   #4160
chubs73
Member#: 367514
From what I understand vehicles with build dates 2/13 and newer have the new ring design
chubs73 is offline
Old 09-27-2013, 03:12 AM   #4161
chubs73
Member#: 367514
The only 14's affected are 14 foresters due to their early build date. All fb engines with build dates after 2/13 have uodated rings
chubs73 is offline
Old 09-27-2013, 03:15 AM   #4162
chubs73
Member#: 367514
Originally Posted by Chris793 View Post
I did not see in the TSB posted here where it read 1/3 in 1200 miles. That is the official new standard for the test? I know chubs mentioned that initially.
The tsb refers to the new fb engine oil consumotion form. Vehicke has ro have at least 3,000 mikes. And doesn't require 4 trips to establish. First trip it is down the 1/3 meets the requirements of the tsb
chubs73 is offline
Old 09-27-2013, 08:04 AM   #4163
nels0300
Member#: 331332
2014 Camry SE V6
So how does the TSB only apply to a "limited number of vehicles"?
I'd guess it applies to over half the vehicles Subaru sold in 2012-2013 if it's all FB engines.
nels0300 is offline
Old 09-27-2013, 08:35 AM   #4164
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Its listed on your car sheet where the engine was assembled and where your car was assembled. Both were assembled in Japan but different territories/states/what ever they call them, from what i remember when i was reading mine.
auskip07 is offline
Old 09-27-2013, 08:44 AM   #4165
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
We already know that most cars built before 2/13 don't have a problem. My Impreza was built 4/12, and it doesn't consume oil.
So I think when Subaru says "limited number of vehicles", that's their way of saying that only cars showing the oil-consuming symptom are affected. It would be unwise to replace the rings on all cars built before 2/13 regardless of whether they are consuming oil or not.
I, for one, do not want my Impreza's rings replaced. If it ain't broke, don't fix it.
sgoldste01 is offline
Old 09-27-2013, 08:50 AM   #4166
nels0300
Member#: 331332
2014 Camry SE V6
Just a quick google search shows all Imprezas come from Gunma, Japan and all FBs are made at a new factory Subaru built just for that engine.
nels0300 is offline
Old 09-27-2013, 08:54 AM   #4167
nels0300
Member#: 331332
2014 Camry SE V6
I don't want my rings replaced either, but my car does consume oil. Who wants a new car with a engine that's been torn down? The dealer WILL screw something up, guaranteed.
I really want to know what it is about the coating of the rings that makes some vehicles use oil, but not others.
nels0300 is offline
Old 09-27-2013, 09:05 AM   #4168
john_coctostan
Member#: 369384
2014 Impreza SL
Very good to know. Thank you very much. Definitely gives me reason to be optimistic.
Old 09-27-2013, 09:29 AM   #4169
79letour
Member#: 302570
2013 XV
DGM!
I read that tsb on another site, and it said it still requires the car to burn the 1.1 quarts in 1200 miles. Thats whats posted on XV Forum. I'll try to get the tsb in its entirety and not rewritten. But I'm not paying SOA to download pdf's.
79letour is offline
Old 09-27-2013, 09:33 AM   #4170
john_coctostan
Member#: 369384
2014 Impreza SL
Again, after having read this thread over the months, I understand how those affected by the rings are upset. I've never owned a Subaru, but I've always considered it a top car name.
Subaru is not the only top car maker to have a rather large problem.
I had an '04 Tacoma. Loved that truck. That thing was amazing. Come to find out the 98-04 model year had the wrong mix in the alloy for the frame, and they were rusting out, bigtime. I fell victim to that. I was able to dump the truck on a dealer, but my frame was perforating after 5 years. Others were having total frame replacements. Heavy duty surgery there.
The Xterra I have (2010)... the first three years of the design 05-07 had a major problem. The tranny cooler circulated through the bottom of the radiator beneath the engine coolant. The transmission fluid was corrosive to the layer of metal separating the fluid from the coolant, and eventually would fail allowing the coolant into the transmission. This has lovingly been dubbed the "strawberry milkshake of death", as the transmission fluid looked like a frothy milkshake when the transmission failed.
Toyota backed the frame issue fairly well. Nissan extended transmission warranties, but it's not as good as what Toyota did.
But at least the Subaru problem is not on par with these. Again, I totally understand why people with an oil user are pissed. A new car should be better.
Old 09-27-2013, 10:31 AM   #4171
79letour
Member#: 302570
2013 XV
DGM!
These new developments make it a lot clearer why (so far, knock on wood) my 3/13 built XV hasnt burnt any oil yet, while my 10/11 Impreza required top-offs and low oil lights.
Btw- my dads 99 toyota had a rotten frame pretty quickly too.
79letour is offline
Old 09-27-2013, 10:33 AM   #4172
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ Nicely written post, John. Good job. I enjoyed the "strawberry milkshake of death" reference.
What is your profession, if you don't mind me asking? I'm a technical writer, so I appreciate your post.
Old 09-27-2013, 10:35 AM   #4173
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, but as you know, not every FB engine built before 2/13 is an oil consumer. In fact, most are not.
Old 09-27-2013, 10:41 AM   #4174
john_coctostan
Member#: 369384
2014 Impreza SL
SMOD is horrendous. The Xterra transmission is a $5500 replacement.
I'm a meteorologist (no TV), and I'm actually required to write a lot, essentially explaining my forecasts.
Bonus points to anyone that gets my username. No Google!
Old 09-27-2013, 02:08 PM   #4175
79letour
Member#: 302570
2013 XV
DGM!
Right. But MINE WAS.
79letour is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
