Old 08-18-2013, 12:17 AM   #176
tacoornot
Member#: 223269
98 swapped toaster
rust
legacy b4 blitzen wheels
tacoornot is offline   Reply With Quote
Old 08-21-2013, 08:42 PM   #177
Mach V Dan
Member#: 12029
Originally Posted by willowlee View Post
Can you guys also put the color code for each rim?
Where would you suggest we find this color code?
I don't think I'm going to add those to the list for a couple of reasons. For one, they are extremely rare. I've never seen a set in person outside of Japan. For another, we have no specs.
--Dan
Mach V
FastWRX.com
Old 08-22-2013, 02:21 PM   #178
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
There are color codes for wheels? Beyond BBS Gold most people don't seem too concerned. Either silver or gun metal gray. Not much variety.
Old 08-22-2013, 05:26 PM   #179
sc00by4life
Member#: 97135
Wurth silver laquer matches most OEM silver finishes.
Old 08-22-2013, 05:38 PM   #180
chanomatik
Member#: 159474
SNOSLO
That's good to know! I would like to paint my BRZ wheels to an OEM silver, but was just gonna settle with powder coating them a silver that wasn't too boring, but still OEM-looking.
Old 08-25-2013, 09:49 PM   #181
speedenthusiast1371
Member#: 108140
Thinking of picking up a set of BRZ wheels for my 13 Hatch to use as winter wheels. How much of a spacer do you think I would need to clear the front brakes?
speedenthusiast1371 is offline   Reply With Quote
Old 08-26-2013, 09:45 AM   #182
Mach V Dan
Member#: 12029
They should fit fine on a WRX without a spacer. To fit on an STI they would need a very thick spacer/bolt circle converter.
--Dan
Mach V
Old 08-26-2013, 10:27 AM   #183
speedenthusiast1371
Member#: 108140
Thank you. From what I've read they're a tight fit on the front so I figured 5 millimeter spacer might help but if you don't think I do then I guess I'm OK
Old 08-27-2013, 12:06 AM   #184
jdavis92
Member#: 362070
I understand how the measurements are for wheels are taken.
What I don't understand is how differences in some of the measurements can effect the the fit of the wheel and the driveability of the car.
For example...I found a set of 2007 WRX wheels (offset +55) for sale. I was thinking they would be nice for a winter set of tires for my 2013 Impreza Sport Premium (stock offset +48). Is the difference too much? And could I put the stock 2013 tire size on the 2007 wheels?
Jeff in Flagstaff
jdavis92 is offline   Reply With Quote
Old 08-29-2013, 01:21 PM   #185
Mach V Dan
Member#: 12029
For example...
I don't want this thread to turn into a "Will this wheel fit my car?" thread. Just specs for OEM wheels, please. Please start another thread elsewhere about what fits on what.
--Dan
Mach V
FastWRX.com
Old 09-27-2013, 01:50 PM   #186
FearBoy
Member#: 84529
2013 BRZ Limited
Lightning Red
Not sure if the data is in this thread, but I don't see hub bore on the first few posts. Might want to add that Subaru uses 56.1mm bore. Thanks.
FearBoy is offline   Reply With Quote
Old 09-29-2013, 04:42 PM   #187
Mach V Dan
Member#: 12029
Sigh. Okay. Since they all do, I sort of figured it wasn't an issue. But I will post that.
--Dan
Mach V
FastWRX.com
P.S. Subaru SVX had a 57.1mm centerbore.
Old 10-12-2013, 02:01 AM   #188
J_S_K
Member#: 361671
This wheel is on my 2002 WRX - looks like the first wheel presented in this thread. Is it safe to assume that it's just a gold-colored rim from a 98/99 Impreza? ...also, according to the specs listed in this thread, it looks like this rim is 1/2" wider (it's 7" wide) than the '02-05 WRX rims yet it's the same weight at 16.5 lbs! Can I call this an "upgrade" rim with a clear conscience?
J_S_K is offline   Reply With Quote
Old 10-12-2013, 11:22 AM   #189
sc00by4life
Member#: 97135
Wouldn't really consider it an "upgrade" but yes, those are RS wheels.
Old 10-12-2013, 09:52 PM   #190
CoopaLoop
Member#: 355979
03 Forester XS
Great info, just what I was looking for. Thanks!
CoopaLoop is offline   Reply With Quote
Old 10-12-2013, 10:13 PM   #191
J_S_K
Member#: 361671
Yes, it IS great info -- Thanks Sc00by for your input too!
Old 10-14-2013, 04:24 PM   #192
Mach V Dan
Member#: 12029
Wouldn't really consider it an "upgrade" but yes, those are RS wheels. They clear brembos too.
Brembos? I don't think so. Four-pot Subaru brakes, yes.
--Dan
Mach V
FastWRX.com
Old 10-14-2013, 05:58 PM   #193
sc00by4life
Member#: 97135
--Dan
Mach V
FastWRX.com
Alas, you are correct. I could've swore I saw someone post a pic with those clearing brembos, however at a quick glance it was possible it was RS Zero's.
edited my post .
Old 10-25-2013, 07:35 AM   #194
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
XV wheels are 48 offset, 17x7.
TRSAndrew is offline   Reply With Quote
Old 10-28-2013, 10:07 PM   #195
Mach V Dan
Member#: 12029
Thanks. Updated.
Old 11-03-2013, 10:03 AM   #196
Haven
Member#: 95
2006 Wrx
Crystal Gray
So will the
BBS RK (Optional for Saab 9-2X, WRX)
Offset: +48
Fit an '06 wrx without problems?
Haven is offline   Reply With Quote
Old 11-11-2013, 02:30 PM   #197
Mach V Dan
Member#: 12029
Originally Posted by haven View Post
So will the
Offset: +48
I don't think so. This post indicates no.
--Dan
Mach V
FastWRX.com
Old 11-19-2013, 10:49 PM   #198
CT05Legacy
Member#: 130091
2005 LGT Wagon
Are all the 2011+ WRX wheels the same finish?
CT05Legacy is offline   Reply With Quote
Old 11-20-2013, 09:40 AM   #199
matigas_TT
Member#: 322775
2012 WRX-4Dr
Except the orange limited wrx/sti
matigas_TT is offline   Reply With Quote
Old 11-20-2013, 02:30 PM   #200
nepbug
Member#: 328631
2008 FXT
2002-04 Impreza
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 205/55R16
I've got one of these wheels bare right now. I weighed it and it comes in at 16.5 lbs.
nepbug is offline   Reply With Quote
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
