Closed Thread
Old 09-29-2013, 10:29 PM   #1
nshipman12
Member#: 369496
04 Subaru WRX
Green
Default Grinding Noise in Cylinder head
Ive search many threads and made many calls for advice on my problem, but no help so far. These are exact details of this mysterious noise in my 04 WRX.
I drove to a friends, and halfway installed a TT, since I didn't have the harness yet all I did was mount it and hooked up the grounds to the frame and the handbrake. I got in the car a few hours later and the steering wheel was jerking in unison with a belt squeek, and the starter was not disengaging(i think) from the flywheel when i crank it up. So I drove it around to check the steering and I heard a quiet grinding/ticking noise coming from the drivers side under the dash that sped up with rpms but still remained when the car was in neutral or the clutch pushed in. I drove it home.
I checked all fluids besides differential cause I dont know how, but oil(a little low, but ok), tranny and power steering are good. I checked for anything loose and it seems fine. Then I started the car, got underneath, and listened for the noise, which Im almost positive is coming from the driver side cylinder head(kinda hard to tell with the loud exhaust). I even listened to the passenger side and it sounds different than the drivers side. The car is stock besides HKS downpipe and STI uppipe
The confusing part is that the car drives fine, no loss of power, smoke out of the exhaust ect. Im not a master mechanic, but I have done a motor rebuild before and Im not a complete idiot, but completely new to Subaru's. Im stumped on what to do.
My question is if there is any other way of diagnosing the problem, what is it, and if not, how screwed am I??
thanks for the feedback
nshipman12 is offline
Old 10-04-2013, 01:22 AM   #2
nshipman12
Member#: 369496
04 Subaru WRX
Green
bump...anyone?
Closed Thread
