Old 08-31-2013, 01:51 PM   #1276
matthewilliams83
Member#: 354857
08 wrx prem sedan
black
To:gsrcrxsi,
Thanks, yeah rubbing is my concern and i figured that's why i haven't seen any yet. 1cm 5mm just doesn't seem like it would make that much difference.
matthewilliams83 is offline   Reply With Quote
Old 09-03-2013, 10:29 AM   #1277
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
You can't just say blanket '45s', that doesn't tell you direct sidewall height. It tells you sidewall height as a ratio based on tire width.
You could probably fit 225/45 18's, but that is going to be pretty extreme. And silly (IMO)
I know a guy who has 245/40R18's on his widebody and they fit (with a +45 wheels) but it's pretty extreme on tire height. And about 5mm shorter then a 225/45R18.
Not to sound mean, but if you are bending rims on a 225/45R17 (215/50?) setup... It's not the tires fault, imo..
Breezio is offline   Reply With Quote
Old 09-03-2013, 07:13 PM   #1278
matthewilliams83
Member#: 354857
08 wrx prem sedan
black
It was a 205/50R17 Stock rim and tire. Yeah deep yet narrow pot hole on a back road filled to the rim with water, and it was night so it was impossible to see. but the rim was able to be fixed.
Ahh, thanks, did some reading into what you meant by ratio... Was thinking that the second # was just the side wall measurement. (seems like that would be much simpler)
The Rims I picked up are 18x8 with a + 40. They currently have (Very worn) 225/40R18 and just seem alittle thin. Our roads suck over here in PA and NJ I'm Stock suspension at the moment but my struts are jello so lowering is gonna happen in the near future. With my new knowledge it looks like 235/40R18 might be my best bet. Not sure 245/40R18s would work on an 8" rim? Suggestions?
Old 09-04-2013, 12:39 AM   #1279
Breezio
Member#: 234357
2009 WRX
245/40 will fit on the 18x8 wheel. but I wouldn't recomend it at all. And it'd likely rub on your vehicle also.
I currently run a 235/40 on a 18x8 (+45) and love it. It's definatly thinner (shorter) on the sidewall then what you are used to. But nothing dangerous, except for massive potholes covered with water...
Old 09-06-2013, 11:15 AM   #1280
MRAU
Member#: 343045
2009 wrx
Enkei RPF01 SBC
18x9.5 +38
235/40/18 Achilles sport
Lowered on epic engineering spring
Rear fenders rolled
Would like to get coilovers and white Work xd9's next.
MRAU is offline   Reply With Quote
Old 09-18-2013, 01:35 PM   #1281
wrxmyers
Member#: 50484
2015 SUBARU WRX
Ice Silver
lmk and ill buy the enkeis from you
wrxmyers is offline   Reply With Quote
Old 09-18-2013, 02:25 PM   #1282
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Originally Posted by MRAU View Post
2009 wrx
Enkei RPF01 SBC
18x9.5 +38
Rear fenders rolled
Nooooooooooo!! Keep the enkeis!! Work xd9 are soooooo heavy and already been done!! The rpfs are beautiful!!
Let's Spool is offline   Reply With Quote
Old 09-23-2013, 01:14 PM   #1283
sowrxy
Member#: 323050
09 wrx
SSM
sowrxy is offline   Reply With Quote
Old 09-25-2013, 04:43 AM   #1284
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
I hit one such pothole and blew out a tire (235/40/18 Conti DWS), Rota Gravel survived unscathed. I went back to a 245/40 for more sidewall (pilot supersports). I'm on 18x8.5 +44. I'm rolled and pulled with -2 front camber with a modest drop. No issues now. Did not clear stock!
Vanderkitten is offline   Reply With Quote
Old 09-26-2013, 11:09 AM   #1285
crzyasian
Member#: 138631
2010 WRX hatch
dying to put on my wheels(enkei nt03 18x9.5 +40) and having to wait for funds to be available is the worst. just gotta decide on what tire size to go with that wont require extensive modification to the fenders. debating on either 245/35 or 255/35.
crzyasian is offline   Reply With Quote
Old 09-26-2013, 12:46 PM   #1286
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Both will require a roll and possibly a slight pull especially if your lowering car... I have those exact wheels and w/ 245/35 and I had to roll and slight pull all 4 fenders
Old 09-26-2013, 12:51 PM   #1287
crzyasian
Member#: 138631
2010 WRX hatch
gotcha. yea im plannin on gettin coilovers here shortly and gettin them on before mounting my wheels to the car. prob going to just install it as is out of the box or lower it a tad depending on fender to wheel gap.
are the tires stretched at all with the 245 size tires?
Old 09-26-2013, 02:59 PM   #1288
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
^^ Yea, just a tad... nothing too crazy... I dont have any great pics of it:
Fender's slight pull in front
Old 09-26-2013, 06:22 PM   #1289
crzyasian
Member#: 138631
2010 WRX hatch
thats good enough for me! thanks for the pics! did u have to get rear lower control arms to get enough camber out of the rears to get em to fit?
Old 09-26-2013, 08:08 PM   #1290
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
^^ Nope, no LCAs required for fitment
Old 09-28-2013, 09:29 AM   #1291
ortag49
Member#: 206899
2009 wrx
pearl white
Can someone tell me if I'm going to have fitment issues with this setup. Im lowered on h&r springs with koni adjustables 1.4" in the rear and 1.3" in the front, 18x8 with 48mm offset rim. I want to mount a 245/40/18 on there. Will I have rubbing issues? I'm currently running a 225/40/18 on my car with no issues. Will the 245 work?
ortag49 is offline   Reply With Quote
Old 09-28-2013, 12:43 PM   #1292
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
IIRC, the 245 will work however you may have to roll the rears a little or deal with slight rubbing on large bumps and hard cornering ... I believe if you go with a 235 you'll be fine with no issues
Old 09-28-2013, 02:30 PM   #1293
ortag49
Member#: 206899
2009 wrx
pearl white
I got the 245s at a killer deal...so I'd like to make them work if I can......
Old 09-28-2013, 02:34 PM   #1294
insane_one
Member#: 301431
2005 Evolution VIII
Anyone here running a 17x8 +35 or 17x9 +35??
insane_one is offline   Reply With Quote
Old 09-28-2013, 11:26 PM   #1295
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Any amount of work and you can make em work.
It's a big ass tire though.
I'd say a roll if needed but it is a high offset 8" wheel so you could be fine.
Rolling isn't a big deal if done properly.
colin1234567 is offline   Reply With Quote
Old 09-30-2013, 10:38 AM   #1296
Breezio
Member#: 234357
2009 WRX
Inner clearance could be a concern with a +48 and 245's, but I'm guessing a bit.
Old 10-05-2013, 02:06 PM   #1297
tunga
Member#: 370119
Planning to go 18x8.5 +38 with Work Emotion Kiwami's and I was wondering if anyone had a similar set up along with suspension etc. If not would anyone know if this would work without any fender modifcations?
tunga is offline   Reply With Quote
Old 10-05-2013, 09:50 PM   #1298
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Similar fitment to a 9" wheel with +44 offset (which I have). You'll likely have to roll the rears slightly to avoid rubbing.
That's assuming you run a 245 width tire (which would fit perfectly on that wheel size)
Old 10-06-2013, 04:36 AM   #1299
tunga
Member#: 370119
Do you have any pictures of your setup? Does it poke?
EDIT
Sorry for all the questions this is my first car and legit all I've done so far is read things about my car on forums and what I could do to it.
I was planning on running BC coilovers and was wondering if the fitment would be flush or would it be too low with the wheel size?
Old 10-06-2013, 05:23 PM   #1300
09wrbrex
Member#: 350382
2009 WRX
Anybody have experience with the xxr527 wheels? I can only seem to find them in 17x8.25 with a 35 offset. I don't want to have to roll or pull any fenders but I really like the look and price of them. I'm just unsure because of how low the offset is. I'm on stock suspension too btw. 09 wrx
09wrbrex is offline   Reply With Quote
