North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 09-30-2013, 02:00 AM   #5376
buzznickle45
Member#: 331206
12 Impreza WRX
Originally Posted by BigTaco425 View Post
+1 on the KW V1's. I love mine. Your car has the perfect stance now!
Thank you, yup nice were I sorta want it, once I get my wheels I'll tuck I in a bit more
buzznickle45 is offline   Reply With Quote
Old 09-30-2013, 11:06 AM   #5377
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Paid a detail guy to get the melted blue crayon out of the rear seat fabric....
And he did a damn good job.
Breezio is offline   Reply With Quote
Old 09-30-2013, 04:47 PM   #5378
mistercj
Member#: 335196
2013 WRX
WRBlue
I used to have KW V2 on my old car and curious how these feel with our cars. Would love to go on a ride along if you guys are willing. PM me if interested.
mistercj is offline   Reply With Quote
Old 10-01-2013, 04:06 PM   #5379
37mm
Member#: 365078
2013 Impreza WRX
Question
Finally had time to bake and black my headlights! I also debadged the front grill since the bumper was already taken off during the project.
37mm is offline   Reply With Quote
Old 10-02-2013, 04:16 PM   #5380
gmhl10
Member#: 158695
2013 GVB STi
World Rally Blue
Just picked up a turboback from Nameless Performance today.
This completes the rest of the parts I was waiting for. Now to find the time to install it.
Beautiful pieces! Great guys! Thanks!
gmhl10 is offline   Reply With Quote
Old 10-02-2013, 09:19 PM   #5381
Metalhead19d
Member#: 347698
2005 Impreza WRX STi
I drove it ^_^
Metalhead19d is offline   Reply With Quote
Old 10-02-2013, 10:43 PM   #5382
HomerTwiggs
Member#: 369460
Metallic Silver
Default I know, I know
I tried (and failed) putting on carbon fiber wrap on my roof.... one wrinkle can ruin the whole project.
HomerTwiggs is offline   Reply With Quote
Old 10-02-2013, 10:53 PM   #5383
I'mFineW/Slow
Member#: 260395
2004 Impreza 2.5 RS
Hardest thing I've ever done on my car (granted, I haven't done anything too crazy).
You simply can't do it by yourself. It took my dad and I forever and the corners still aren't great after forcing everywhere else to work.
I'mFineW/Slow is offline   Reply With Quote
Old 10-03-2013, 12:17 AM   #5384
djpast
Member#: 31016
2016 Focus RS (blue)
2005 WRX Wagon (white)
Tip from someone who used to tint. Spray the sticky side with water generously, and the surface too (after being cleaned). Apply wet. Line up the wrap. It should be pretty easy to move because the water is temporarily preventing the adhesive to stick. After you have it lined up and made sure its where you want it, use a squegee and slowly start smoothing out the vinyl. The water will start to come out. You may need to guide some of the bubbles out. If there isnt a protective cover on the top of the vinyl, you may want to use some of the vinyl backing paper you peeled away while doing this, depending on the type of vinyl you used to add additional protection but if you use a pretty soft squeegee it shouldn't make a different, but better safe than sorry.
djpast is offline   Reply With Quote
Old 10-03-2013, 12:22 AM   #5385
Clutch Dog
Member#: 258967
2007 Charger R/T
Real Steel
Friend of mine mentioned using a light mixture of soap with said water. if on a hot day the sun causes the water to evap faster.
I failed horribly at this too. dried too fast and i was by myself.
Clutch Dog is offline   Reply With Quote
Old 10-03-2013, 12:31 AM   #5386
Laxman45
Member#: 342950
2005 WRX
CGM
Red tail light overlays. They should have come red from the factory!!!
newer hatch?
Laxman45 is offline   Reply With Quote
Old 10-03-2013, 01:22 AM   #5387
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
BREWPUBEAVER is offline   Reply With Quote
Old 10-03-2013, 09:49 AM   #5388
hillsboro
Member#: 84823
14 Evo
00 Outback
Originally Posted by BREWPUBEAVER View Post
Nice work! Can't wait to check it out.
hillsboro is offline   Reply With Quote
Old 10-03-2013, 10:17 AM   #5389
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
Looks awesome!
mw1484 is offline   Reply With Quote
Old 10-03-2013, 02:12 PM   #5390
Subarutex
Member#: 24241
Hey Guys...
There are certain instances where using a wet application method works, and there are others where it is one of the worst ideas you could do.
Wrap vinyl (3m 1080, Avery Supreme wrapping film, Oracal) all have 2 distinct technologies that water does not work well with.
The 1st is air egress tech. This is micro air channels in the adhesive that allow air to escape as you are squeegeeing the vinyl down. This helps prevent bubbles and wrinkles.
The 2nd is a repositionable tech. What this does is it keeps adhesive elevated above the surface, preventing full tack / adhesion. Every manufacturer does it slightly different, but its usually microscopic beads. This allows you to pick up and move/slide/work the vinyl on the surface. When you squeegee, the microscopic beads are pressed into the adhesive, and this starts the adhesives final bonding process.
You can recognize air egress technology by looking at the backing paper (wax paper) of your vinyl. If you can tell any sort of texture, it is an air egress film.
When doing a wet install with a film designed with air egress technology, it actually will TRAP the water in the tiny air channels in the adhesive.
Worse than that, water will prevent the microbeads from pressing into the adhesive. So, even after the water evaporates out (as long as a couple of weeks), the adhesive in those locations will not have a bond with your surface. Which basically means your wrap will not be held on by more than a few places, and will fail far quicker. That is, if you can even get it to stick at all.
Wrap vinyl (especially the carbon and chromes) is expensive... Don't waste money and time. Avoid Water!
If you're wrap vinyl doesn't have a textured backing paper, it probably isn't fully wrappable vinyl. This probably means you have some form of lesser vinyl meant for other applications (flat windows, plastic signs, etc...). While you can probably get it installed, its going to be a bad time. It will not stretch very much, the adhesive won't be as forgiving, and it will not have the same UV protection and will break down faster.
Subarutex is offline   Reply With Quote
Old 10-03-2013, 07:23 PM   #5391
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Put on some gorilla mud flaps. Way better than previous rally armors I had in strength.
Subie_Noob_Brian is offline   Reply With Quote
Old 10-04-2013, 10:59 AM   #5392
Breezio
Member#: 234357
2009 WRX
Looks good.
Did you have the UR's? If so, they are supposed to be 'weak' IE: very flexible in order to not break from impacts. Super stiff (strong..?) flaps can break easily when they hit the ground or have a large impact thrown from the tire.
I know nothing about the gorilla flaps, so I'm not saying anything about them specifically.
Old 10-04-2013, 05:30 PM   #5393
loveNWlife
Member#: 353053
2003 WRX Wagon
Platinum Silver Metallic
Subie_Noob_Brian, your XV is perfect. Absolutely love it!
I finally got around to finishing my light bar! Just need a new Hella and some OEM fogs!
loveNWlife is offline   Reply With Quote
Old 10-04-2013, 07:05 PM   #5394
Subie_Noob_Brian
Member#: 288037
Originally Posted by Breezio View Post
Looks good. Did you have the UR's? If so, they are supposed to be 'weak' IE: very flexible in order to not break from impacts. Super stiff (strong..?) flaps can break easily when they hit the ground or have a large impact thrown from the tire. I know nothing about the gorilla flaps, so I'm not saying anything about them specifically.
My issue was with the mounting hardware and brackets. Just not a good system. The gorillas are firm but not thin plastic they will break. They are thick and do fold/bend with pressure.
Thanks lovenwlife!
Old 10-04-2013, 07:25 PM   #5395
NWsoobie
Member#: 289516
2012 WRX
ISM
Installed an FXT engine cover today. Thanks to eugeneutopia. It makes the engine bay look so much cleaner in my opinion.
NWsoobie is offline   Reply With Quote
Old 10-05-2013, 08:47 AM   #5396
wraven
Member#: 17757
2011 STI Sedan stg 2
WR Blue Mica
Default COBB Intake w/Air Box, Perrin Cat-Back, etc.
Just catching up... August-September 2013:
Installed the COBB SF Intake w/Air Box, Perrin Cat-Back Exhaust. Have COBB downpipe and stainless Heat Shield yet to install, and then AP flash to Stage 2. Sounds great, feels great.
Road trip to Utah to swap a WRX owner his wingless trunk lid for my STI whale tail. We're both happy now. My wife says the STI looks like it's owned by a mature adult now.
You can check out my photos on my FaceBook page under the album "Cars and Car Events"
Darrel Fleischman
wraven is offline   Reply With Quote
Old 10-05-2013, 01:27 PM   #5397
Hebidoshi
Member#: 355680
97 GF8/92 cressida
I replaced one of the plugs for my headlights, and this is what it looked liked...
Hebidoshi is offline   Reply With Quote
Old 10-06-2013, 08:52 PM   #5398
Rodin5
Member#: 358173
2013 WRX
Tangerine Orange Pearl
LatheWerks Hybrid Piston and 5" extension.
Rodin5 is offline   Reply With Quote
Old 10-07-2013, 11:15 PM   #5399
Breezio
Member#: 234357
2009 WRX
I fully understand. I've made modifications to mine and replaced a couple washers that disappeared...
Old 10-07-2013, 11:56 PM   #5400
TCh
Member#: 347639
2004 STI
Looks good! Make it yourself?
TCh is offline   Reply With Quote
What did you do to your Subie Today? Version 3 TrickNipple North West Impreza Club Forum -- NWIC 3796 09-07-2011 02:52 AM
What did you do to your Subie Today? Version 2 Smoke North West Impreza Club Forum -- NWIC 1978 05-21-2010 12:43 AM
What did you do to your Suby today? BREWPUBEAVER North West Impreza Club Forum -- NWIC 1197 11-01-2009 12:06 PM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
