Old 09-20-2013, 06:58 PM   #1
DrSnazzy
Member#: 368848
Default Delete
Delete
DrSnazzy is offline   Reply With Quote
Old 09-20-2013, 07:00 PM   #2
DrSnazzy
Member#: 368848
I have a subi nut buddy that i will probably pay to help, or just pay to do the work for me.
Old 09-20-2013, 07:21 PM   #3
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Look at spending a few thousand just to get it running properly.. Then it skyrockets from there.. And regarding buying a motor get it from a REPUTABLE source otherwise you might get shafted with another blown motor
Dat8687 is offline   Reply With Quote
Old 09-20-2013, 07:27 PM   #4
DrSnazzy
Member#: 368848
Like where? What parts should i buy or will i need? like i said. Totally clueless. Not my knowledgeable platform lol
Old 09-20-2013, 07:37 PM   #5
rdieder
Member#: 257818
2007 STi
CGM
you'll need minimally headgaskets, timing belt, timing belt pullleys, bearings and a new/good condition rod. with that milage, you'd probably ask a machine shop to press in new valve guides and inspect/replace any bad or going exhaust valves. Then the cost of having the heads and block decked for straightness.
Another option is to get a 2.1 stroker kit while you're all apart
rdieder is offline   Reply With Quote
Old 09-20-2013, 07:43 PM   #6
DrSnazzy
Member#: 368848
So would it be worth it just just buy a low mile 50 or 60k motor? and drop it in. I dont have a car now so the sooner i can get it running perfect the better.
Old 09-21-2013, 07:22 AM   #7
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
fill out you profile so we know where you are from and then can possibly advise on a shop to go to. Maxwell Power sells built short blocks for $3800 too or Subaru sells them for about $2000
shamrock 05 is offline   Reply With Quote
Old 09-21-2013, 09:04 PM   #8
DrSnazzy
Member#: 368848
There man sorry!
Old 09-21-2013, 09:15 PM   #9
DrSnazzy
Member#: 368848
and i do have future plans for this car, hopefully 500whp at one point. But in the next couple years working up to 350 or so? just keep that in mind when recommending parts. Im trying to soak all this new motor stuff up here lol
Old 09-22-2013, 12:31 PM   #10
DrSnazzy
Member#: 368848
Goodmorning bump! The faster i can be pointed in the right direction the faster i can have a car lol. This will be my DD
Old 09-22-2013, 01:36 PM   #11
riderdude125
Member#: 183476
2005 LegoTransformer
pm'ed you good sir!
riderdude125 is offline   Reply With Quote
Old 09-23-2013, 07:27 AM   #12
shamrock 05
Member#: 120057
A few good shops are located in the SE Mich area too.
Old 09-23-2013, 07:46 AM   #13
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
This will be my DD
Spenk is offline   Reply With Quote
Old 09-23-2013, 08:05 AM   #14
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 18G 6sp RA
Swap in a ver 8 ej207 motor, simple stage 2 bolt on mods will get you around 300 whp, be happy. You'll still burn between $4,000 - $5,000
D-Rodman is online now   Reply With Quote
Old 09-26-2013, 02:06 AM   #15
DrSnazzy
Member#: 368848
Decided to go with the 2.0
Old 09-27-2013, 05:31 PM   #16
H_wells3000
Member#: 322035
Ol yeller
i vote 2.5l hybrid with forged internals. way cheaper and DIY with some help, probably less then 2k when its all said and done.
H_wells3000 is offline   Reply With Quote
Old 09-27-2013, 05:44 PM   #17
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Any updates on the rebuild? if you have not pulled the trigger yet, then i'd highly recommend either of these options:
1) US ej255/257 long block. Prior to 3500 RPM, you will gain roughly 60 ft of TQ over the 2.0L, which is a HUGE amount. You can use the 2004-2007 STI, 2006-2009 WRX, Outback XT and Forester motors too. Just go with one that only has AVCS for the intake cams, not dual.
2) JDM version 8 or 9 complete motor. 8500 RPM rev limit, butter smooth operation, need I say more It will surpass just about any built 2.0L option that you can come up with, mainly due to the cylinder heads/cams/turbo.
If the 2004 WRX has high mileage then expect to find the cylinders head cracked from the spark plug holes to the valve seat. Most machine shops will not work on heads if they are in this shape. In which case, you have a built bottom, and then need to buy replacement heads :-/
[email protected]
www.facebook.com/iaperformance
IA Performance is offline   Reply With Quote
Old 09-28-2013, 09:29 PM   #18
DrSnazzy
Member#: 368848
I bought a whole new 2.0 from riderdude on here. building it for me now, DOnt want to mess with tuning, blah blah blah being i dont have a car till this is done.
Old 09-28-2013, 10:08 PM   #19
OldManRed04
Member#: 356635
2005 STI
WR Blue
What fun is it to have a car that you paid somebody to do all the work for you and didn't build yourself? Seems you have prior knowledge, what are you afraid off?
OldManRed04 is offline   Reply With Quote
Old 09-30-2013, 05:58 PM   #20
Kcoupe
Member#: 330651
Next time try and jump on it your self (if you have time). Take pictures before you start
taking things apart. It helps retracing your steps. Do a lot of reading. Like that in the
future you could fix your own car. Oh yeah proper tools also. Look for the whole of DIY's
in this forum. Priceless. Let us know how to goes when you get it back.
Kcoupe is offline   Reply With Quote
Old 09-30-2013, 06:32 PM   #21
DrSnazzy
Member#: 368848
I would love to learn and build the ej20 myself, but i currently do not have a car, or time for problems. Being why i am having someone who has built tons of boxers do mine! Sucks i know :/
Old 10-02-2013, 06:08 PM   #22
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Fir3Fighter is offline   Reply With Quote
