Old 09-27-2013, 10:22 PM   #1
ygtrn
Member#: 312868
Default turbo choice for 400hp
hi...
I have almost finished my setup in a few days, but i'm having reservations abou the turbo choice i've made for my setup...... my target hp 400 on crank (not whp) but the turbo is i want, should spoll up early as it's possible... i think the turbo which i need is 16g big billet, but i concerning about reaching 400hp...
the car is 99 sf5 forester..
specs....
fully forged engine....
+1 supertech ss valves
ported and polished heads, trottle, manifold
8.5 wiseco pistons
headers, uppipe
76mm downpipe and catback
ets 2008+ tmic + 10cm carbonfiber big scoop
cai
650cc injectors
walbro450 lbh
hks fuel pessure regulator
vi-pec plugin ecu
now im using vf22, but i want to change it because its very old turbo...
here is the link of the turbo i thik to buy...
http://www.ebay.com/itm/161104751079...84.m1423.l2648
i waiting for your suggestions....
thanks...
ygtrn is offline   Reply With Quote
Old 09-27-2013, 11:02 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
18g or 20g
Shortpersonbk is offline   Reply With Quote
Old 09-27-2013, 11:15 PM   #3
R6_rider
Member#: 138768
2013 evo x
white
never heard of arashi...
also what do you have for trans?
R6_rider is offline   Reply With Quote
Old 09-27-2013, 11:27 PM   #4
Red_Wrx
Member#: 158658
Originally Posted by Shortpersonbk View Post
18g or 20g
Yea if you wanna pull timing, depends on what you want to do. 400 with a small enough turbo. Or a big enough turbo for top speed and pwr? Gt30
Red_Wrx is offline   Reply With Quote
Old 09-27-2013, 11:45 PM   #5
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
One from a Cummins ISX LOL
2011WRXMT is offline   Reply With Quote
Old 09-28-2013, 04:10 AM   #6
ygtrn
Member#: 312868
stoc trans, but ill change it...
Old 09-28-2013, 04:27 AM   #7
ygtrn
Member#: 312868
by the way the car is euro type forester, there would be diffrence about the cams...
i want a turbo which can catch the efficient point of the cams...
previously i was using td04 turbo and the acceleration was (0-100) 5.8 second and i take 270hp with it (@1.2 bar, my older specs was turbo, wrx cooler, oem ecu, exhaust)
later i changed only the turbo with the vf35, i loose that 5.8 sec and its decline to about 7sec and i take no more power @top ands @ same boost...
i want to say, if its possible i want a turbo which is spolling like td04 and give me abot 400hp.
Old 09-28-2013, 04:53 AM   #8
Ihaveawagon
Member#: 366807
Took me a second to realize it was 100kmh.
Ihaveawagon is offline   Reply With Quote
Old 09-28-2013, 05:37 AM   #9
ygtrn
Member#: 312868
yes its kmh
here is a video...
and here is the dyno... (td04, wrx cooler 1.2 bar)
Old 09-28-2013, 05:39 PM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
400 chp with 5 speed is ~310 at the wheels with drivetrain loss.
i'm a that power with vf30 @ 18 psi with water / meth.
16g billet would get you there and probably spool faster than my vf30
Old 09-30-2013, 07:40 PM   #11
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Dont buy the asrashi junk.
Check out the Steamspeed groupbuy thread or the one in built motor section.
dingobite is offline   Reply With Quote
Old 09-30-2013, 07:42 PM   #12
dingobite
Member#: 82391
08 OBP Sti
Does not ship to United States If anyone missed this part.
Old 10-02-2013, 10:09 AM   #13
ygtrn
Member#: 312868
one more question... is that turbo has billet comp wheel or not? there is no information about it...
http://www.bptstore.com/Subaru-WRXST...er-_p_126.html
Old 10-02-2013, 10:11 AM   #14
ilovedemhotrides
Member#: 326147
Fp red or green
ilovedemhotrides is offline   Reply With Quote
