Welcome to the North American Subaru Impreza Owners Club Wednesday November 26, 2014
Old 09-28-2013, 10:21 PM   #1
Samiam1017
Member#: 334068
Default Installing 06wrx avcs heads on an 05 Wrx
I want to install 06 Wrx singls avcs heads onto an 05 Wrx. I've done a lot of searching but most turn up results for 207 swaps. I want the avcs to work and know I need a Jdm ecu. But I'm not sure of the correct version? Also the cam position sensors are different and use a different plug (avcs heads have three wires as opposed to two) whats the fix for this as I am using the 05 engine harrness? Thx
Samiam1017 is offline   Reply With Quote
Old 09-29-2013, 08:39 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
I think there is a problem with the bore size/ the heads bore is too big for a 2.0.if you wanat avcs, you gotta do the jdm heads
Old 09-30-2013, 09:56 PM   #3
Samiam1017
Member#: 334068
It's accually a 257 sti short block. I posted in the wrong area. But I want to use all the 2.0 05 Wrx stuff on the new long lock and make the avcs work
Old 10-01-2013, 12:36 AM   #4
shredboostnburn420
Member#: 277436
2005 Impreza WRX STI
It will work fine. depending on what cams you go with the avcs will have to be plugged in the cams if using sti cams. and your solid wrx cam gears used. you might need to buy a cam sensor bracket for the front pickup. If you want to use avcs look into a stand alone or sti ecu/engine harness swap.
shredboostnburn420 is offline   Reply With Quote
