Old 10-01-2013, 10:08 PM   #1
born2perform
Member#: 267616
Default Low Profile Winter Tires
Hello
I planning on buying some low profile winter tires (225/40/18). Any people with previous experience with them?
I understand about going to a narrower size for grip in the snow but I spend about 80% of the winter on clear road. Do the low profile tire offset that much grip in the snow that I would even need to consider going to a narrower width?
born2perform is offline   Reply With Quote
Old 10-01-2013, 10:40 PM   #2
krzyss
Member#: 8365
2013 Ford Focus SE
I had 225/45R17 and they did fine (Continental TS810).
However 18" winter tires are quite expensive.
Krzys
Old 10-01-2013, 10:59 PM   #3
JonnyV2889
Member#: 197384
2006 WRX Ltd
There will be greater chance of smacking a wheel if you're on bumpy/pot hole roads. And you will be bent over, otherwise not a crazy huge difference, a bit less contour/squishy.
JonnyV2889 is offline   Reply With Quote
