Old 10-02-2013, 04:37 PM   #326
jm020
Member#: 353194
2013 WRX Limited
ISM
Thanks for the advice! I'd upload a pic so you could see it, but couldn't figure out how. Hopefully i'll have some "after" pics that look much better! How's beaufort?! Had a buddy in high school who had a house down there...fun place!
jm020 is offline   Reply With Quote
Old 10-03-2013, 06:03 AM   #327
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
I really like Beaufort though I'm currently in Afghanistan. I can't wait to go back.
Brown Ops is offline   Reply With Quote
Old 12-24-2013, 03:05 AM   #328
SteveDeChello
Member#: 376876
Default Re: Auto Body/Paint Question and Answers
Originally Posted by MattTHEpainter View Post
Supply List:
*1 quart body filler with activator (preferably rage gold or comparable product)
*Tube of glazing putty/"icing"
*Assortment of sand paper starting at 40 grit ranging to 400 (40,80,180,220,320,400)
*High build primer
*Sanding block
*DA sander (not necessary but will make job much easier)
*Filler Spreaders
Instructions:
I do not know if you have any prior knowledge when it comes to bodywork so I can only give you guidance and getting it "perfect" depends on the time you take and practice.
1. Were the welds ground flush? If so there is most likely some slight distortion in the metal. Try to get the metal as flush as possible prior to filling. Use a body hammer, or stud welder to do so. If the metal has any low spots that cannot be worked out, sand about a 5" diameter circle from the center of the welds to give you ample room to work. Sand with 80 grit on a DA. Any spot that you will be filling you want bare metal for the filler to adhere to. Do not heat the panel too much with the DA.
2. Mix the filler on a piece of sheet metal or cardboard. A good rule of thumb is put the amount of filler down, and then draw a line across the puddle with activator. Depending on conditions this could vary. Use a spreader to put down only as much filler that is needed over the holes. Let harden, and then begin to sand with 80 grit sandpaper on a block. Sand in a diagonal pattern // then \\ crisscrossing and creating an imaginary "X" over the work area. Do this until you level the filler with the surrounding metal. This will take some practice to get correct. A helpful trick is to apply a guide coat of black spray paint to see if there is any low spots or high spots in the filler.
3. Continue this process of applying filler and then smoothing, and after every coat go to a higher grade sandpaper. For such a small job like this you may only need one coat of filler before glaze. You could start with 180 grit depending on the condition of the metal after the welding.
4. Stop when you feel, with your hand, that the surface is level with the surrounding area and there is no bumps, or dimples. You will finish the filler with 400 grit before applying the glaze. Glaze is basically used to fill any fine scratches still left in the surrounding metal from sanding, or pin-holes that are in the filler. You will apply this extremely thin over the filler with a decent amount of pressure to fill any imperfections.
5. Let the glaze dry and sand with the same process as before, but not so much that you start to take off material from the filler below. You will see the glaze fill the scratches and pin-holes.
6. After this work you will get a good feel for sanding and should feather out the existing paint surrounding your area of repair. Use 400 to scuff existing paint.
7. Mask up for high build primer by back taping your work area and covering anything you do not wish to get primer on. Never apply primer to the edge of the tape or you will get a "hard edge".
8. Let primer dry and wet sand with 400/600 grit paper.
9. Send it to paint.
If you have any specific questions about this process (which I'm sure you will) just ask.
Where in NE are you located?
-Matt
Thanks a lot for your Guidance .They are really helpful in my work.I am owner of Marlow auto body shop.We offer a wide range of a offers wide range of auto body services including collision repair, car painting, body work, dent removal, hail repair, scratch removal, custom painting, etc. And i really appreciate these type of forums that help me in my work
SteveDeChello is offline   Reply With Quote
Old 01-28-2014, 11:21 PM   #329
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
Do all panels need to be blended in? I understand metallics need to, But do solids? I'm asking because my WRX is San Remo Red. I want to redo the bumper and maybe hood. I've painted some small items here and there and have experience with wet sanding and polishing. Also where is a good place to get color coded paint? Can I order some offline from the automotive touchup site? Any info would be greatly appreciated! Thanks!
mr.nicknasty8 is offline   Reply With Quote
Old 02-02-2014, 11:37 PM   #330
braydeno
Member#: 301547
2006 Subaru STi
Yes! you need to blend to get a good match. You will just need less blending space if it's not a metallic. Go to your local auto body supply store with your code and find your variant with chips. I suggest PPG's Deltron line or Auto Color for the best coverage and match.
braydeno is offline   Reply With Quote
Old 02-25-2014, 12:14 PM   #331
sciroccodotalex
Member#: 379114
2005 WRX
Can this be saved?
[url=http://s120.photobucket.com/user/sciroccodotalex/media/CAM00432_zps836b2be3.jpg.html][/
More importantly, can the roof be saved?
And what should i do to prevent fading from happening again and on the body?
Thanks.
sciroccodotalex is offline   Reply With Quote
Old 02-25-2014, 12:46 PM   #332
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
That needs a repaint. Once the clear starts to bleach and fade like that there isn't much you can do. A good up keep on waxing is a good preventative.
Jackie leggs is offline   Reply With Quote
Old 02-25-2014, 12:56 PM   #333
sciroccodotalex
Member#: 379114
2005 WRX
So... i gotta do the whole roof again?
Old 02-25-2014, 01:22 PM   #334
daveS12
Member#: 238079
2009 2.5i impreza
red
Yes sir you do unfortunately
daveS12 is offline   Reply With Quote
Old 02-25-2014, 02:07 PM   #335
sciroccodotalex
Member#: 379114
2005 WRX
Awww ok..
Old 02-25-2014, 02:25 PM   #336
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
The color can be blended out but the whole roof needs re-cleared.
Old 02-26-2014, 10:15 PM   #337
kolten493
Member#: 222633
02 WRX
caged 'n such
in need of some assistance. i have been doing paint and body for about 6 years now and am no stranger to working with different substrates, however i am currently in the process of widebodying my wrx and am having difficulty finding a product i can use to smooth the seams and still offer enough flex to allow for the different expansion rates from the fiberglass to metal. i currently have a 3M panel bonding adhesive that i used to adhere the panels, then came back with a self leveling 2k seam sealer. and then a high build PPG K36. even with sanding the seam sealer and feather edging it out, my seams still have low spots. I have been eyeing UPOL 7601 plastic bumper filler, thinking that it would have enough flex to suit my needs. i have never used this filler before, but have used other plastic repair products and seem to think it would fit my need.
any advice or other product recomendation is appreciated.
pics for reference
kolten493 is offline   Reply With Quote
Old 02-27-2014, 09:11 AM   #338
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
I've used that filler before both on a bumper and fiberglass hood. I have no complaints how it has worked.
What about using a filler primer? I can't think of the stuff I have used in the past that I really liked, it filled amazingly well for something that you spray. The hardener was close to the consistency of molasses. I'll check out the can I have left and get you the name.
That line has to suck to sand.
00camaro16 is offline   Reply With Quote
Old 03-02-2014, 04:29 PM   #339
kolten493
Member#: 222633
02 WRX
caged 'n such
I've thought about using ever coats slick sand or super fill or whatever, but wasn't sure if that would give me enough of a build. I don't want to hose it down too much and have shrinking or scratch swelling issues later. I know ok not really "supposed" to put anything else on top of the seam sealer, but I was just thinking as long as it's still pliable and since the seam sealer was 2k, I'd probly be okay. Thanks for the info on the upol stuff
Old 03-07-2014, 12:49 PM   #340
sciroccodotalex
Member#: 379114
2005 WRX
[quote=sciroccodotalex;41518740]Can this be saved?
quote or whatever...
i want to DIY on this hoodscoop after all. what steps do you guys recommend on this (sandpaper grit, and primer etc...)
i learn better by being told "instructions".
Old 03-07-2014, 12:50 PM   #341
sciroccodotalex
Member#: 379114
2005 WRX
already have the paint for it. just need the prep steps.
Old 03-08-2014, 10:10 PM   #342
toxinwrx
Member#: 251665
2006 WRX
1.Feather edge the flaking clear with 320 grit (da will really come in handy here!) trying to avoid going through the base coat (color) so there won't be any low spots. Keeping the da (or block if doing it by hand) flat will deter low spots.
2. Once all the flaking clear is feathered out and there is no evidence of a line between the base and the old clear, especially to the touch, you are looking good.
3. Hit the entire area well with 600 grit.
4. Blow it off, clean it with wax and grease remover.
5. Paint it.
6. Cross fingers that all is well and no runs.
7. Rejoice in the finished product : )
toxinwrx is offline   Reply With Quote
Old 03-09-2014, 11:17 PM   #343
Nick05sti
Member#: 303290
5. Paint it.
320 grit is a but to rough/overkill IMO. The factory clear is super thin. Just spend some time with 600 grit wet sanding the clear off. 320 can and will leave grit marks that are deep and a PITA to get out. My .02
Nick05sti is offline   Reply With Quote
Old 03-10-2014, 09:19 AM   #344
toxinwrx
Member#: 251665
2006 WRX
That's fine too. I like doing things and getting them done in the least amount of time, that's how we make money in body shops. A lot of shops will paint right over 320 grit sand scratches and that's ok too. 320 grit doesn't leave deep scratches when using a da or really even when you are blocking by hand. Going back over 320 with 600 eliminates 320 scratches and saves a lot of time. Its all about adhesion. The scratches help provide that adhesion, that's why its critical to sand. Wet sanding really isn't necessary in this situation. It will cause more of a mess than its worth. Going thru the clear here isn't a bad thing either because it is flaking off and will continue to do so. You'll want to get rid of a lot of that clear.
Old 05-06-2014, 02:43 PM   #345
alucard7755
Member#: 327664
2012 Impreza WRX
World Rally Pearl Blue
Supply List:
*High build primer
*Sanding block
*Filler Spreaders
Instructions:
-Matt
I was in a minor collision yesterday, and it's got my brain going with some ideas of how to turn this mess into something cool. Could I in theory, use this process to fill in the part behind the license plate molding on the front bumper cover, and then sand down the molding to make a smooth bumper?
The part circled in red is what I want to try and sand down:
My ouchies....
alucard7755 is offline   Reply With Quote
Old 05-08-2014, 11:21 AM   #346
bl0wnb0xerbabiE
Member#: 121722
2006 Impreza WRX tr
Obsidian Black
I have an 06 wrx black obsidian pearl. I have a hookup on a brand new paint job and I was thinking about keeping it the same oem color scheme but bumping up the pearlescent green flake a little bit more than stock to be more apparent. Does anyone know what specific color layer The body shop that is doing the work would need to increase?
bl0wnb0xerbabiE is offline   Reply With Quote
Old 02-26-2015, 01:23 PM   #347
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
I just purchased the front and rear side skirt accents (aero guards, side strakes, whatever you want to call them) and rear bumper lip/splitters for my 06 wagon. I have read up on prep and finishing but I have no clue how much actual paint I will need to do the job. I purchased one 12oz can of color matched paint already, is that enough to properly base coat everything?
Preludicrous is online now   Reply With Quote
Old 03-17-2015, 03:34 PM   #348
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
as my details to the left
<----- indicate: 2004 WRB WRX Wagon... all stock panels.
Rear bumper is an OE Subaru piece that was painted to match.
Minor collision with a medium/moderate impact with a tree, pretty much dead on in the center of the license plate area.
The problem: the Sikkens base/clear paint is peeling/cracking/flaking in big pieces all the way down to the OE bumper itself. So the primer on up is coming off as a piece in 1"-5" by 1"-9" sections. literally peeling it off down to the urethane. there is absolutely no damage, deflection, warpage, etc to the actual urethane bumper.
There is no "spot repairing" the actual final finish. its going to have to be stripped to the urethane, adhesion promoted, primed, sanded, primed/sealed and then base/cleared. I got that... no worries...
Question: What is the safest & fastest way to strip this without gouging the OE urethane, melting the urethane, putting sanding marks in the urethane, etc?
Chemical strip? if so what is the recommended brand & product for an OE urethane bumper?
Sand it with a DA? if so what grit(s) and what about the license plate recess?
Pics later tonight when my wife sends them (I'm out of town for work).
Want to get materials on the way to the house for next weekend, get this thing off the car and get it ready for paint.
thanks!
~Rob
TXwrxWagon is offline   Reply With Quote
Old 03-17-2015, 04:08 PM   #349
TXwrxWagon
Member#: 191557
2004 WRX Wagon
~rob
Old 03-21-2015, 10:42 PM   #350
heinekensti
Member#: 415095
2013 STI HB
Just moved to the Schaumburg IL area. I'm looking to repaint my front bumper. It was previously painted from the previous owner but the color still doesn't match up well. Any recommendations what shop I should go to?
heinekensti is offline   Reply With Quote
