Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 06-13-2003, 05:40 PM   #1
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default What Tranny Can I Use???
I need to find out what kind of tranny case will bolt up to a 2.5 RS. Is the 5mt for the 2.5 the only one that will bolt up? I am going to be using the case (just the bell housing) to make a mounting plate to put my engine on the dyno at work. I need to know if the 2.2 or 1.8 tranny has the same bell housing with the same bolt pattern, so I can get this beast on the dyno. Also, does anyone know where I can find one?(cheap) Please help!!!!!
Tattoo Collector is offline   Reply With Quote
Old 06-13-2003, 06:38 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Pick any tranny that has bolted up to an EJ series motor and it will go right onto your engine. (That basically means anything from ~1990+). Flywheel and clutch will have to be matched to the tranny type though.
Best place to buy one cheap is to have a friend that just did a motor swap. Occasionly, there will be a dirty cheap tranny in the classifieds section by either vendors or private individuals.
-Jon
stimpy is offline   Reply With Quote
Old 06-14-2003, 02:46 AM   #3
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default Awesome....that was a big help
Actually, I don't need to worry about the tranny matching up as far as the internals go. I am just going to take a sawzall and cut the bell housing off just to use it as a mounting plate. Am I correct in assuming that it does not have a removable bell housing? That would be awesome if it did, but I kind of doubt it.
Thanks again for your help.
Nathan
Old 06-14-2003, 04:34 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The tranny is one full case (well two halves split longitudinally).
-Jon
Question About What Tranny Fluid to use in 06 WRX dan1587wrx Transmission (AT/MT) & Driveline 9 06-10-2008 09:46 AM
What manual tranny can be used in a '93 Legacy turbo? TajMan_17 Transmission (AT/MT) & Driveline 9 10-08-2005 11:15 PM
uncle scottys cocktail, what tranny fluid to use? Impr3zy0u Transmission (AT/MT) & Driveline 1 09-08-2005 11:39 PM
What tranny should I use? the spacecowboy Subaru Conversions 8 01-31-2004 09:04 PM
What gearset can I use with my EJ18 tranny? Homemade WRX Transmission (AT/MT) & Driveline 3 07-15-2003 04:43 PM
