Old 10-02-2013, 08:35 PM   #1
AtomicX
Member#: 363197
2013 WRX Base
Plasma Blue Pearl
Default Stage 2 Datalog from Dragway
Hey guys, I did a datalog after a few runs at the dragway. I decided to take a log because I was not hitting target boost anymore. Usually when driving on the highway I hit anywhere from 18.5-19.4. Im struggling just to hit 17 at the track. I also suspect that my tune is garbage.
Car is a 2013 WRX with a Cobb SF Intake, Invidia Divorced catless downpipe and nameless axleback. (Cobb Stage 2 OTS map)
https://docs.google.com/file/d/0B2-e...it?usp=sharing
AtomicX is offline   Reply With Quote
Old 10-03-2013, 07:33 AM   #2
AtomicX
Member#: 363197
2013 WRX Base
Plasma Blue Pearl
Note: Running Stage2 93 Octane Rev 3.12
Old 10-03-2013, 07:36 AM   #3
Robman7835
Member#: 105862
2006 STi
Tune is garbage for sure. You showing multiple knock events, and your DAM is off.
Get a pro tune. I'm dealing with stimikey right now for an e-tune and so far I'm getting great results.
Robman7835 is offline   Reply With Quote
Old 10-03-2013, 08:36 AM   #4
AtomicX
Member#: 363197
2013 WRX Base
Plasma Blue Pearl
Its odd, because the car seems to run alot better on the street then the track
Old 10-03-2013, 09:27 AM   #5
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
You might have a crappy tank of gas...you DAM is off and not constant and your knock levels are high too.
How long ago did you flash it? You didn't just flash it seconds before your run right?
subiebosch is offline   Reply With Quote
Old 10-03-2013, 09:30 AM   #6
AtomicX
Member#: 363197
2013 WRX Base
Plasma Blue Pearl
No its been flashed for a month or so. And my gas was on E.... Gas light on.
After I left the dragway my DAM was at a constant .6
My first 2 times were 12.9 every run after that was a 13.1 - 13.3 (log is from a 13.1 run)
Old 10-03-2013, 11:41 PM   #7
Domain
Member#: 85167
2010 WRX STi
Cobb Stage 2 map is not designed to run with a catless downpipe, its stated clearly in the map notes... so calling the tune garbage seems silly when you aren't following the map notes.
Domain is offline   Reply With Quote
Old 10-04-2013, 02:23 PM   #8
Cobb Tuning
Member#: 4803
The car definitely wasn't happy during that run.
The FBKC at lines 30, 39, and 52 are the result of the hard shift (somewhat common on a drag run). The FLKC at lines 50 - 52 that then drops the DAM is a bit concerning. It's possible that the TMIC was heat soaked from sitting in line. As you got going, the air flow across the TMIC increased and dropped your boosted air temps and the car was more happy. Just a guess at what happened.
You could try stepping down one octane in mapping (93 map -> 91 map or 91 map -> ACN91) or you could try adding a couple gallons of race gas next time you are at the strip as a safety buffer.
Do you have any logs of a 3rd gear pull on the street? I'd be interested to see if the car is still unhappy or if it was just mad at the strip.
- Chris
Old 10-10-2013, 05:39 PM   #9
carobmor02
Member#: 280285
Default sti 06 please help with my log
My first time logging my car i just buy a cobb accessport v3 install stage 2 93 map downpipe catback 3" cobb air intake and mac boost controller 3 port
pull 4th gear
https://docs.google.com/file/d/0B8Ok...it?usp=sharing
carobmor02 is offline   Reply With Quote
Old 10-10-2013, 07:56 PM   #10
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Theres also an option in the ap to reduce timing up to 5degrees to account for bad gas. Drop it a degree or two and watch for the knock events around 5krpm
bluemax189 is online now   Reply With Quote
Old 10-10-2013, 08:08 PM   #11
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
jump to a 91 map and be done
Cefaln452 is offline   Reply With Quote
Old 10-11-2013, 01:06 PM   #12
Cobb Tuning
Member#: 4803
I can't access the log. You need to change the setting on that file to "anyone who has the link can view". Or just post the actual .csv file from the AP in this thread.
If you have an upgraded 3-port boost control solenoid, you need to look into a custom map. That is not a modification that is supported by the Stage2 mapping and will cause your car to radically over boost if it is not tuned for appropriately.
- Chris
Old 10-11-2013, 08:47 PM   #13
carobmor02
Member#: 280285
Default link is fix log
- Chris
thanks i fix the link for the log file advise always welcome
Old 10-12-2013, 12:24 AM   #14
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
pull 4th gear
You might want to invest in a good wideband to verify your AFR's. You may be leaning out up top.
Old 10-12-2013, 01:25 AM   #15
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
22psi....?
Chicago AJ is offline   Reply With Quote
Old 10-14-2013, 01:28 PM   #16
Cobb Tuning
Member#: 4803
Are you running the off-the-shelf Stage2 mapping or do you have a custom tune? The wastegate duty cycles in that log don't quite line up with our Stage2 mapping.
That initial boost spike to 22 psi and timing corrections from 5800 - 6800 RPM are not good. I would not recommend running the car aggressively until you get those issues sorted out.
- Chris
Old 10-14-2013, 04:04 PM   #17
carobmor02
Member#: 280285
- Chris
yes that off map shelf stage 2 93 thanks for the advise
