Old 04-04-2012, 10:24 AM   #476
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
I have installed and tuned for plenty of these solenoids and there is nothing wrong with them. Some people dont have the time or desire to cut and splice wires for a diy. This is a great solution for those people.
Medamullet, If you have a problem with their solenoid, why wouldnt you just send it back to them. Btw, if you solder a wire it looses its flexibility as the solder gets absorbed into it. If too much solder is aborbed into the wire, the wire can break that way.
SubiSam is offline   Reply With Quote
Old 04-04-2012, 11:50 AM   #477
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I agree and completely understand what you are saying. I didn't return the valve because it wasn't worth the $30.00 to me to do so. I had been running it for quite a while before the wires failed. It was easier to throw it in the garbage.
I know I don't need to sell my skills here but honestly I own a shop and tune cars and have build tons of custom parts and have tried new innovative idea. Search some of my build threads if you care.
This is where mine failed. If you have a rubber grommet like the GS then great you aren't using the same solenoid I did. There were exposed wires where they meet the solenoid. It had nothing to do with my workmanship. They started to get brittle and eventually 1 of the legs broke off.
it's fine I don't care at all which solenoid everyone is using and hope it works perfect for you all. I wish you al lthe best of luck.
medamullet is offline   Reply With Quote
Old 04-04-2012, 11:57 AM   #478
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's not a gm solenoid.
why are you in this thread?
Old 04-04-2012, 12:56 PM   #479
sorrowfulkiller
Member#: 170439
I <3 Lamp
Originally Posted by GrimmSpeed
Hey, we are all for DIY...trust me! All of us over here at the shop are DIYers as well. We just wanted to give a simple/full featured plug-n-play option to you guys.
Couple of things to clear up:
1. We've never switched valves. We have always used our customer MAC valve. We have NEVER used the IR valve. (btw, in testing we found the IR valve is not even close to the MAC valve performance-wise)
2. Our MAC valve is not an off-the-shelf valve you can buy. It is similar but we had MAC customize it a bit for us.
Also to reiterate from above...no one is butt hurt here in the DIY vs. GS debate. Two different options for two different people. Completely understandable.
Game on my friends,
Justin Grimm
If you guys get Mac to make some 4 port solenoids for us using external wastegates that would sway me into buying one of your solenoids. That's the only reason I didn't buy one.
sorrowfulkiller is offline   Reply With Quote
Old 04-05-2012, 10:22 AM   #480
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
No **** it's not a GM solenoid....
I was showing with a Grimmspeed picture where on the GM solenoid mine failed. Grimmspeed obviously knew there was a problem with the design and added a rubber grommet where the wires went into the solenoid. I have heard GM started putting that grommet on some of their solenoids since but I haven't seen any to verify if this is true or not
Old 04-05-2012, 10:36 AM   #481
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ummm...
gm doesn't put the grommet on their solenoids because their solenoids don't have wires.
Old 04-10-2012, 12:36 AM   #482
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya I have nothing against the GS unit. It is obvious that a plug and play unit was missing on our market, and it is a great solution. All I was saying is that a DIY thread turned into a "buy plug and play for 4x as much" thread, so I posted a good alternative for those of us who are making realistic wages, going to college, or just plain cheap
Old 05-04-2012, 08:57 PM   #483
Antonio09
Member#: 319142
Originally Posted by Sharky NRK View Post
well I have had the profec installed for a long time and it works flawlessly, but if it is not too much trouble to adjust the map for a cheaper gm soleniod setup and use the utec to control boost (previously used unichip base map and profec b to adjust boost) I will sell the profec b
In terms of this, I must go with your opinion, because all the others does not seems to match.
Antonio09 is offline   Reply With Quote
Old 05-30-2012, 12:54 AM   #484
penguin707
Member#: 321691
2003 wrx 4 door
white and black
Can you post more close up pic's of your motor. mostly vacuum line connections and around the intercooler and front around radiator . PLEASE THANKYOU
penguin707 is offline   Reply With Quote
Old 09-12-2012, 01:02 PM   #485
skets
Member#: 170698
2003 WRX V-Limited
Is there anything apart from the WGDC table that I should check when I install the 3-port? I ask because I am looking to tune my car myself (already bought the tactrix cable and a wide band), but my car is overboosting so I think I need to change the boost controller.
I'm waiting for parts to arrive but I would like to know what to look out for so I don't kill my engine.
skets is offline   Reply With Quote
Old 09-12-2012, 05:22 PM   #486
SubiSam
Member#: 156401
'03 WRB WAGON
What are your mods? Assuming you are stock, take a look at your vaccuum lines going to your wastegate.
Old 09-12-2012, 05:32 PM   #487
skets
Member#: 170698
2003 WRX V-Limited
Thanks for the reply. I have an STi Turbo, STi intercooler, STi injectors, up-pipe, down pipe, and exhaust.
I have changed all the vacuum hoses going to the wastegate already. Could it be something else?
Old 09-12-2012, 06:03 PM   #488
SubiSam
Member#: 156401
'03 WRB WAGON
Well, to start off when you get your new solenoid, decrease max wgdc and initial wgdc (depending on your rom, some dont have initial wgdc) by about 30%. That should be a good starting point. Fill in your profile so we know what kind of suby you have and mods.
Old 09-12-2012, 11:58 PM   #489
skets
Member#: 170698
2003 WRX V-Limited
Thanks, I'll do that.
Old 10-19-2012, 01:05 AM   #490
Viral E
Member#: 242246
2002 Impreza WRX
Did a search and I can't seem to find an explanation on how to do this with a "bleed-type" setup instead of blocking. I'm more than likely having a "derp" moment but is there an explanation for that?
I'd also like to understand the difference between the setups. I get the impression with blocking type in a BCS failure you'll overboost badly?
Viral E is offline   Reply With Quote
Old 06-12-2013, 01:06 AM   #491
WillGeorge
Member#: 339409
2006 WRX
hi, back from the dead here
I am boosting too high on my 06 wrx vf39
my map is made for 18 psi, but i am boosting at 23. i know its a problem in the boost control system. I am wondering if a larger pill will fix it, or if i should do this new boost solenoid
any comments would be helpful! wanna start boosting again =)
WillGeorge is offline   Reply With Quote
Old 07-09-2013, 01:03 PM   #492
JonnyV2889
Member#: 197384
2006 WRX Ltd
Did you change to the vf pill? If yes and everything mechanical is fine, your max wgdc is too high.
JonnyV2889 is offline   Reply With Quote
Old 07-10-2013, 10:29 PM   #493
WillGeorge
Member#: 339409
2006 WRX
Thank you!
I drilled the pill to the right size and it still has a little boost creep.
Decided to go ewg, and a 3 port.
Thanks again.
Old 10-04-2013, 01:17 AM   #494
tersplat
Member#: 337888
2003 WRX Wagon
So, I am trying to get mine tuned right now, and my tuner is saying that my bcs isnt working( GM EBCS) but it was working on the previous engine, and on the jdm rom. I double checked and everything is hooked up just like in the first post, and I have double checked to make sure that the solenoid is operating with 12v applied to it, and it is. he says that the map is set up to run 20psi and on my datalogs, I am only pushing 15psi though. Any idea why this is? I tried flip flopping port a and b, and it made boost go to 20psi, but then it's not hooked up right. I'm so confused right now, I just want to get the tune finished so I can enjoy my new ej207, but this issue is keeping me from finishing the tune.
any ideas would be greatly appreciated.
tersplat is offline   Reply With Quote
Old 10-04-2013, 06:07 PM   #495
tersplat
Member#: 337888
2003 WRX Wagon
I just got home from another test drive, and this time, I switched to a brand new gm bcs, and had the same result. I cant ever hear any clicking though. maybe my exhaust is too loud, but the new solenoid is mounted with no rubber grommets and I can't hear a thing.
Old 02-10-2014, 07:31 AM   #496
Sparcomx
Member#: 1791
Sparcomx is offline   Reply With Quote
Old 02-12-2014, 03:48 AM   #497
Nikryj
Member#: 346659
Put the car into test mode and see if you hear it clicking.
Nikryj is offline   Reply With Quote
Old 10-01-2014, 12:01 AM   #498
sub9lulu
Member#: 36946
bumping old thread
who has the image saved please ? thanks
sub9lulu is offline   Reply With Quote
Old 10-04-2014, 02:45 PM   #499
sub9lulu
Member#: 36946
none of those pics on 202 is working
edit: i found this
http://mnsubaru.com/threads/gm-bcs-install.13966/
i got my car back together but havent started it yet
wish me luck
Old 05-20-2015, 11:28 AM   #500
coronamoto
Member#: 105850
2004 STi
Any one running the SH 7.00036.02.0 boost control solenoid? Im having trouble finding the specs for the solenoid
coronamoto is offline   Reply With Quote
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 05:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 07:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 02:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-24-2004 11:52 PM
