Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 10-05-2013, 12:20 PM   #1
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Default cobb v1 stage 1 91 to 93 loss of power? ??
my car was flashed with a cobb stage 1 91oct when I bought it. The dealership foolishly put 87 oct in it. So I figured the ecu compensated and retarded timing and what not. This morning I reset the ecu by disconnecting the battery then I reflashed to the stage 1 93oct map. Car def feels slower!! How long does it take to adjust or should it be ok out of the box??
bjjrev is offline   Reply With Quote
Old 10-05-2013, 12:46 PM   #2
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
You probably still have a mixture of 87 and 93 in it. I'd drive out of boost until your gas light comes on and fill up with 93. Do some logging (NOT WOT PULLS) or monitor knock and make sure you're not knocking like crazy. It may feel fine, but you could be definitely have a lot of knock. You could also put a few gallons of 100+ octane in if it's available by you.
Chicago AJ is offline   Reply With Quote
Old 10-05-2013, 01:03 PM   #3
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
I've been through 3 tanks of 93 since running that 1/4 tank of 87. It pulled pretty hard up until I flashed the 93 map. When it had the 87 in it I drove till the light came on. I was driving back from atlanta so I ran through 2 tanks of 93 after that at highway speed out of boost.
Old 10-05-2013, 01:07 PM   #4
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
Then the 93 octane near you might not actually be 93 octane. Just switch back to the 91 map.
Old 10-05-2013, 01:19 PM   #5
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Could it be the IAM?
Old 10-05-2013, 01:20 PM   #6
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Gotcha. I use the same shell gas station in the city that everyone else uses. I may just try a mixture.
Old 10-05-2013, 01:24 PM   #7
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Ill reflash when I get home... I shouldnt have messed with it! Haha I need a downpipe to go stage 2!!!
Old 10-05-2013, 01:26 PM   #8
bjohnson_55
Member#: 216580
Motor blown?
bjohnson_55 is offline   Reply With Quote
Old 10-05-2013, 01:34 PM   #9
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Why would the motor be blown? There is no knock.
Old 10-05-2013, 01:43 PM   #10
Razgeiz
Member#: 358782
2013 STi
Anytime you reflash you will have a dead pedal feel for awhile some cars take longer than others. Mine usually is gone after 50 miles or so but I've never put in the wrong gas so... you could of done some damage. And second did I understand correctly you flashed a stage 2 map when your still on stock downpipe?
Razgeiz is offline   Reply With Quote
Old 10-05-2013, 01:50 PM   #11
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Def did not flash stage 2.
Old 10-05-2013, 01:52 PM   #12
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
And thanks for the dead pedal explanation. That's what I think it's going on.
Old 10-05-2013, 02:56 PM   #13
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Watching my boost gauge I am only hitting .09mpa now also...
Old 10-05-2013, 03:26 PM   #14
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
No check engine light... no knock... could it be the dead pedal feel (iam)? I've only put roughly 20 miles since the new map.
Old 10-05-2013, 03:37 PM   #15
Razgeiz
Member#: 358782
2013 STi
I don't know the conversion for MPA sorry bit what do the map notes say boost levels should be?
Old 10-05-2013, 04:08 PM   #16
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
.09mpa = 13.05psi that's lower than stock. I'm gonna run with the ap to get an actual number when uy stops raining.
Old 10-05-2013, 04:25 PM   #17
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
16psi tapering down to 12...
Old 10-06-2013, 12:30 PM   #18
Razgeiz
Member#: 358782
2013 STi
Well if its not hitting target boost switch to the HWG map and give her a try you should see target boost then.
Old 10-06-2013, 01:40 PM   #19
bjjrev
Member#: 368929
2005 Wrx Sti
aspen white
Well... today its def hitting 16psi. Just took a few miles to reset. Lesson learned. Its gonna be parked while I go to work for a couple of weeks but while I'm gone ill be on the lookout for a catless down pipe and will be running stage 2 93 with c16 mix. Thanks for the help guys!
Old 10-09-2013, 01:18 PM   #20
RedImpreza07
Member#: 130600
2004 WRX
My stock boost gauge always shows lower than the AP shows. I just use the AP to know if I'm in the proper boost levels and the boost gauge to see when and if anything funny is going on. Mine at .09 mpa shows 14.9 lbs on the AP.
which is spot on Target boost for my 2004 Stage 1 WRX.
RedImpreza07 is offline   Reply With Quote
