Old 09-30-2013, 12:34 AM   #1
yudangorgor
Member#: 151107
Default Log Check: 2011 WRX STG2
91 Octane
Stg2 - catted dp, q300, aem cai
i did several runs just to make sure the results are consistent.
with the OTS map i have now, is it safe to run trackdays?
Run1
https://docs.google.com/file/d/0Bz8ItLxkWb7xd1FaZm9ZaUwzT3c/edit?usp=sharing
Run2
https://docs.google.com/file/d/0Bz8I...it?usp=sharing
Run3
Run4
yudangorgor is offline   Reply With Quote
Old 09-30-2013, 02:28 AM   #2
snoopy_sti
Member#: 164942
2015 Porsche Cayman
In all your a logs except the first one you are over boosting. Might want to try the lwg map.
snoopy_sti is offline   Reply With Quote
Old 09-30-2013, 10:07 AM   #3
Cobb Tuning
Member#: 4803
Originally Posted by yudangorgor View Post
91 Octane
Run1
Run2
Run3
Run4
I would try the super low wastegate (SLWG) version of the map. Boost is not tapering as fast as it should at higher RPM - this could be a case of boost creep, but we'll see what the SLWG log looks like (if you can get one safely). What downpipe do you have and what are the outside temps with these logs?
Bill
Old 09-30-2013, 10:22 AM   #4
yudangorgor
Member#: 151107
invidia catted dp...prolly approx 60degF..
Old 09-30-2013, 10:25 AM   #5
Cobb Tuning
Member#: 4803
Boost creep can be more likely with the divorced wg downpipes, although can still happen with bellmouth style downpipes. I would give the SLWG map a try and we'll see what happens. You want to try to get a higher RPM run (near redline), if you can do so safely.
Bill
Old 10-03-2013, 03:30 PM   #6
yudangorgor
Member#: 151107
Old 10-03-2013, 06:02 PM   #7
Cobb Tuning
Member#: 4803
The SLWG mapping dropped your peak boost levels, but the car is still building too much boost from 5000+ RPM. Your car may be suffering from boost creep.
There's one more test we can do to see if we can tune out that boost creep. Try doing a realtime map change to the Economy map and datalog one 3rd gear pull. If your car is able to maintain 8 - 12 psi at redline then we may be able to tune it out. If your car still creeps up to 14 - 15 psi at redline then you have true boost creep.
Chris
Old 10-07-2013, 01:25 AM   #8
yudangorgor
Member#: 151107
Old 10-07-2013, 07:04 AM   #9
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
I think cobb needs one up to redline onnstrictly the wg spring.
bluemax189 is offline   Reply With Quote
Old 10-07-2013, 10:28 AM   #10
yudangorgor
Member#: 151107
economy map tops off at 5500RPM or so though
