Old 10-08-2013, 11:00 PM   #1
wchafe
Member#: 361580
2014 STi 5dr
Default AccessTUNER Race - no dashboard or logging
I am connecting ATR to my 2013 STi through my Accessport V3. I have OTS map Stage 2 91 v332 in the ECU and loaded in ATR. I can connect to the ECU, and the live tracing function works so I am definitely seeing live ECU data.
The problem is when I select Dashboard the display is blank and after a short while I get an error message that the ECU connection is lost. Once this happens live trace also no longer works, I have to reconnect to the ECU. Also logging does not work, my log files are empty.
Any ideas why selecting dashboard drops the connection to the ECU? Is there maybe some conflict with the new V3 accessport?
wchafe is offline   Reply With Quote
Old 10-09-2013, 12:27 PM   #2
Tripintaz
Member#: 245218
2013 STI Limited
Sounds more like a PC issue if you cannot even connect to the ECU.
Old 10-09-2013, 04:24 PM   #3
wchafe
Member#: 361580
2014 STi 5dr
I can connect to the ECU. It's only when I try to use the dashboard that I get the problem.
Old 10-10-2013, 09:38 PM   #4
Cobb Tuning
Member#: 4803
How many monitors do you have selected? Have you tried with only 1 or 2 monitors? I'll try to duplicate the issue tomorrow, but any more info you can give us will help narrow it down.
-Josh
Old 10-10-2013, 09:49 PM   #5
wchafe
Member#: 361580
2014 STi 5dr
I did try with just a few monitors, not sure how many but no more than 4 or 5. I was running Windows 7 in Parallels v8 on a mid2011 Macbook Air. If it wasn't able to connect at all I would have blamed the VM, but as I said it does connect to the ECU and I can see that live tracing is working by viewing a table because the table cell that's highlighted changes as I rev the engine. That connection seems to last indefinitely until I choose the dashboard.
Old 10-11-2013, 10:01 AM   #6
Cobb Tuning
Member#: 4803
Do you have a wideband connected via ATR or have one selected in the ATR options? If so, try removing that option from the software. Occasionally if you are using the wideband feature, the software can timeout and drop comms if the WB signal becomes unresponsive.
Old 10-11-2013, 12:27 PM   #7
wchafe
Member#: 361580
2014 STi 5dr
No wideband connected or configured. I know I ran it with just a few monitors but wasn't sure how many so I tried again starting with two. I tested about 10~12 times with various monitors set. It does appear to be related to the number of monitors. I've found that it works reliably with up to 4 monitors. It will sometimes work with 5 but usually not. Any more than that and it never works. Any ideas on why it only works with so few monitors? I've successfully logged far more than that with the accessport V3 directly and I've never had an issue with logging in the accessport.
I'll try it on a laptop with a native Windows 7 install and see how that goes. I'll report back.
Old 10-11-2013, 12:38 PM   #8
Cobb Tuning
Member#: 4803
I have seen a few guys have odd issues using VM, specifically with USB communication. The guys internally that use Macs with our software usually use Boot Camp or something that will allow you to fully boot up in Windows as opposed to a virtual machine.
Let us know if the native Windows 7 laptop has the same behavior or not.
- Chris
Old 10-11-2013, 07:57 PM   #9
wchafe
Member#: 361580
2014 STi 5dr
The VM was the problem. I was able to display as many items as I liked in the dashboard on the native Win7 laptop. I stopped at 31.
I then installed Win7 on the Mac with Bootcamp and that works fine, so that's what I'll use from now on.
Thanks for the help Chris.
- Wade
Old 10-14-2013, 01:17 PM   #10
Cobb Tuning
Member#: 4803
No problem. Glad you got it sorted
- Chris
Old 10-14-2013, 08:08 PM   #11
loather
Member#: 367325
2008 STi Hatchback
I too suffer from the VM issues - it'd be great if Cobb would plan for a Mac version of their software at some point
loather is offline   Reply With Quote
