Old 10-10-2013, 05:00 PM   #1
lavid2002
Member#: 226864
Default Omni 4 bar MAP throwing CEL
Hey everyone,
Does a base map need to accomodate for an omni 4 bar MAP sensor? I have a car that is running a little rough but the AFRs are fine, I have an omni 4 bar MAP sensor on it and I'm wondering if maybe my tuner forgot to accomodate for this. I'm getting a P0107 from it. Perhaps I should throw the OEM MAP sensor back on for break in.
Input?
_Dave
lavid2002 is offline   Reply With Quote
Old 10-10-2013, 05:11 PM   #2
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Yes the only thing oem about those sensors is the fitment. It needs to be calibrated accordingly.
Id toss the stock MAP in, reset the ecu. let idle for fiveish minutes then drive around and see how things look.
I know they work well when calibrated properly with the 32bit ecu "DBW throttle cars" Ive heard they were having issues with them on the 16bit ecu "DBC 2.0ltr 02-05" cars.
Are you running SD or MAF based tuning?
Old 10-10-2013, 05:16 PM   #3
lavid2002
Member#: 226864
This is the kind of stuff that is making me slightly questionable about my tuner. I explicitly asked him this and gave him a list of all my mods and he told me to throw the MAP sensor on right now and not to wait until dyno day. Meh.
I'll throw the OEM sensor back on and see how that works out.
Edit: Just read your vehicles. This is for an 05 FXT
Old 10-10-2013, 05:28 PM   #4
rexworx
Member#: 103232
wootwoot yeah some fozzy love! ok for its a 32bit ecu. If calibrated correctly it shouldnt be a issue.
is this on opensource or a AP?
Why were you swapping it out? how much boost did you want to run?
Anything I can do to help!
Ian,
Old 10-10-2013, 05:36 PM   #5
lavid2002
Member#: 226864
Thanks Ian,
It's an Accessport. I was advised by my tuner to swap it out as the OEM MAP sensor "Doesn't read past 22 psi and has no boost cut"
I don't intend to run over ~20 psi anyways.
Old 10-10-2013, 05:45 PM   #6
rexworx
Member#: 103232
Pump gas or e85. From the sounds of it you might want to seek out another tuner... the MAP has nothing to do with fuelcut. no need to swap out imo if your not pushing it.
The pic looks nice!!!
Old 10-10-2013, 06:12 PM   #7
lavid2002
Member#: 226864
I didn't want to throw a name around but I am using precision tuning motorsports. I heard great things about them.
I'm tuning for 93 octane.
I don't have it in email so I don't want to quote directly, I think it may have been through a phone conversation where they recommended the MAP sensor and gave reasoning, but here's a few emails about the base map.
The 850cc and 4 bar setup will work just fine. Cleo Is making a make for
you as we speak. keep an eye out for it.
XXXX
-----Original Message-----
Sent: Friday, September 27, 2013 12:29 PM
To: XXXX
Subject:XXX
Sure,
I have two questions though. I have OEM 550 side feed injectors on the car,
and set of 850ccs in my garage that you asked for. Which injectors should be
on the car for the base tune? I planned on putting the 850s on for the dyne
tune and leaving the 550s on for the base map as I was told. is this
correct? (because you have to change the injector duty cycle right?)
Also, I have an OMNI 4 bar MAP sensor. The OEM MAP sensor is on the car now.
Same question as the injectors, should I leave it off until the dyne sesh or
put it on now?
Old 10-10-2013, 06:26 PM   #8
rexworx
Member#: 103232
OK Cleo does know his stuff. I think hes still there...
Old 10-10-2013, 08:45 PM   #9
lavid2002
Member#: 226864
Good to hear
Old 10-10-2013, 09:52 PM   #10
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Just finished watching the vid from Shawn Church OS tuning an '05 STi. Car had a 4 bar MAP sensor and he did have to change the scaling (multiplier and offset). At first he disabled dtc for map sensor range/perf but car still threw a PO107 and had trouble with a low idle. After he disabled PO107 and PO108 everything was good.
Old 10-11-2013, 02:03 AM   #11
lavid2002
Member#: 226864
I swapped for the OEM MAP sensor tonight and went for a cruise running mildly to 4k and engine braking to seat those rings. Everything was going great then I did a 2nd gear to 4k and popped it into third. Right as I was tagging 4krpm the engine cut power and I got a check engine light for the boost solenoid "A"
IDK if this is related to the MAP sensor or not but I was watching the boost gauge pretty well keeping it around ~8psi. I opened the AP and it said that I was at 0psi at idle (No way) and I was at 22psi when my gauge read 7 psi. So something is off, car must have thought I was overboosting and now it won't let me go over 7psi.
IDK I guess it's kind of a good thing for now but I wonder why it is cutting this.
AFRs look good. 11.1 at WOT still.
Old 10-11-2013, 08:19 AM   #12
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Talk to your tuner.
Old 10-11-2013, 11:21 AM   #13
Airboy
Member#: 72829
2006 WRX
2015 WRX
4-bar MAP sensor has different pressure vs voltage slope than the stock unit. You can't swap between them without reprogramming the ECU. There is a high/low voltage threshold table that need to be altered to prevent the CEL.
Airboy is offline   Reply With Quote
Old 10-11-2013, 12:34 PM   #14
rexworx
Member#: 103232
^^^ exactally^^^
Also the AFR sensor is crap once your on the gas. 11.12 is more of a default. Real afr could be 12.5-1 or 8-1. you need a widedand for the openloop part of tuning...
Old 10-13-2013, 11:40 PM   #15
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Carberry roms have a patch built into them for these issues as well
cosseywrx is offline   Reply With Quote
Old 10-16-2013, 10:25 AM   #16
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
XXXX
To: XXXX
Subject:XXX
Sure,
put it on now?
I quote you quoting them. They say your injectors and map sensor will be fine and they have a map in the works for you. Did you load they're map with the scaling for the new map sensor or have you not recieved it yet?
The scaling of the ONMI power sensor is different but the min and max fault voltages have to be changed to 0 and 5 V respectively also or you will have problems. If the ECU thinks its overboosting with the stock MAP sensor on it sounds like your map map be scaled for the new sensor but the fault voltages aren't set up correctly.
kellygnsd is online now   Reply With Quote
Old 10-16-2013, 06:02 PM   #17
lavid2002
Member#: 226864
I think that is what's happening. I received the base man and have flashed it to the ECU. I put the omni 4 bar MAP sensor back on and am running the car like that.
Old 10-16-2013, 06:52 PM   #18
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Why not just ask your tuner. From you first post you made it sound like you just installed the ONMI power without even a reflash and expected it to work.
That bit of info about the reflash is info we didn't have but your turner did. He should have been able to either tell you what he did to your map or tell you where to check to see what he did to your map.
Old 10-23-2013, 06:46 PM   #19
Clark Turner
Member#: 178047
02 WRX STI Spec C
Do yourself a favor and do not use the 4 bar. I have had at least a dozen fail. For 20 psi, the factory sensor is fine. If over 25 psi, you can use the AEM 3.5 bar brass for gasoline or Stainless for Gasoline and E85 use. Never had the AEM fail. What is scary is that if you are using SD with the 4 bar and it does fail, it tends to lock up in one spot. The car may run ok at idle and cruise but then never get fuel on boost.
On the 16 Bit ECU, They will cause an oscillation in idle. I was the one who found this and reported it. Don't use the 3 or 4 bar on that ecu. Stock or AEM is fine.
C
Clark Turner is offline   Reply With Quote
Old 10-23-2013, 07:23 PM   #20
cosseywrx
Member#: 276443
I run an omni 3 bar on a carberry tune with zero problems. On stock rom i would say go Aem.
02-03 wrx ecu on 05 wrx
Old 10-25-2013, 12:55 AM   #21
lavid2002
Member#: 226864
The car the engine is in is a 2005 Forester XT.
I used a base map prepared for me by my tuner.
Old 10-25-2013, 11:56 AM   #22
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
C
Does an ECU reset fix this? Should be noticeable if you are constantly watching afr in boost
wgr73 is offline   Reply With Quote
Old 10-26-2013, 04:05 AM   #23
Clark Turner
Member#: 178047
02 WRX STI Spec C
No. Reset does not fix. Sensor fail.
Old 10-28-2013, 01:42 PM   #24
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Cool. If this should ever happen then it would be easy to spot. Thanks
Old 08-09-2015, 01:05 PM   #25
2015_upgraded_sti
Member#: 427671
2015 Subaru STI
Default OMNI 4 Bar Sensor Fail on 2015 STI
Apologize for replying on an old thread.
I recently had my 2015 STI speed density tuned to make 352 WHP on 91. The tune was done at a very respectable place in So-Cal and all worked fine until 2 days later when the engine stopped on cruising throttle.
It turned out that the OMNI 4-bar sensor was giving an erroneous 70PSI boost and my injectors were maxing out (fuems from exhaust). Luckily I didnt blow up my motor.
I called OMNI up and they indicated that the rate of failure on these sensors is 0.3%. Thats 1 in every 333 cars. I think this rate is too high.
Questions :
- Which other map sensor are typically used when running high pool with speed density?
Suggestions :
- Keep your original/stock manifold sensor handy. Get another map with low boost. In case the omni sensor blows up, swap the sensor with stock and run the low boost map.
2015_upgraded_sti is offline   Reply With Quote
