Welcome to the North American Subaru Impreza Owners Club Tuesday October 6, 2015
Old 10-08-2013, 03:17 PM   #1
Member#: 356509
2007 WRX STi
Default Flywheel torque question
I have a 2007 STi running stage 2 cobb map with full cobb turboback exhaust. Any estimation of of torque at the flywheel? I ask because I am about to get a new clutch and can't deciding between Exedy 15803 or Exedy 15803(HD). Google didn't really help me that much. Any help would be appreciated. Thanks.
weirdTurnedPro is offline   Reply With Quote
Old 10-08-2013, 04:43 PM   #2
Member#: 197384
2006 WRX Ltd
Why do you need flywheel torque? Exedys appear to be rated at brake torque, which you're probably in the 300-340 range.
JonnyV2889 is offline   Reply With Quote
Old 10-11-2013, 12:53 PM   #3
Member#: 46135
02 WRX
Sti V9 Spec C
The gearbox is a torque multiplication device.
The losses are in the form of lost power/heat, the output torque can be higher than the input torque, depending on the gear you're in. In 4th of the 6 speed, you're not at 1:1.
There is no 1:1 ratio in any of the gears, once you factor in the final drive ratio.
At the wheel contact patch you have a propelling force, not a torque.
So, when a figure comes out regarding torque from a dyno, I think there is a compensation factor involved.
It can measure no further than the torque at the axle, not "at the wheels".
But when you try to figure out what it compensates to torque-wise, things become unclear.
The torque at the axle will be different than the torque at the transmission output and the torque at the flywheel.
