Old 10-11-2013, 08:29 AM   #1
ronaldremedy
Member#: 352353
2007 wrx
wrb
Default help, clutch problem :(
so i was driving on the high way, and i ran over some small animal like a rabbit or something, and as soon as i hit it, my clutch stops working right, my car in gear would smoke, and a screeching noise happened, so i took it out of gear, and when i push in the clutch it has almost no motion ( stuck almost all the way down) and putting it into gear makes it pulsate on my foot.
ronaldremedy is offline   Reply With Quote
Old 10-11-2013, 09:11 AM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
I'd start with checking to make sure the clutch line didn't get damaged. You probably lost fluid if its stuck the floor. If not there's probably an issue with the slave/tob area.
JonnyV2889 is offline   Reply With Quote
Old 10-11-2013, 11:53 AM   #3
atomicfire
Member#: 136296
2005 STi
it probably had nothing to do with the small animal you ran over. I believe your car is a push-type clutch - the screeching noise you hear is probably the throwout bearing scraping against the pressure plate. You may also have broken a finger or two on the pressure plate, which is what is causing the clutch pedal to feel funny.
You will need to take apart the clutch assembly to inspect what happened. Before you dive in, check the things that don't require you to pull the engine or transmission:
Clutch fluid
Clutch hose
Clutch pedal
You can also remove the inspection plate under the engine and take a peek into the bellhousing with an inspection camera.
There's another access port on the top of the bellhousing that is used for automatic transmissions to unbolt the flex plate. It's covered by a rubber plug - you can pull the plug out and stick an inspection camera in there too.
Good luck!
atomicfire is offline   Reply With Quote
Old 10-11-2013, 01:43 PM   #4
danger1138
Member#: 279525
04 rex luger!
Is it dangerous to run without that rubber inspection plate? Mines got lost jn the shuffle.
danger1138 is online now   Reply With Quote
Old 10-11-2013, 01:47 PM   #5
atomicfire
Member#: 136296
2005 STi
No, you'll be fine.
