Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-18-2013, 09:51 PM   #476
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Quick question: If I have a tune that was done on a 2.5 R12 Hydra, can I just load the maps right onto a 2.5 R15 Hydra? I just replaced my R12 with an R15 and want to make sure the files will work okay.
ExecNav is offline   Reply With Quote
Old 05-19-2013, 04:27 PM   #477
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Phil-
Shot you a message. Hope you had a good weekend!
-Brett
Old 05-20-2013, 04:42 PM   #478
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Hydra 2.5 units have encrypted maps so if you're map is from XXX serial number and you load that map into yyyy serial number it will not work.
You can email me the serial number and I'll get you the unlock code for the unit so you can do that but if you need maps and more support we do charge a one time fee for that.
Element Tuning is offline   Reply With Quote
Old 09-11-2013, 03:43 PM   #479
Element Tuning
Member#: 54918
673 WHP Element
Default Plug and Play Hydra EMS for FRS/BRZ
I think many already know Iíve been testing and developing the Hydra EMS for some time in our Time Attack car and successfully winning many races. Great car and great engine!!!!!
Much of what Iíve been doing is testing the limits of various engine parts and tuning parameters since not only is this a new engine but also the added complexity of direct injection with simultaneous port injection. I really wanted to not only test these things on the dyno but also in the everyday commute and then in torturous racing environment. Itís very important to me, more than peak power, that my base maps are tested in real world conditions and under racing conditions.
Hydra Dyno Plot: Dynajet SAE Corrected
Modifications:
Element Tuning Hydra EMS plug and play Stand-Alone
Element Hydra EMS Boost Control Solenoid
Element Tuning Competition Catch Can
FA20Club 60 Trim Turbo Kit, 60 Trim Garrett Turbo, Front Mount Intercooler, Tial MVS WG, and Tial BOV
Full Blown Radiator
DW1000cc Injectors
DW300 Fuel Pump and OEM Fuel Pump in saddle tank
Cat delete and muffler delete pipes
Element Tuning Custom Valved BC Racing BR Coilovers
Whiteline Front Sway bar and transmission bushing
Clutch Master Clutch and Flywheel
Brembo STi front brakes and rotors
18x10 Rota DPT with 285/645-18 Hoosier or Pirelli slicks
18x9.5 Prodrive GC010 with 275/35-18 Hankook RS3
18x9.5 Rota T2R with 225/45-18 Goodyear F1
Hydra screen shot:
While a full fledged stand-alone EMS with all of itís additional features (Anti-lag, Launch control, Flat-Foot Shifting, Gear Based Boost Control, 45 psi MAP Sensor, Flex Fuel Sensor (E85) Support, Multiple Maps, Programmable Traction Control) my not be needed by everyone, finally everyone has another choice for the FRS/BRZ in terms of engine tuning. What really sets the Hydra EMS apart at itís core is that is end user tunable so anyone with a laptop is free to tune themselves or use any tuner they like in the world. Tuned base maps for NA, E85, Turbo, race fuel, will always be free to the original owner along with technical support. Your factory ECU does not need to be flashed or even removed, just unplug the connectors, and plug the Hydra harness and EMS in.
Getting Technical with the Hydra EMS for the FRS/BRZ:
- Stand-Alone, plug and play
- Full CAN Bus support. This means your ABS, Dash, Fuel Computer, Stability Control Modes, AC, Stereo, Power Steering, all remain functional.
- Simultaneous Direct and Port Injection strategy. This is really where an exceptional tuner is going to excel because you have precise control over how much direct injection pulse width you want vs. how much port injection pulse width you need at any RPM and at any load (Boost or Vacuum). This way as you upgrade your port injectors you can still have specific control over your DI injectors. This will come in handy as you start pushing higher power levels and RPM levels where DI injection pulse width limits are very critical. I found pushing the limits here at high RPM can pay off but itís a fine line that changes with HP levels.
- Injection Response (On-Time). Each set of injectors has their own specific injector response time maps. As you change brands of injectors, fine tuning results in smoother running.
- Injector Phasing. Direct Injection requires very specific timing of the pulse width at different RPM/Load ranges and you have complete control over this. You also have separate control over your Port Injector Phasing.
- Fuel Pump(s) Control. This comes in real handy when boosting the car since you will need a larger fuel pump and the OEM system is internally regulated. Iíve actually assigned in our base maps a 2D fuel pump controller duty map so that you donít over power the OEM internal regulator with a the larger fuel in tank fuel pump. My personal car also runs twin pumps, one in the saddle tank, and the Hydra is triggering both pumps. Now the direct injection pump is mechanical but with the Hydra you can tune your pressure target based on RPM/Load. Hitting these targets can be adjusted through the DI Fuel Pump Pulse Width, DI Dump Valve Response Time, Dump Valve Phase Trim, and PID.
- Variable Cam Timing. The Hydra has ďquadĒ variable cam timing control. This mean each of the intake cams and each of the exhaust cams are run in closed loop. So your variable cam timing maps are tuned with a target and the Hydra then ensures each cam hits that target independently. Advanced user control allows fine tuning of cam discrepancies an error in target control. So if you have one cam that is off 1 degree at idle that can be fine tuned and if youíre overshooting, undershooting, or too slow to respond, the closed loop rate can be fine tuned to hit the target as fast as possible without overshooting.
- Closed Loop Fuel Control: This is where something like a Hydra can make the difference between loving your highly modified daily driver or hating it. With 1032 load cell fuel targeting the Hydra can set to any AFR target at any RPM/Load. This really comes in handy when you have a heavily ported or cammed motor that may not want to idle at 14.7 AFR or when running E85 and you can run much leaner AFR targets. As load increase you can stay leaner longer or go richer sooner and making your engine run in the ďsweetĒ spot makes all the difference in the world. You can also set your how aggressive or how slowly you want the closed loop to control the fuel changes. You can also set the TPS cut off point for closed loop fuel control. On top of all that the Hydra has Multiple AFR Target Tables so if your map is tuned so the Auxiliary maps are tuned for E85, you can run a unique AFRs better suited for E85.
- Flex Fuel Sensor Support. Want to run E85 but itís not readily available? Flex Fuel Sensor Support allows automatic map switching in the Hydra based on ethanol content and it also has automatic fuel, boost, and ignition timing tuning based on ethanol content. Simply tune your base pump fuel map (fuel, ignition, and boost), then tune your E85 map and the Hydra will trim boost, fuel, and ignition timing based off of the ethanol content when you canít get e85 and are forced to mix pump fuel with it. The Hydra also has additional ďstartingĒ maps for using E85 so that extra start fueling requirements can be handled independently of your pump gas starting maps.
- Boost Control: Built in boost control without the need to eliminate your purge control valve like OEM flashing. With a great blend of closed loop and manual control you can really get what you want out of the boost control system. Maximum boost sets your protection for overboost with a fuel cut, Boost RPM Targets, minimum solenoid duty based on boost target, maximum solenoid duty based on boost target, compensations trim maps for coolant temp, air temp, knock, throttle position, and gear.
- Traction Control, Programmable. This has to be the best feature honestly for a high powered FRS/BRZ. Letís face it the OEM traction control is lame as itís not performance based, itís just way too intrusive. You can now set your traction control to intervene smoothly and less aggressively if youíre a racer like me through fuel cutting and ignition cutting, based on each of the 6 gears. Each gear has its own speed delta trigger for traction control along with each gear having its own setting for ignition and fuel cutting. So one may want a more aggressive traction control setup in 1st gear than they want in 3rd gear for instance.
- Different Engines. Donít want to run the FA20? Want to drop in your monster EJ257, how about an EZ30R H6, Supra 6Ö.no problem with the Hydra EMS as we make custom ecus for this very thing so you donít have to rewire you chassis and loose your carís features!!!
I could go on and on but Iíll leave the rest open for discussion or questions.
Iím sure many are thinking, OMG I have no idea what heís talking about and I donít know if I can even tune all of that or need it. This why Iíve taken so long to release any real information until Iíve tuned the base maps and encountered typical issues a customer may come across. The maps are already dialed in for a particular modification path and your ďaverage JoeĒ will need just the typical fuel and ignition tweaks. People with more advanced skill or those who seek every last ounce of performance will be able to extract that with all the advanced features. Tuners and those forging uncharted territory will not have brick walls to face and Iím always available to guide or coach anyone through tuning a difficult combo.
The latest Hydra 2.7 software is so nice and easy to use compared to past versions. Having a Google software engineer on our team has made all the difference in the world here and trust me when I say we can do just about anything, all you need to do is ask, Iím not kidding. We have advanced expressions that allow us to tweak output controls and do things that are not part of the ďfixedĒ maps.
If you guys want to know more we have a thread going in Proven Power.
http://forums.nasioc.com/forums/show....php?t=2549903
Thanks,
Phil Grabow
Old 10-14-2013, 02:15 PM   #480
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
i have purchased an upgraded 2.7 hydra that has the harness to run parallel to the oem ecu. Is this the only way to run this unit or is there a way to run this unit as a full stand alone? Meaning i can remove the OEM ECU from the vehicle. Its not a huge problem except for the room i would need to mount both ecus. Also does anyone have a photo of a hydra installed in parallel with the factory ecu? I'd like to have as clean an install as possible.
Unit SerialNumber is : FHZ050111C2.70W11564
SpongeBobSquarePants is offline   Reply With Quote
Old 10-31-2013, 03:57 AM   #481
Moxik
Member#: 288398
what Hydra i can buy for 2005 Forester 2.5XT MT? i need PnP Ecu with all options
Moxik is offline   Reply With Quote
Old 10-31-2013, 03:17 PM   #482
Element Tuning
Member#: 54918
673 WHP Element
You would need our 2005-2006 STi Hydra EMS.
Old 12-03-2013, 05:50 PM   #483
Element Tuning
Member#: 54918
673 WHP Element
The latest Hydra EMS 2.7 software has individual cylinder knock detection and correction. Awesome stuff!!!
Upgrade your Hydra 2.7 flash and software here:
http://www.hydraems.com/software/
Thanks,
Phil Grabow
Old 12-24-2013, 03:52 AM   #484
pivo
Member#: 376875
Default Hydra 2.1 Software
Hi guys, I'm in desperate need of the hydra 2.1 software, does anybody still have it??
pivo is offline   Reply With Quote
Old 12-24-2013, 09:35 AM   #485
Member#: 296048
2011 STI
Blurple
Old 12-24-2013, 10:01 AM   #486
Element Tuning
Member#: 54918
673 WHP Element
Thanks...Google is your friend
Old 12-24-2013, 09:31 PM   #487
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Thanks,
Phil Grabow
Which menu has that?
west_minist is offline   Reply With Quote
Old 02-13-2014, 02:43 AM   #488
lyckaon
Member#: 105257
Someone to help me??
I lost my Nemesis 2.5 R12 software after a pc crash
Who could send it to me? Please please
Thanks a lot
lyckaon is offline   Reply With Quote
Old 02-13-2014, 11:19 AM   #489
Element Tuning
Member#: 54918
673 WHP Element
Old 02-15-2014, 05:42 PM   #490
traction issuez
Member#: 86559
2005 RS Wagon
why isn't there a hydra plug and play kit for 2005 2.5rs?
I have a 2.17 ecu for 05 sti and I'm trying make it work for my rs that will be converted to ez30.
traction issuez is offline   Reply With Quote
Old 02-15-2014, 07:42 PM   #491
Member#: 296048
2011 STI
Blurple
In sure that hydra could help you out with a jumper harness of some sort to solve your dilemma give them or element tuning a call
Old 02-15-2014, 07:46 PM   #492
traction issuez
Member#: 86559
2005 RS Wagon
Yes. I called but only received a voicemail option. I emailed hydra ems and it looks like I can use the ecu for ez30 with cable throttle body. I'm still not sure if the ecu plugs into an RS though.
Old 02-17-2014, 08:16 AM   #493
lyckaon
Member#: 105257
Thank you )
but its just a small file... it dont work. Im lost... (
Old 02-17-2014, 05:19 PM   #494
Element Tuning
Member#: 54918
673 WHP Element
We do actually make a unit for the 05 RS we just only list the most common applications. Making that older unit work will be expensive since it requires a 2.7 upgrade along with the newer DBW circuit board and you would need a new wiring harness. You'll still save a few hundred over a new unit however.
EZ30, EZ30R, and EG33 applications are no problem.
Old 02-17-2014, 05:20 PM   #495
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by lyckaon View Post
Thank you )
The link works fine for me sorry.
Old 02-17-2014, 06:23 PM   #496
Member#: 296048
2011 STI
Blurple
I'm new to the nemesis software and was wondering if someone could help me figure out where to find the menu to input my injector scale. trying to setup a startup base map for my car.
ID1300s 2011 STI davcs.
Old 02-17-2014, 06:31 PM   #497
traction issuez
Member#: 86559
2005 RS Wagon
I believe we have a harness that will work for that car.You will need to
wire the 4 additional wires for the 2 injectors and ignitors.* You will need
to upgrade the hardware for that ecu to run the 6 cyl motor. Price for PNP
harness will be $325 and ecu upgrade will be $750. Let us know if you like
to proceed.
Best Regards,
Hydraems Support
I'm having a difficult time selling my hydra that's why I'm trying to reuse it on another project. if I can get a new ems for 1k it would be worth it.
Old 02-20-2014, 04:17 PM   #498
Element Tuning
Member#: 54918
673 WHP Element
That's not how it works when tuning injector pulse width. The "Base Fuel Table" is specific to a fuel injector and setup. So when someone purchases a Hydra EMS from Element we'll ask the engine modifications and provide a map specific to that. Now if you have let's say a 800cc map you're starting with you can multiply the fuel map by the appropriate percentage to get close to the new injectors.
I'm going to say this right now and that's not going to work with the DW1300cc injectors are they have a pretty unique injector response curve compared to other injectors so you first need to get that right and then adjust the fuel map.
We have DW1300cc base maps for Hydra 2.7 and if you are the registered purchaser it's free but if not you can still purchase the maps from us and the tech support.
Old 02-20-2014, 04:18 PM   #499
Element Tuning
Member#: 54918
673 WHP Element
Then it's worth it
Old 02-20-2014, 04:40 PM   #500
Member#: 296048
2011 STI
Blurple
Thanks I am a customer. Tony from Jersey with the pro comp your building for me. Can't wait....
Seems ether aren't too many folks out there who are competent with this ems system. Why do you think that is?
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 02:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 08:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 02:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 12:39 PM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 05:12 PM
