Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 10-10-2011, 07:45 PM   #101
2006whitesti
Member#: 124311
2006 STi, 03WRX wago
10Tribeca,00 RS,99 Foz
Originally Posted by Homemade WRX View Post
does anyone have any good leads on velocity stacks?
I can find a ton of smaller ones but am having a hardtime find 2.5" (roughly 64mm) size that aren't a huge taper. The only two I've been able to find are like 8" long total length and located in the UK or in Aus.
http://www.rossmachineracing.com/velocitystacks.html
2006whitesti is online now   Reply With Quote
Old 10-10-2011, 08:19 PM   #102
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
^^I know about them and they're actually not far from me either. Sadly they don't make a large enough ID velocity stack.
Thanks for the velocity stack link, Brent!
Old 10-13-2011, 07:10 AM   #103
Rising Sun Subaru
Member#: 265020
thats who we use.
http://www.jntperformance.com.au/
Kris
Rising Sun Subaru is offline   Reply With Quote
Old 10-13-2011, 01:02 PM   #104
Homemade WRX
Member#: 33782
96 bastard child
Yeah, JNT was actually one of the one's that I'd found.
Old 10-14-2011, 10:24 AM   #105
tyroorosaurswrx
Member#: 245440
08 Impreza WRX
Originally Posted by elow07 View Post
Thats SICK!! no turbo lag there huh?
WOOOOOAHAHAHAHAAAAAAAA That is soooo sick. SOOOOOO DOPEEEE!!!!
tyroorosaurswrx is offline   Reply With Quote
Old 10-16-2011, 02:29 PM   #106
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Originally Posted by ADAM (type r) View Post
wrc replica made out of 2 version 1 manifolds
Nice, want to make one for a phase 2? lol!
heres my modded stocker. Its not done yet, but almost there. The hardest part has been making the throttle pull.
Old 05-10-2013, 07:26 AM   #107
TIGWERKS
Member#: 256615
The start of my manifold project. A few small adjustments and then off to get machined.
TIGWERKS is online now   Reply With Quote
Old 05-12-2013, 02:08 AM   #108
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
^^^ Now that's badass. I'm lovin it, now just waiting for the finished product/1off.
...CHUCKLES... is offline   Reply With Quote
Old 05-12-2013, 03:08 AM   #109
Buck Steinberg
Member#: 295650
2002 Impreza 2.5 RS
What material is this?
It looks like ceramic on my iPad...
My guess is aluminum?
Buck Steinberg is offline   Reply With Quote
Old 05-12-2013, 09:41 AM   #110
TIGWERKS
Member#: 256615
No I had one rapid prototyped before I had a set machined. I often overlook stuff when all I have to look at is a computer screen. I made a few small adjustments to it as a result of having one in my hands. I grabbed some injectors and some fuel rail stock, machined the injector ports in the rail and took some measurements for that. Since aftermarket rails obviously won't work with this I needed to come up with a solution for it. Set it up for off the shelf 60mm x 14mm injectors. I won't have my car for awhile so I'm not sure when I'll be building a manifold but I believe I have a machine shop setup to machine these in aluminum for me. Hadn't even driven my car yet with the setup I just finished and now in changing stuff around already.
Old 05-12-2013, 10:18 AM   #111
JonnyV2889
Member#: 197384
2006 WRX Ltd
I'd love to be given a project like that at work. 3d milling the runner tract will be a bit time consuming.
JonnyV2889 is offline   Reply With Quote
Old 10-13-2013, 08:06 PM   #112
ScoobyJD
Member#: 185910
2007 WRX TR
bump thread, dont care; want to see more goodies
ScoobyJD is offline   Reply With Quote
Old 10-13-2013, 08:38 PM   #113
TIGWERKS
Member#: 256615
I'll be running my manifold flanges soon. Hopefully this month Probably going to go with a slightly smaller runner than my original plan, should pair nicely with the new turbo setup
Old 10-13-2013, 10:02 PM   #114
ScoobyJD
Member#: 185910
2007 WRX TR
I knew that is what you were working on after I thought about it for some time. You sneaky dog you! lol
Old 10-14-2013, 02:19 PM   #115
kay95
Member#: 45494
95 impreza L awd
green
If you go through all the work to get a printed part why not just get one that is made of GFN or some of the other high temp plastics? There are several materials now that can be rapid protoyped to around 350-400F. Just use some silcone connectors and make it two, three or four pieces if you have to.
kay95 is offline   Reply With Quote
Old 10-14-2013, 08:51 PM   #116
TIGWERKS
Member#: 256615
Why would i do that? No sense in that, all I wanted was a cheap part to check everything with and that did it. I don't want manifold held by silicone couplers and that's several pieces. More chances for stuff to leak and or blow apart. Besides I like to build and weld stuff and make pretty things and plastic stuff doesn't allow that.
Old 10-15-2013, 08:00 PM   #117
omiotek
Member#: 272090
^^^^agreed......
omiotek is offline   Reply With Quote
Old 10-22-2013, 10:24 AM   #118
fateo66
Member#: 130997
I have two extra manifolds and fuel rails for sale after my last few builds
http://forums.nasioc.com/forums/show....php?t=2563668
fateo66 is offline   Reply With Quote
Old 10-22-2013, 06:36 PM   #119
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
You Sir are asking for trouble
dangerousatom is offline   Reply With Quote
Roller Barrel ITBs and Custom Intake Manifold Design wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 277 10-11-2010 08:06 AM
Post your custom intake heat shields sc00ter Interior & Exterior Modification 10 01-19-2010 11:42 PM
Custom Intake Manifolds??? schvanos Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 10-15-2005 09:52 PM
Custom Intake Manifold (gauging interest) Tattoo Collector Normally Aspirated Powertrain 37 02-10-2003 06:49 PM
Custom Intake Manifold N/A01RS Normally Aspirated Powertrain 2 08-22-2002 05:05 AM
