Old 10-08-2013, 03:42 PM   #1
Joshrs
Member#: 361863
01 rs
Default clutch bled, still on floor(swapped car)
Ok so my car started as a 01 impreza L, auto. Now has a complete wrx motor/ 5speed swap. Used the wrx pedal assembly/ master cylinder. problem is i bled my master/slave cylinder, and my clutch is still sticking the floor..
Thanks for any help
Joshrs is offline   Reply With Quote
Old 10-08-2013, 05:07 PM   #2
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
un bolt the slave cylinder... hold above master cylinder and proceed to bleed.
Cefaln452 is offline   Reply With Quote
Old 10-11-2013, 05:13 PM   #3
Joshrs
Member#: 361863
01 rs
okay i will try bleeding it that way. I think one of my probs is, when i push my clutch in, the rod barley moves to touch the clutch fork. Thinking that may be my problem?
Old 10-11-2013, 05:17 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the clutch fork travel is about an inch.
if the piston rod is not contacting the clutch fork you need
to continue pumping the pedal until you built up enough pressure.
if no pressure you still have air in the lines or bad slave cylinder seal.
how are you bleeding the air out?
Old 10-11-2013, 05:35 PM   #5
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Originally Posted by jaxscuby View Post
you need
This. Go pump it about a hundred times and see if that fixes it.
bushflyr is offline   Reply With Quote
Old 10-11-2013, 08:39 PM   #6
Joshrs
Member#: 361863
01 rs
im bleeding it by. Pumping it about 20 times, hold the clutch pedal half way, then release the valve, and shut it once fluid stops coming. I didnt think there would still be air in the line. Did this alot and only fuild would came out after so long
Old 10-14-2013, 10:19 AM   #7
h2oridr
Member#: 151936
2003 wrx
Sounds like you may have an issue with the clutch fork and throw out bearing. It might not have snapped into it. Is everything assembled correctly? Try removing the slave and using a prybar to put pressure on the fork to get it to snap into the pressure plate.
h2oridr is offline   Reply With Quote
Old 10-14-2013, 10:49 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Take slave off the trans. Use a big c clamp to hold the piston back in. Pump it up and bleed it with the clamp still on there. When the pedal is rock solid, put the slave back on.
Old 10-15-2013, 03:23 PM   #9
DaveSB
Member#: 371010
May need to be power bled. Sometimes one car of the same model can be more difficult than others to get all the air out of the system.
DaveSB is offline   Reply With Quote
