Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 10-22-2012, 05:46 PM   #26
JDwhiteWRX
Member Sales Rating: (1)
Member#: 190502
2005 VF36 WRX
Originally Posted by WRXt4cy View Post
From what I understood from reading through the huge AOS/Catch can thread that is out there is that the top port of the PCV that goes through the white sensor and into the the inlet is always flowing air in the direction from the inlet to the crankcase. Under manifold vacuum, the side port of the PCV has a very strong draw from the intake manifold port that is under the throttle body so this is a source of oil vapor getting into the manifold directly. When I took off my throttle body to install this catch can setup, I could see a pool of oil inside my intake manifold, right below where this port is tapped. When the manifold is under pressure, the PCV closes and the positive pressure causes the air in the crankcase to flow into the heads and out from the top ports on the valve covers.
So the "blow by" comes out of the valve covers during boost and is caught in one catch can. The only other oil vapor present in the breather system is during vacuum and comes from the intake port to PCV connection and this is caught by the other catch can.
Again, this is not my explanation of how the breather system works; this my own understanding from reading through lots of information and I believe it to be accurate. When I was running the G/S AOS, all my oil vapor seemed to come from the heads. The crankcase hose would get oil on the AOS side as if it was drawing from the AOS and picking up some oil vapor so this seems to fit with out the system seems to work. The G/S AOS completely ignores the PCV to intake manifold hose which seems to be the more import crankcase hose to put a catch can on.
Great explanation, thanks! need to do some reading on this.
JDwhiteWRX is offline   Reply With Quote
Old 10-23-2012, 08:39 PM   #27
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I have been thinking about this some more and I am wondering if the catch can between the PCV and intake manifold would get pressurized under boost? sure the valve in the PCV will close but not before the catch can gets pressurized. Maybe its a good idea to install a check valve between the intake manifold and catch can? or maybe its ok to pressurize the catch can?
Actually I think the real solution is to put the can between the block and PCV.
Old 11-27-2012, 11:07 PM   #28
tonyp1974
Member Sales Rating: (2)
Member#: 335826
Anyone know if these will fit on an 02? Ive been looking for a kit to fit on the 02 but I havent found any.
tonyp1974 is offline   Reply With Quote
Old 11-27-2012, 11:49 PM   #29
vision.dynamix
Member Sales Rating: (53)
Member#: 139955
2015 Subaru STI
Stage e
02 kit is coming. They developed them on my car a few months ago.
Old 11-28-2012, 07:11 AM   #30
tonyp1974
Member#: 335826
Ugh....build is happenning now!!
Old 11-30-2012, 10:22 PM   #31
Grippen
Member Sales Rating: (19)
Member#: 329712
2005 Sti
Just build your own catch can set up fellas
Grippen is offline   Reply With Quote
Old 03-21-2013, 08:49 AM   #32
RallySoob
Member#: 74872
2006 STi
White/Black
so is this the best catch system? Better than crawfords heated system? I live in oregon and go snowboarding a lot so the freezing of catch cans is a fear of mine. Will these freeze ? Crawford addressed this issue with heaters as mentioned
Also, crawford Q&A mentions that yellow gunk as seen in your picture above. That is normal. You throw it away. You can read exactly what it is and why on their website
RallySoob is offline   Reply With Quote
Old 03-21-2013, 10:38 AM   #33
jnorth85
Member Sales Rating: (31)
Member#: 76785
2000 580Whp The RSTI
SRP
I Installed this kit in my GC chassis car we will see how it works!
jnorth85 is offline   Reply With Quote
Old 04-01-2013, 08:59 PM   #34
bigusnickus
Member#: 245851
2004 WRX Rally car
How are you guys draining the cans? I installed the 85510 last weekend in preparation for this weekends track time and I can barely get my hand in there to turn the valve, let alone put a bottle or can to catch the fluid. I am thinking of running a hose from each can down and using a drain pan to catch everything.
Thoughts?
bigusnickus is offline   Reply With Quote
Old 04-17-2013, 11:22 AM   #35
12GRSTi
Member#: 353742
12 N/A
N/A
Just had a track day with my Moroso dual catch setup and wanted to post my results. I really beat on the car for 150 miles on the track and this is the result:
My crank vent had a milkshake of slightly yellow crap, and my have been frothy as I checked it right after getting off the track. Anyone know what this junk is, I had no noticeable oil consumption.
The head vent had just a bit of oil, what I would expect.
12GRSTi is offline   Reply With Quote
Old 04-17-2013, 02:57 PM   #36
Jdub.csu
Member Sales Rating: (5)
Member#: 283784
2013 EVO X GSR
Doesn't coolant + oil = milkshake?
Old 04-17-2013, 02:58 PM   #37
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Oil + water of any kind. Condensation, usually, when found in catch cans.
That post reminds me I have 2 Moroso cans full of milkshake sitting in my garage..
Old 04-17-2013, 03:00 PM   #38
12GRSTi
Member#: 353742
12 N/A
N/A
It is an E85 setup, only 13k on it, oil analysis shows no coolant. Probably mostly water vapor.
Old 05-01-2013, 04:17 AM   #39
TyConway
Member#: 193189
2002 wrx
If anyone is looking for this setup, I have a slightly used setup, asking $250 shipped....
Also for sale on ebay user name ( Tyconway 100% feedback 220 plus sells)
TyConway is offline   Reply With Quote
Old 05-20-2013, 09:46 AM   #40
evoq007
Member#: 90875
2013 4dr STi
Just installed this kit this weekend. Relatively involved install. Give yourself 2 hours to install everything and button everything down. Only put on 250miles on the car so far and have not checked the levels. Will do so this week to gauge how often I should empty.
Helpful tip...use a hairdryer to warm the rubber hoses before fitting over barbed lines...makes it easier.
evoq007 is offline   Reply With Quote
Old 05-23-2013, 09:40 PM   #41
12GRSTi
Member#: 353742
12 N/A
N/A
I little silicone lube helps too
Old 05-24-2013, 11:31 AM   #42
castle1977
Member#: 332244
2003 wrx wagon
black
has anyone used these on a 2003 wrx yet? i know they say a kit is in the works, im looking for someone that did a custom install.
castle1977 is offline   Reply With Quote
Old 10-15-2013, 04:04 AM   #43
BJJMark95
Member#: 371004
2013 STi Hatch
I know this thread is a bit old. It I am looking at doing the moroso aos in my sti and was simply wondering if I could get some feedback on the difficulties of emptying each system? The small cans and the large cans? It would appear to me at first glance that the small cans would be because they give a bit more room to work. However they do have to be unscrewed so this was my concern.
Thank you for this thread tho. This is all great information and reviews and pretty much sold me on the Moroso system over the Crawford.
BJJMark95 is offline   Reply With Quote
Old 10-15-2013, 08:47 AM   #44
12GRSTi
Member#: 353742
12 N/A
N/A
With the stock intercooler, you will have to have a bit of dexterity to empty the catch cans, but it is not an impossible task. I find it easiest to stand on the passenger side and use my left hand palm facing me to slide down and grab the knurled side of the catch cans to get them started. When you tighten them up back them off just a fraction of a turn so they are easier to remove later.
With a bit of practice you can easily remove and check both cans while the car is fueling up at a pump.
If you have a Grimspeed intercooler you get a lot more room to work with and it is a pice of cake. Same goes for front mount.
I am not sure which you consider to be the small or the large ones, but the 85510 is just the right size for me in consideration to both ease of accessing them and having enough capacity to not have to empty them all the time.
Old 10-25-2013, 05:23 AM   #45
BJJMark95
Member#: 371004
2013 STi Hatch
Thank you - yes the ones I am looking at are I believe they say 25-30% smaller and are the 85645s
Old 12-11-2013, 04:15 PM   #46
Clinically_ill
Member Sales Rating: (8)
Member#: 356436
These cans are beautiful... I've been looking into ventilation systems for my motor build and these seem like the best choice. Awesome baffling & separate cans for crank case/heads. I need to get me a set of these.
I would be possible to get AN fittings and run braided lines since I'm getting AN fittings installed on my heads & block. WIIICKED.
Clinically_ill is offline   Reply With Quote
Old 03-19-2014, 03:01 PM   #47
elevenbravo
Member#: 372475
2015 STI
CWP
I've been watching the top mount 08+ kit, and finally pulled the trigger today when I saw it on Amazon for $255.
Moroso 85645 Air and Oil Separator for Subaru STI : Amazon.com : AutomotiveMoroso 85645 Air and Oil Separator for Subaru STI : Amazon.com : Automotive
elevenbravo is offline   Reply With Quote
FS (OR): Impreza WRX STi Dual Catch Can setup wrxridah Engine/Power/Exhaust 7 05-20-2010 07:42 PM
EJ207 Dual Catch Can Setup iNfEk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-08-2009 10:38 PM
Perrin Dual Catch Can setup 1/2" ID hoses aboothman Engine/Power/Exhaust 3 01-08-2009 04:10 PM
FS: NM - Dual Catch Can Setup (Complete!) j87w Engine/Power/Exhaust 18 11-18-2007 01:01 PM
WTB: Boost Gauge & Dual Catch Can Setup GHott Private 'Wanted' Classifieds 0 07-20-2007 09:37 AM
