Old 09-30-2013, 01:43 PM   #1
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Default Lean part-throttle between 0-10psi at lower RPMs
I recently got my motor together and running well and got it tuned. During daily driving I'm noticing a flat spot when I start transitioning into boost. For example, I'll be cruising along at 40mph in 4th gear on a backroad at about 2800rpm and come to a slight grade, so I'll give it a little bit more gas.... light boost will start to build and I'll notice my AFRs go to around 15.5 and the car will lightly stutter a bit. If I get into the throttle more, it'll build heavier boost and the AFRs will drop into line at about 13-12-11 depending on how much throttle I give it. It's the part-throttle cruising conditions that really annoy me because that's 98% of what the car sees as a daily driver.
Before pestering my tuner about this, I wanted to rule out mechanical issues first. I was wondering if it could be due to a bad MAF, front O2 sensor, MAP sensor, etc, etc... Does anyone have any input on this issue and how to diagnose it? Thanks very much for you any help! I'm great at mechanics but a novice at tuning so forgive me if I sound ignorant. I do have a Tactrix 2.0 and ECU flash and RomRaider software.
Car details: 1998 Legacy GT swapped to EJ257 block, B25 heads, plugged B25 cams, no AVCS, 2002 WRX wiring harness and ECU, SPT intake, Bosch 1000cc injectors, TGV deletes, VF48 turbo, catless 3" exhaust, v7 6sp, STi top mount.
Soarer is offline   Reply With Quote
Old 10-07-2013, 12:07 AM   #2
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Interesting development... I cleaned my MAF and now it's running waaaay rich. My AFR gauge is going to 10.0 full rich when I get on it... Hmmmmm
Old 10-14-2013, 11:38 AM   #3
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Anyone got any ideas on this? I was running a bit lean under light boost, then cleaned the MAF and now I'm running way rich under boost. Is this a tuning problem (i.e. the car was tuned with a dirty MAF and the scaling was off to compensate for the MAF being dirty, now it's clean and things are going haywire) or could this be a mechanical problem such as a bad MAP sensor or fouled O2 sensor???
Also, I don't know if this is related or not but I get a small backfire during easy driving conditions when I shift. I've never heard it when I'm getting on the car in heavy boost but when I'm just leisurely driving around under light loads, I'll shift and occasionally hear a "pop" from the motor like unburnt fuel igniting.
Old 10-15-2013, 08:01 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
Did you remove the maf to clean it ?
sidewayz is offline   Reply With Quote
Old 10-15-2013, 09:55 AM   #5
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Sounds like a post turbo boost leak.
Old 11-27-2013, 09:54 PM   #6
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
If it was a boost leak ( inherently post turbo ), it would run rich under any sort of boost. I would imagine that the tuner would have noticed that his pre defined map for ur intake wasn't taking kindly to your car ( if the maf was a big problem ). Try unplugging the maf and taking it for a cruise. Don't go into heavy boost or anything, but feel out that low throttle boost range. Report back as to whether or not it feels any better.
BeastianSTI is offline   Reply With Quote
Old 11-27-2013, 09:57 PM   #7
BeastianSTI
Member#: 310506
2005 WRX STi
I'm thinking you may have either a faulty maf sensor or front a/f sensor.
Old 12-02-2013, 03:08 PM   #8
BeastianSTI
Member#: 310506
2005 WRX STi
Any updates on this mate? For all the other scoobies out there.
