Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 09-12-2013, 07:16 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default Need a new seat for the rally car
I am a really skinny guy, 176cm height and 55kgs of weight - yeah, like a spare wheel
The only seat I've been ever comfortable in is Sparco Prodrive
This year my seat expires and I have not seen another seat that would be the same size
What are my options?
Gaining weight is not an option, I've been trying that for past 5 years
Hyper is online now   Reply With Quote
Old 09-12-2013, 10:30 AM   #2
sureshot007
Member#: 142405
#716 G2 OBS
I don't think there are many options for someone of your size. The last time I was 120lbs, I think I was 10. Have you considered adding some extra padding to the seats?
Off topic - is that a picture of your car? Where do you rally that they allow a bolt in cage?
sureshot007 is offline   Reply With Quote
Old 09-12-2013, 11:01 AM   #3
delongedoug
Member#: 124113
and beyond!
MOCKBA, duh.
delongedoug is offline   Reply With Quote
Old 09-12-2013, 11:07 AM   #4
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
no, that's just some random pic I found on google
this is a picture of my car
...MOCKBA, duh.
Old 09-12-2013, 11:14 AM   #5
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Since you fit well in a sparco, get a sparco.....
rjrutzky is offline   Reply With Quote
Old 09-13-2013, 06:16 PM   #6
Deuce Cam
Member#: 130444
'85 AE86 GTS
Status Ring and Bride Zeta 3 are pretty darn small. Recaro pole position and even profi spg will be too big.
Deuce Cam is offline   Reply With Quote
Old 09-14-2013, 10:07 AM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
needs to be fia approved
Old 09-14-2013, 02:02 PM   #8
blubug_768
Member#: 324962
02 WRX
doesn't putting a brace in allow you to run expired seats? And you can try to send them back to sparco for an inspection to buy an extra few years.
blubug_768 is offline   Reply With Quote
Old 09-14-2013, 11:13 PM   #9
Jim_Rippy
Member#: 188709
www. facebook.com/
revolutionarysports
Take a look at Racetech seats, fits my skinny codriver well. We use the RT1000's.
http://racetech-usa.com/shop/
Jim_Rippy is offline   Reply With Quote
Old 09-15-2013, 04:46 AM   #10
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
looking at dimensions, rt1000 is bigger than even sparco s-light
Old 09-15-2013, 08:21 AM   #11
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I'd second Racetech, but if none look like they're thin enough...
I really like mine. The thing I like about them most compared to the Sparco seats I tried is the the seat base is a bit longer. I'm 6' 1" so that was important for me.
mav1c is offline   Reply With Quote
Old 09-15-2013, 11:09 AM   #12
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Older Sparco Circuit
Jard is offline   Reply With Quote
Old 09-15-2013, 01:43 PM   #13
Aceyduce
Member#: 194449
2011 Mazda, 2003 WRX
Black , WRB
Looked into Cobra seats? I run the suzuka pro wides and am 160 lbs at 6'2", 32" waist.
Aceyduce is offline   Reply With Quote
Old 09-15-2013, 03:43 PM   #14
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
nope, will check it out
Old 09-20-2013, 02:46 PM   #15
rally-fast
Member#: 121857
2014 Impreza WRX
I thought the Prodrive by Sparco used the same shell as the Sparco Corsa. Yes? No?
rally-fast is offline   Reply With Quote
Old 09-20-2013, 02:48 PM   #16
rally-fast
Member#: 121857
2014 Impreza WRX
Sparco dimension data chart for all their seats: http://subesports.com/data/sparco_seat_dim.pdf
Old 10-15-2013, 03:32 PM   #17
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I owned Sparco Corsa and it was way bigger than Prodrive
after extensive research, I went with Sparco REV - smallest FIA seat with working homologation that is offered today
way less comfortable, and requires a different seating position - more straight up due to lack of leg support compared to Prodrives
however I do like the nice curve for HANS
Old 10-15-2013, 04:19 PM   #18
WhatTurboLag?
Member#: 243992
2006 WRX TR
Good, now you should give me your pro drives
WhatTurboLag? is offline   Reply With Quote
Old 10-15-2013, 04:32 PM   #19
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I can sell you one, but you will have to come to Moscow to pick it up
Old 10-16-2013, 05:39 PM   #20
WhatTurboLag?
Member#: 243992
2006 WRX TR
Aw just ship it!
Although, I do really want to visit Moscow.
Old 10-16-2013, 11:41 PM   #21
Rokkit
Member#: 84181
NASA #530 GTS2
Are you sure it even matters if the seat expired? In NASA/SCCA road racing (wheel to wheel) you just need a back brace for the seat with a load spreading plate and you can continue to use it. All people do is weld a 5x12" sheet of steel to a 1-3/4 DOM tube and bolt it to the harness bar behind the cage with the roll cage clamp.
Rokkit is offline   Reply With Quote
Old 10-17-2013, 04:48 AM   #22
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
domestic regulations
Old 10-20-2013, 11:07 AM   #23
Dilan34
Member#: 370594
You can see here http://autoline-eu.co.uk, usually there is a great choice of both new accesories and used ones.
Dilan34 is offline   Reply With Quote
Old 10-22-2013, 03:47 PM   #24
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Sparco Circuit for sure. Tinest seat I have ever sat in, I am squeezed in there tight.
MConte05 is online now   Reply With Quote
Old 12-15-2013, 12:19 PM   #25
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
you were right
I wasn't really digging the REV, so tried Circuit - LOVED it and bought it!
