Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 10-15-2013, 03:24 PM   #1
ftnjun2x
Member#: 107096
04 WRX
Default humming noise 04 WRX
Sounds like it's coming from passenger side. It hums in any gear, speed, on neutral or whenever the car is rolling.
I turned off the engine, put it on neutral while moving and was still there.
I need help, i just replaced the timing belt last weekend, thought it was the problem.
ftnjun2x is offline   Reply With Quote
Old 10-15-2013, 04:23 PM   #2
sg_halvorsen
Member#: 201924
98 Forester with a
full wrx drivetrain swap
Well seems like you ruled out engine noise. Next step would be bearing or transmission. Does the noise change when going around turns. Bearings usually isn't a humming noise but it could be that they are starting to go. Could also be something in your transmission/center diff. This might be better suited in the transmission & drivetrain section.
sg_halvorsen is offline   Reply With Quote
Old 10-15-2013, 04:35 PM   #3
GrimmSpeed
Member#: 136396
2013 BRZ
It could be anything rotating or spinning. Try jacking the car up on the right side and inspect the wheel&tires/bearings/axles ect.
Mike
