Old 11-08-2012, 11:41 PM   #51
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Enjoy it while it lasts!!!
punchjamesarnol is offline   Reply With Quote
Old 11-29-2012, 02:15 PM   #52
RancerEvorution
Member#: 235190
2011 STi
didn't know you had a built bottom end
RancerEvorution is offline   Reply With Quote
Old 11-29-2012, 02:51 PM   #53
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
Now I do.
Ringlands
4Warned is offline   Reply With Quote
Old 11-29-2012, 03:15 PM   #54
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Been there done that!
My EJ255 lasted 126K and gave me 150psi compression and 10,10,10,5% leak down, so I figured it's worth a try to make big VF power or bust. I then pushed it a bit too hard after a Junior E85 tune making 450 WTQ & 360 WHP. My stock STI clutch hated it anyway. Not that Juniors tune was bad, I'm not saying that at all but you gotta pay to play as the saying goes
Old 11-29-2012, 03:37 PM   #55
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Built motor FTW!!!
ckyguy68 is offline   Reply With Quote
Old 11-29-2012, 05:51 PM   #56
manitou
Member#: 193757
2006 XTI Limited
Yes sir, MPS long rod 2.5 with PnP'd, D25, Super Tech big valve train, Kelford R199B cam heads FTW for me!!
Old 11-30-2012, 04:36 PM   #57
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Subscribed.
Good luck guys!!
Squidz is offline   Reply With Quote
Old 11-30-2012, 05:07 PM   #58
4Warned
Member#: 66092
2011 STi sedan
Originally Posted by Squidz View Post
Subscribed.
Good luck guys!!
Thanks Squidz
I told DJC I would knock out his E85 time on pump and I will be sure that happens!
Old 12-05-2012, 12:21 PM   #59
IPSracing
Member#: 339758
Good numbers
IPSracing is offline   Reply With Quote
Old 12-05-2012, 08:53 PM   #60
Squidz
Member#: 142608
2003 Sonic Yellow
Originally Posted by 4Warned View Post
Thanks Squidz
Can't wait...I'm really considering putting my HTA71 on my wife's car and going back to a smaller turbo on mine.
Wondering if something like what you guys have done here is even possible without AVCS.
Old 12-06-2012, 12:12 AM   #61
manitou
Member#: 193757
2006 XTI Limited
I've got a Dom 3.5xtr on my MPS motor and it feels very quick spooling on my breakin map. Can't wait to tune it with Junior on the 17th! In keeping with this thread I'm keeping one of my VF48s with the PnPd & welded WG hot side to put back on my XTI at some point. I think it will be fun! We will see.
Old 12-06-2012, 10:14 AM   #62
manitou
Member#: 193757
2006 XTI Limited
Thanks Squidz
Yeah bro bring the record to Michigan! Please keep me in the loop when you hit the track in the spring! I'm sure that Layvon and I would show up for support!
Old 12-06-2012, 04:21 PM   #63
4Warned
Member#: 66092
2011 STi sedan
Pump gas record is already in MI with my 12.0 passes
It has been 11's or bust since I started with this car last year. Once that is in the books I am going after JR's 11.4 on E85 record.
Old 12-06-2012, 04:44 PM   #64
HonduhPowa
Member#: 269076
2012 Wrx
****'s weak!
Jk Darius, i <3 you car. (It's Cody btw)
HonduhPowa is offline   Reply With Quote
Old 12-06-2012, 06:08 PM   #65
manitou
Member#: 193757
2006 XTI Limited
I wanna see both 11s on pump and all VF record low low 11 on E85! I may have to challenge at some point with the VF48 on my XTI but I'm having fun with the Dom 3.5 right now and after Juniors tune it might be hard to go back to the VF! I'd be spotting you 150 lbs it whatever!
Either way good job on your car! I love what you're doing!!
Old 05-25-2013, 07:21 PM   #66
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
[email protected] mph, best MPH is around 118.. Backed up the pass 4-5 times as well. I think a new thread will be made.
Congrats Mr. Warned!
Old 05-25-2013, 08:07 PM   #67
manitou
Member#: 193757
2006 XTI Limited
Right on DW! Good job!
Old 05-27-2013, 11:54 PM   #68
giantbrandon
Member#: 329666
2008 Liberty sti
what temps where at the track?
giantbrandon is offline   Reply With Quote
Old 10-15-2013, 04:01 PM   #69
BoostinChick
Member#: 218971
2007 WRX
...and threads like this is why I picked myself up a VF48! Other than a built bottom end, mods will be similar for pump gas. I may ping JR as well to set me up once I get this installed. If I can crack 300 that would make my happy. And over 400tq must be neck snapping.
BoostinChick is offline   Reply With Quote
Old 10-15-2013, 04:36 PM   #70
Back Road Runner
Member#: 60082
2004 Forester STI
How do you make 100 more ft-lbs than everyone else? That's not a minor feat and seems, well, unbelievable. I don't know where it comes from for 23psi on 93 octane. At the same time your HP is normal as that is just an air flow limit of the turbo. I just don't get how you get the torque without a significant bump in displacement or boost. I would expect north of 30psi to see that kind of torque number or an engine around 3.0L running 23psi to generate that kind of torque number. I can only scale to what I've seen from my own vehicle though. I've done 23psi on 93 octane and E85 also. I just can't fathom the combustion chamber difference to support 400 wheel torque. I mean all you can add is timing, and that won't net you 100 ft-lbs alone. You're still stuck with the same amount of burnable product that everyone else is only making 300 ft-lbs with.
I don't know. It confuses me. I could say it's lower friction losses, but your HP is normal. I don't know how you get significantly more air/fuel into the combustion chamber and likely a lot more timing without knock at similar parts and psi as other people.
Junior knows his stuff though. I just can't fathom the trickery he's doing to make that kind of torque without significantly more displacement or boost. I mean we're not talking 10-20 ft-lbs here. 100 ft-lbs is huge. Whatever Junior's doing, it's crazy good. I just don't know what everyone else is doing wrong.
Back Road Runner is offline   Reply With Quote
Old 10-15-2013, 04:38 PM   #71
Back Road Runner
Member#: 60082
2004 Forester STI
Step one is to upgrade the clutch. That and you're pretty much sticking to a 6-speed only by this point.
Old 10-15-2013, 05:41 PM   #72
BoostinChick
Member#: 218971
2007 WRX
I have an ACT clutch and built trans with PAR gearing. I think I will be okay in that department
Old 10-15-2013, 08:25 PM   #73
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
How do you make 100 more ft-lbs than everyone else? That's not a minor feat and seems, well, unbelievable. I don't know where it comes from for 23psi on 93 octane. At the same time your HP is normal as that is just an air flow limit of the turbo. I just don't get how you get the torque without a significant bump in displacement or boost. I would expect north of 30psi to see that kind of torque number or an engine around 3.0L running 23psi to generate that kind of torque number. I can only scale to what I've seen from my own vehicle though. I've done 23psi on 93 octane and E85 also. I just can't fathom the combustion chamber difference to support 400 wheel torque. I mean all you can add is timing, and that won't net you 100 ft-lbs alone. You're still stuck with the same amount of burnable product that everyone else is only making 300 ft-lbs with. I don't know. It confuses me. I could say it's lower friction losses, but your HP is normal. I don't know how you get significantly more air/fuel into the combustion chamber and likely a lot more timing without knock at similar parts and psi as other people. Junior knows his stuff though. I just can't fathom the trickery he's doing to make that kind of torque without significantly more displacement or boost. I mean we're not talking 10-20 ft-lbs here. 100 ft-lbs is huge. Whatever Junior's doing, it's crazy good. I just don't know what everyone else is doing wrong.
I made 420 wtq all day long on 25-26 psi on VF39. I tuned it myself and there was no magic involved. IIRC timing was at 10 degrees at peak boost with 10.8-11.0 AFR. if he isn't cranking up the boost then he has to be adding timing and I would think he also changes AVCS.
bswilmington is offline   Reply With Quote
Old 10-15-2013, 08:47 PM   #74
manitou
Member#: 193757
2006 XTI Limited
10-4 on that! Jr. had my XTI with the VF48 making 450wtq and it made it by 3100. It was a ****ing rocket! A bit short legged but it got up to speed quickly!! LOL
Old 10-16-2013, 01:32 PM   #75
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
whoa. I can only imagine...
SlimJim8804 is offline   Reply With Quote
