Old 01-12-2013, 11:56 PM   #1
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Default 05 STI Tuning Problems ECUFLASH
Im having troubles with EcuFlash reading my current rom. I can use Romraider and log fine, however EcuFlash Is not connecting to the car correctly. I keep getting error codes
[13:13:37.185] EcuFlash Version 1.44.3721
[13:13:37.185] OS Version Windows 7
[13:13:37.185] Qt Version 4.8.0
[13:13:37.185] 63 memory models read.
[13:13:37.185] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[13:13:37.465] 611 ROM metadata models scanned.
[13:13:37.465] checksum module "subarudbw" loaded.
[13:13:37.465] checksum module "mitsucan" loaded.
[13:13:37.465] checksum module "mitsuh8" loaded.
[13:13:37.465] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:13:37.465] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:13:37.465] flashing tool "wrx02" loaded.
[13:13:37.465] flashing tool "wrx04" loaded.
[13:13:37.465] flashing tool "sti04" loaded.
[13:13:37.465] flashing tool "sti05" loaded.
[13:13:37.465] flashing tool "mitsukernel" loaded.
[13:13:37.465] flashing tool "mitsukernelocp" loaded.
[13:13:37.465] flashing tool "mitsubootloader" loaded.
[13:13:37.465] flashing tool "shbootmode" loaded.
[13:13:37.465] flashing tool "shaudmode" loaded.
[13:13:37.465] flashing tool "subarucan" loaded.
[13:13:37.481] flashing tool "subarucand" loaded.
[13:13:37.481] flashing tool "mitsucan" loaded.
[13:13:37.481] error loading FTD2XX.DLL
[13:13:37.497] J2534 API Version: 04.04
[13:13:37.497] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.497] Device Firmware Version: 1.12.3688
[13:13:37.497] Device Serial Number: TAyv9EHc
[13:13:37.497] interface close
[13:13:37.528] J2534 API Version: 04.04
[13:13:37.528] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.528] Device Firmware Version: 1.12.3688
[13:13:37.528] Device Serial Number: TAyv9EHc
[13:13:37.528] interface close
[13:13:37.559] J2534 API Version: 04.04
[13:13:37.559] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.559] Device Firmware Version: 1.12.3688
[13:13:37.559] Device Serial Number: TAyv9EHc
[13:13:37.559] interface close
[13:14:25.201] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[13:14:25.217] J2534 API Version: 04.04
[13:14:25.217] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:25.217] Device Firmware Version: 1.12.3688
[13:14:25.217] Device Serial Number: TAyv9EHc
[13:14:32.712] kernel get version
[13:14:32.915] interface close
[13:14:32.946] J2534 API Version: 04.04
[13:14:32.946] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:32.946] Device Firmware Version: 1.12.3688
[13:14:32.946] Device Serial Number: TAyv9EHc
[13:14:33.399] VIN: JF1GD70645L512954
[13:14:33.523] CVN: 2A0086B4
[13:14:33.617] interface close
[13:14:33.648] J2534 API Version: 04.04
[13:14:33.648] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:33.648] Device Firmware Version: 1.12.3688
[13:14:33.648] Device Serial Number: TAyv9EHc
[13:14:33.820] SSM2 init
[13:14:33.960] SSM2 ECU ID is 3D12594006
[13:14:34.038] Requesting Seed...
[13:14:34.085] Sending Key...
[13:14:34.132] interface close
[13:14:34.147] interface close
[13:15:25.900] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[13:15:25.916] J2534 API Version: 04.04
[13:15:25.916] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:25.916] Device Firmware Version: 1.12.3688
[13:15:25.916] Device Serial Number: TAyv9EHc
[13:15:28.218] kernel get version
[13:15:28.421] interface close
[13:15:28.452] J2534 API Version: 04.04
[13:15:28.452] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:28.452] Device Firmware Version: 1.12.3688
[13:15:28.452] Device Serial Number: TAyv9EHc
[13:15:28.904] VIN: JF1GD70645L512954
[13:15:29.029] CVN: 2A0086B4
[13:15:29.123] interface close
[13:15:29.154] J2534 API Version: 04.04
[13:15:29.154] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:29.154] Device Firmware Version: 1.12.3688
[13:15:29.154] Device Serial Number: TAyv9EHc
[13:15:29.326] SSM2 init
[13:15:29.466] SSM2 ECU ID is 3D12594006
[13:15:29.544] Requesting Seed...
[13:15:29.591] Sending Key...
[13:15:29.638] interface close
[13:15:29.653] interface close
If someone could help me out, that would be greatly appreciated.
Eddie at PNR is offline   Reply With Quote
Old 01-13-2013, 07:33 AM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Try running an older version of the software, OR, try reading your Rom off the ecm, then writing it directly back in. See if its a Rom code error.
Old 01-13-2013, 08:13 AM   #3
bmx045
Member#: 262684
2015 Impreza Sport
ISM
are you using a tactrix? if so did you install the tactrix J drivers listed on the site? install those first, then ecuflash, when prompted for openport install during ecuflash install, click cancel.
bmx045 is offline   Reply With Quote
Old 01-13-2013, 12:17 PM   #4
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Will do
Old 01-13-2013, 12:17 PM   #5
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Will try that Monday, thanks.
Old 01-13-2013, 12:18 PM   #6
Eddie at PNR
Member#: 332016
1999 Swapped GM6
And yes Im using a tactrix
Old 01-14-2013, 09:48 AM   #7
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Anyone got any pointers? I've replaced the previous ECM due to it being bricked by the previous owner. Everything else connects besides ECUFLASH
Old 02-07-2013, 12:05 AM   #8
ccbremech
Member#: 286915
2004 STI
BLUE
i am having the same issue. I can datalog the ECU but cannot read it. To makes things worse, my car will no longer start. Im guessing i have an ECUTek Locked ECU
ccbremech is offline   Reply With Quote
Old 02-07-2013, 09:18 AM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
did you disconnect romraider
Old 02-07-2013, 10:13 AM   #10
Beast Leg
Member#: 281868
1995 Lego
Beast Mode Black
ive got the same problem with my new-to-me 02 wrx. im trying to read the ecu, and then force readiness to pass my inspecting that is due... but i cant even get ECUflash to work.
the ECUflash software is bouncing this stuff back at me:
[08:18:35.726] EcuFlash Version 1.44.3721
[08:18:35.726] OS Version Windows 7
[08:18:35.726] Qt Version 4.8.0
[08:18:35.726] 63 memory models read.
[08:18:35.726] scanning for metadata models in C:/Users/ECU Flash/EcuFlash/rommetadata
[08:18:35.836] 612 ROM metadata models scanned.
[08:18:35.836] checksum module "subarudbw" loaded.
[08:18:35.836] checksum module "mitsucan" loaded.
[08:18:35.836] checksum module "mitsuh8" loaded.
[08:18:35.836] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[08:18:35.836] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[08:18:35.836] flashing tool "wrx02" loaded.
[08:18:35.836] flashing tool "wrx04" loaded.
[08:18:35.836] flashing tool "sti04" loaded.
[08:18:35.836] flashing tool "sti05" loaded.
[08:18:35.836] flashing tool "mitsukernel" loaded.
[08:18:35.836] flashing tool "mitsukernelocp" loaded.
[08:18:35.836] flashing tool "mitsubootloader" loaded.
[08:18:35.836] flashing tool "shbootmode" loaded.
[08:18:35.836] flashing tool "shaudmode" loaded.
[08:18:35.836] flashing tool "subarucan" loaded.
[08:18:35.836] flashing tool "subarucand" loaded.
[08:18:35.836] flashing tool "mitsucan" loaded.
[08:18:35.836] error loading FTD2XX.DLL
[08:18:40.874] J2534 error [ERR_TIMEOUT].
[08:18:40.874] J2534 error [unable to open device].
[08:18:59.092] using metadata XML ID read_wrx02 from file C:/Users/ECU Flash/EcuFlash/rommetadata/read templates/read_wrx02.xml
[08:18:59.107] J2534 error [unable to open device].
[08:18:59.107] unable to connect to vehicle interface.
[08:18:59.107] interface close
[08:19:09.323] using metadata XML ID read_wrx02 from file C:/Users/ECU Flash/EcuFlash/rommetadata/read templates/read_wrx02.xml
[08:19:14.359] J2534 error [ERR_TIMEOUT].
[08:19:14.359] unable to connect to vehicle interface.
[08:19:14.359] interface close
any ideas?
Beast Leg is offline   Reply With Quote
Old 02-07-2013, 10:53 AM   #11
cranberryumyum
Member#: 275456
what is your voltage? what model tactrix cable? had the same issue, and it turned out to be a combination of voltage being out of range because my battery is oversized and a 1.3 tactrix
cranberryumyum is offline   Reply With Quote
Old 10-15-2013, 09:42 PM   #12
Toadz
Member#: 262903
I'm having the same issue. Can data log with RomRaider but can't do anything with EcuFlash. Here's what EcuFlash is showing when opened:
[20:40:23.215] EcuFlash Version 1.44.3721 [20:40:23.215] OS Version Windows 7
[20:40:23.215] Qt Version 4.8.0
[20:40:23.226] 63 memory models read.
[20:40:23.226] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru
[20:40:23.538] 436 ROM metadata models scanned.
[20:40:23.538] checksum module "subarudbw" loaded.
[20:40:23.538] checksum module "mitsucan" loaded.
[20:40:23.538] checksum module "mitsuh8" loaded.
[20:40:23.538] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[20:40:23.539] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[20:40:23.541] flashing tool "wrx02" loaded.
[20:40:23.543] flashing tool "wrx04" loaded.
[20:40:23.545] flashing tool "sti04" loaded.
[20:40:23.546] flashing tool "sti05" loaded.
[20:40:23.547] flashing tool "mitsukernel" loaded.
[20:40:23.547] flashing tool "mitsukernelocp" loaded.
[20:40:23.547] flashing tool "mitsubootloader" loaded.
[20:40:23.547] flashing tool "shbootmode" loaded.
[20:40:23.548] flashing tool "shaudmode" loaded.
[20:40:23.550] flashing tool "subarucan" loaded.
[20:40:23.552] flashing tool "subarucand" loaded.
[20:40:23.555] flashing tool "mitsucan" loaded.
[20:40:23.556] error loading FTD2XX.DLL
[20:40:23.577] J2534 API Version: 04.04
[20:40:23.577] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[20:40:23.577] Device Firmware Version: 1.12.3688
[20:40:23.577] Device Serial Number: TAT713Or
[20:40:23.578] interface close
[20:40:23.606] J2534 API Version: 04.04
[20:40:23.606] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[20:40:23.606] Device Firmware Version: 1.12.3688
[20:40:23.606] Device Serial Number: TAT713Or
[20:40:23.607] interface close
[20:40:23.634] J2534 API Version: 04.04
[20:40:23.634] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[20:40:23.634] Device Firmware Version: 1.12.3688
[20:40:23.634] Device Serial Number: TAT713Or
[20:40:23.636] interface close
I've done a ton of searching and believe I have tried nearly everything. When I click on Read From ECU it brings up the box for Make, Market, Model, etc. but it's all blank with no choices.
*Update* Downloaded EcuFlash on a laptop at work and it worked just fine. Still had the "error loading FTD2XX.DLL" but from my research that has no effect on it.
Toadz is offline   Reply With Quote
Old 10-17-2013, 02:14 PM   #13
mikeyPSF
Member#: 236475
any ideas?
I'm guessing that you aren't using an OpenPort cable, which means you're trying to work with unsupported hardware. If you are trying to use an OpenPort cable, contact us at support at tactrix dot com and we'll help you get this working.
Yep, you can ignore the FTD2XX.DLL error since that relates to our old 1.3 hardware version. If you'd like to figure out why it wasn't working on the other laptop, contact me at support at tactrix dot com and we'll get you up and running. We have some issues with Windows Vista because of the way the device drivers are structured as compared to every other version of Windows, but Windows 7 shouldn't be a problem at all. Happy to help you get that sorted.
mikeyPSF is offline   Reply With Quote
Old 10-17-2013, 09:17 PM   #14
Toadz
Member#: 262903
That's the odd part, both laptops are using Windows 7. Is there a complete list of drivers the EcuFlash and OpenPort use? When I uninstalled it (several times) I uninstalled all the drivers also. I'm wondering if maybe there is one not so obvious driver that I missed because when I reinstall EcuFlash it still has my old settings for the folders saved.
Old 10-17-2013, 10:58 PM   #15
Eddie at PNR
Member#: 332016
1999 Swapped GM6
If you are still having troubles connecting through EcuFlash. Have you considered the possibility that the ECU is married to a Accessport or EcuTeK? Also, just for reference, do you have the green test mode connectors connected when you try to pull your rom(tune) from the car? You need to have them connected when uploading and downloading tunes.
-Eddie
Old 10-18-2013, 12:45 AM   #16
Toadz
Member#: 262903
-Eddie
In one of my previous posts I updated that it worked on my work laptop. It's something to do with my laptop as I was able to pull my map off the ECU no problem with the other one. I am also able to log with RomRaider perfectly fine on the laptop that EcuFlash doesn't work on.
