Old 09-01-2013, 07:48 PM   #51
darthalal
Member#: 114208
2007 MINI Cooper S
Grumpy Old Man Tan (SSM)
Originally Posted by Freeagnt54 View Post
Those screws are going to rust the first time you get them wet. I recommend getting some stainless steel button head screws. You can get them at hardware stores.
Hmm - I was afraid that might happen. I saw the SS ones, but I didn't want them to show so much (shiny!) so I thought I'd give the black a try. Luckily, the hard part is done, so if these do rust, I should be able to swap them out fairly easily, and I'll give those a try - Thanks!
darthalal is offline   Reply With Quote
Old 09-03-2013, 07:43 AM   #52
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I am surprised that no vendor actually makes this lip....Im sure it would look good on a 04/05 as well.
shamrock 05 is offline   Reply With Quote
Old 09-03-2013, 09:24 AM   #53
Zachbiz
Member#: 331281
car car
You know mine are countersunk and they work absolutely fine. No cracking or anything.
Zachbiz is offline   Reply With Quote
Old 09-03-2013, 01:24 PM   #54
darthalal
Member#: 114208
2007 MINI Cooper S
Impreza WRX
I did this with mechatricity in his garage, and his girlfriend has an 04. I held the strip up to her bumper before we attached it to mine and it definitely looks great there, too.
Did you drill countersunk holes, it just normal holes and let the screw compress itself in? Maybe I should have asked that before starting, haha.
Old 09-03-2013, 01:31 PM   #55
mustafaluigi
Member#: 354986
2013 WRX
Crystal Black Silica
You can get black SS screws from McMaster-Carr that wouldn't rust. You can get them in a flat head, button head or socket head styles as well.
http://www.mcmaster.com/#socket-head-cap-screws/=ockcyq
mustafaluigi is offline   Reply With Quote
Old 09-03-2013, 01:36 PM   #56
Zachbiz
Member#: 331281
car car
I used an actual countersink drill bit. Worked like a charm ad didn't drill too far
Old 09-05-2013, 06:17 AM   #57
shamrock 05
Member#: 120057
I have seen that japanparts.com (I think) sells this lip but they sell it as a rubber strip, but even for that I think its alot of monies. I def like this home made lip tho. I would like to find some poly to make it our of that way it can still felx and not rip off like the OP's did at first.
Old 09-05-2013, 11:07 AM   #58
lvlatthew
Member#: 336712
2002 bugeye wrx
Anyone know how this holds up in snow? . Like backing out of your driveway is it going to want to pull off the bumper? I could see it being like a plow and just dragging all the snow :/
lvlatthew is offline   Reply With Quote
Old 09-05-2013, 11:57 AM   #59
Zachbiz
Member#: 331281
car car
They do well something similar but it is for the burn up wrc replica 04 bumper only.
I've caught this lip on driveways and curbs backing out. It makes an awful noise but doesn't rip off. Especially if you use proper countersunk bolts. Everything just flexes. And I doubt it would even flex with some snow. It's pretty sturdy.
Old 09-08-2013, 03:53 PM   #60
volkld
Member#: 359694
2012 Forester XT Prm
Has anyone done this to their 08 and up subies?
volkld is offline   Reply With Quote
Old 09-08-2013, 07:26 PM   #61
biznasty44
Member#: 275131
2005 WRX (AW)
2007 CBR1000rr Boosted!!
Definitely like the way that looks
biznasty44 is offline   Reply With Quote
Old 09-09-2013, 06:58 PM   #62
Drewbaru2002
Member#: 332254
2002 Impreza 2.5RS
Platinum Silver Metallic
Looks great and makes for a great DIY project!
Drewbaru2002 is offline   Reply With Quote
Old 09-12-2013, 07:55 PM   #63
Skibum101
Member#: 265502
2008 5 Door WRX
Rally Blue
Took a look at my08 premium. looks like the same design would work. I'll need to get some L brackets to support it though. I think if you drilled into the bumper along the sides and mounted upside down L brackets in the middle you could get a consistent mounting all the way across. If you lined it up to where the bumper straightens out and sanded it so it blends better it could look good too.
Might do it in the next week or 2. Little scared of drilling into the bumper. Anyone know a less permanent solution? Maybe involving the industrial strength velcro chilling in my garage or other undoable attachment methods. (toolbox clips and zap straps perhaps...)
Anyone have any cool ideas about how to trim/fold the bottom to make it look better/cooler/cleaner?
Next question is self tappers or nylon nuts and bolts?
And last one... did you pre-drill the holes in the lip before clamping it to the car?
Skibum101 is offline   Reply With Quote
Old 09-12-2013, 08:09 PM   #64
kwikside
Member#: 107888
2003 Impreza WRX
You might be able to get away with this: instead of drilling, but it will also add a little material between the bumper and lip so it might not blend as well.
linklink
kwikside is offline   Reply With Quote
Old 09-12-2013, 08:15 PM   #65
Skibum101
Member#: 265502
2008 5 Door WRX
Rally Blue
Could work. I'm not sure if it would hold up at high speeds though.
Does anyone have any pictures of something like this on an 08 DIY or not. I'm still trying to picture how it would look.
Old 09-12-2013, 08:38 PM   #66
darthalal
Member#: 114208
2007 MINI Cooper S
I don't know if I would trust any adhesive like that, especially after it didn't hold my Prodrive lip on.
I would go with nylon nuts and bolts vs. self-tappers. Did some yanking on mine today and it's not going anywhere.
As far as pre-drilling; I drilled as I went, to make sure everything lined up properly, and so there was no warping of the ABS.
Old 10-02-2013, 01:57 PM   #67
Zachbiz
Member#: 331281
car car
just a little update. Polycarbonate is holding up MUCH better. definitely worth the extra coin for those thinking of doing this.
Old 10-02-2013, 02:16 PM   #68
darthalal
Member#: 114208
2007 MINI Cooper S
^Still looks great!!
Update from me - everyone was right about those screws rusting.
Old 10-02-2013, 03:03 PM   #69
Zachbiz
Member#: 331281
car car
yup i had the same problem. I spray some rustoleum black engine enamel into a bottle cap and went through a dabbed all the screw heads with the paint. no more rust problems.
Old 10-02-2013, 03:26 PM   #70
darthalal
Member#: 114208
2007 MINI Cooper S
That's not a bad idea! Thanks.
Old 10-08-2013, 08:36 PM   #71
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
I think i'm going to give this a shot on my hawk. I've always hated the way the bumper outcrops on the corners. I'm going to eventually couple this with a splitter.
xirallicgdb is offline   Reply With Quote
Old 10-09-2013, 08:40 PM   #72
Zachbiz
Member#: 331281
car car
awesome man! cant wait to see the results. be sure to post up.
Old 10-09-2013, 10:31 PM   #73
tcoffin014
Member#: 173734
Sexy White Princess
Anybody do anything similar on the gr yet? My bumper is pretty messed up and I need a cheap solution
tcoffin014 is offline   Reply With Quote
Old 10-18-2013, 10:39 AM   #74
shamrock 05
Member#: 120057
So with this pic....how far down the bumper is it....and on the sides does it really sit flat/connect good cause it looks like it is resting on that point
Old 10-18-2013, 11:04 AM   #75
Zachbiz
Member#: 331281
car car
If you see the crease in the stock bumper, that's where you line up the lip. All the way around to the other side. And follow the natural crease. The sides are where they bolt the flattest and sturdiest. It will rip the bumper or lip off before the bolts come out.
