Old 07-13-2011, 10:49 PM   #201
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Originally Posted by JesseL View Post
Laptop stand
Reminds me of a line from a certain movie" Danger to manifold"
But i do understand why its there.
2011WRXMT is offline   Reply With Quote
Old 07-20-2011, 11:03 AM   #202
impreza2.5iguy
Member#: 238294
2008 Impreza 2.5i
Dark Gray
I had the footwell illumination kit in blue on my 2009 impreza 2.5i hatchback before she was totaled, I now have a 2008 impreza in dark gray metallic and getting the footwell illumination kit installed on it in blue again. I loved the way it looked. HIGHLY recommend this cheap, nice upgrade.
impreza2.5iguy is offline   Reply With Quote
Old 08-27-2012, 04:00 AM   #203
basara808
Member#: 262588
2012 Impreza 5Dr CVT
Anyone know a easy way to install the illumination kit installed on a 2012 non WRX/STI impreza?
basara808 is offline   Reply With Quote
Old 08-28-2012, 03:23 PM   #204
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
^ ooh ooh me too. Anyone?
myrt1987 is online now   Reply With Quote
Old 12-02-2012, 04:53 PM   #205
dza360
Member#: 10048
2008 STi
Obsidian Black Pearl
Maybe I'm retarded but I took the whole stereo trim out of my 2009 Forester XT, to get to the wires, took out the cubby light and I couldn't find any extra connectors for the driver and passenger LED's. I disconnected the Cubby light and followed that harness back and found nothing.
this is supposed to take 25 mins? I got no where. I just gave up and put it back together. I'm stumped.
*****Turns out I am retarded....the harness that I was looking for was still in the box.*******
dza360 is offline   Reply With Quote
Old 01-19-2013, 02:47 PM   #206
Cr33p
Member#: 320004
I noticed you ordered two separate kits (part numbers). I have a 2012 Subaru Sport (non WRX). I do not have a cubby light. Do you know if the footwell illumination kit will work with the non WRX model?
Also, does H201SSC100 only come with drivers side and passengers side lights?
Cr33p is offline   Reply With Quote
Old 01-19-2013, 02:48 PM   #207
Cr33p
Member#: 320004
I have the EXACT same question!
Old 01-19-2013, 03:33 PM   #208
myrt1987
Member#: 323103
2012 Limited 2.0i
This kit is for 2012 model http://www.subarupartswebsite.com/OE...701SFJ100.html
however the $40 kit will work as well if you tap into the glove box light instead of the cubby hole light.
yes just the front footwells are lit
Old 01-20-2013, 04:10 AM   #209
justinyoon
Member#: 343895
2013 wrx sedan
CBS
just installed this on my 13 wrx
An easier way to go about this is to simply use mounting tape, similar to the 3m one that comes in the kit.
cut a piece off the same size and attach ur light anywhere u want.
you wont have to deal with the screws and washers and u can adjust it to any positiion whenever you want to, just tape it again.
justinyoon is offline   Reply With Quote
Old 01-23-2013, 11:58 PM   #210
Cr33p
Member#: 320004
I have the same question.
Old 05-23-2013, 08:35 AM   #211
roadking0678
Member#: 354839
2012 WRX Limited HB
WR Blue
Thanks for the post.. with all contributions and pictures i was able to install the red footwell kit, and replace my blue cubbie light witht he red one in about 20 minutes. Using a straightend coat hanger to fish the wires from the dash to the footwells really cut down on time. Thanks again guys!
roadking0678 is offline   Reply With Quote
Old 05-23-2013, 08:46 AM   #212
Deathin1985
Member#: 356414
2009 Impreza
News Install in a 2009 impreza
I put these in in about 15-20minutes. you can easily reach everything. running the wires can be a bit hard bc of the tight spaces but I have wired up all my amps and dvd players for this car so I am familiar with the metal tier bracing behind the dash and that aided me in finding the wires a bit easier. the flashlight was a life saver.
I have a red illumination kit and cubby whole light all together was about 60$ from the dealer. I couldn't get a straight answer from Subaru about the correct part number for the red cubby whole light so I went and bought it from them personally so if it was amber and not red they could take it back and order me the right piece. This is an easy install, anyone should be able to do this. if you are a complete noob it may just take you a bit longer, no biggy.
the kit is not very bright on the passenger side- in my opinion. may just be bc im on the driver side and my legs on the pedals reflects the light up, not sure. or maybe its bc there is a huge cavity behind the glove box and the light isn't being forced down. i am going to attempt a bracket to go over top of the light to shine light down or maybe some dynomat. after a bit more tinkering if i come up with anything i'll post a how-to.
I took a pic but without an extended exposure you cant really tell. the other inside lights are quite a bit brighter.
also on the drivers side the light has a tendency to shine up through the steering wheel whole. cant see it when you drive. i am going to get a piece of plastic and some plastic weld or gorilla glue and put me a little shark fin on the top side of the light to hide this. simple fixes for a simple project. dont over-think it, it truly is a plug and play operation.
-good luck
oh, and the passenger side will work a bit easier if you have a short extender on a small socket for the nylon nut. there are some plastic channels you have to fight with and doing it blind is a bit hard but with some patients u can get it. I would say that this was the hardest part for me.
Deathin1985 is offline   Reply With Quote
Old 05-23-2013, 09:04 AM   #213
ponchsox
Member#: 353045
Will this kit work in a 2013 Impreza 5 door 2.0l?
https://www.subaruonlineparts.com/pr...oducts_id=1042
ponchsox is offline   Reply With Quote
Old 05-23-2013, 11:04 AM   #214
Trustkevin13
Member#: 259184
2008 Subaru WRX
Well do you have a chubby light? The plug should be in there, I dont know anyone who has one to go take a look at it. Sorry :/
Trustkevin13 is offline   Reply With Quote
Old 05-23-2013, 11:48 AM   #215
myrt1987
Member#: 323103
2012 Limited 2.0i
You can make it work, but because theres no cubby light so you have to tap into the glove box light by extending the correct wire.
Old 06-04-2013, 03:44 PM   #216
Ellatron5000
Member#: 357087
2010 Impreza 2.5i
Pearl White
anyone have a step by step or wanna do a write up on how to install these to the dome light?
Ellatron5000 is offline   Reply With Quote
Old 10-17-2013, 12:14 PM   #217
msalvas
Member#: 354743
2013 WRX STi
Anyone wanna trade me their blue cubby light for a red one. I have three and I believe this light also works for the light in the glove compartment. PM Me.
msalvas is offline   Reply With Quote
Old 10-18-2013, 07:16 PM   #218
Competitor9
Member#: 371332
Looks nice
Competitor9 is offline   Reply With Quote
Old 10-19-2013, 01:20 PM   #219
airborne4vr
Member#: 368185
I had a red LED strip installed when I had my Sound System installed. Looks great and I watched them install it and it took 2 minutes.
airborne4vr is offline   Reply With Quote
Old 10-20-2013, 12:05 PM   #220
zohh_amaze
Member#: 158592
2004 4Runner V8
Hey guys,
I have a 2011 WRX that come with the blue footwell illumination kit, and I want to change the bulb color to red since it'll match the overall theme better. Can anyone direct or link me what part to buy and how to install it?
zohh_amaze is offline   Reply With Quote
Old 03-30-2014, 05:30 PM   #221
Mr.Gadget
Member#: 385530
2013 Impreza Sport
Deep Cherry
So, I have a 2013 Impreza Sport and purchased the red illumination kit. The instructions are severely lacking for me... I don't have a center cubby light. That's normal, right? So I need to tap into another source? Are there any good, clear writeups on a non-WRX model?
Mr.Gadget is offline   Reply With Quote
Old 03-30-2014, 07:58 PM   #222
dharel0bs11
Member#: 258998
2011 Outback Sport
Blue Pearl/Steel Silver
Originally Posted by zohh_amaze View Post
Hey guys,
I see that this is old, but no one responded. You can't just swap bulbs. Theses are LED. If you want red, you need to purchase the red kit or trade with someone who wants blue.
dharel0bs11 is offline   Reply With Quote
Old 03-30-2014, 08:00 PM   #223
dharel0bs11
Member#: 258998
2011 Outback Sport
I believe the kit for the 2013 is different than the ones for 08-11. Which kit did you get?
Old 03-30-2014, 09:21 PM   #224
Mr.Gadget
Member#: 385530
2013 Impreza Sport
Deep Cherry
I have the H201SSC100...
Old 03-30-2014, 09:40 PM   #225
Mr.Gadget
Member#: 385530
2013 Impreza Sport
Deep Cherry
Dang. Looks like I need the H701SFJ100 which costs $120. Time to exchange mine! Thanks for the heads up.
How do you install in the left vent RSilverSuby Interior & Exterior Modification 4 08-18-2009 07:15 AM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
OT Runners: How do you motivate yourself to run first thing in the morning? doubledribble Off-Topic 39 08-02-2006 03:27 PM
How do you install Dynamat trunk kit? ERaab212 Car Audio, Video & Security 4 09-28-2002 11:50 PM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 02:41 PM
