Closed Thread
Old 10-18-2013, 11:20 AM   #201
erok81
Member#: 300717
2004 WRX
JBP
Originally Posted by kpluiten
What do you mean "build the flares around" the wheels? If the donor shows up with 18x11.5 et20 with 315's, are we all going to get crazy huge flares as a result?
Our donor car guy is running similar setups as we are all looking for. 18x10-10.5 and a 285/295 type tire. Mimicking what most sedan guys are using. Plus I highly doubt Karlton is going to make some giant bat wing flares. We all asked for similar to sedan width. So don't worry.
I'd bet it's bull**** started by either the A) anti-hella-fush crowd or B) the "STI is far superior to your lowly WRX and here's why..." crowd.
I think k-dogg (in this thread) said that one of his wheel bearing died running a fairly wide setup. You'll have to look in this thread. I can't remember the exact details. I'm not worried about it. If I get 1-2 bearing that start to go out once a year or so, that's no big deal if I get 295's as a trade.
erok81 is offline
Old 10-18-2013, 01:21 PM   #202
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
The flares will be very similar to the width of the sedan flares. They will be built around a 18x10.5 +22 with a 285 Is that ok for everyone? I mean you won't be able to go 11-11.5 like us sedan guys, but it should be plenty of wheel/tire for the wagons Plus there are more 10.5 +22 coming out in 5x100 due to the frs/brz, so thank them hahah
pignoseSTI is offline
Old 10-18-2013, 01:45 PM   #203
erok81
Member#: 300717
2004 WRX
JBP
That's works perfectly for me. And it's pretty much what I sent to everyone for the final approvals.
erok81 is offline
Old 10-18-2013, 01:54 PM   #204
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Sounds good.
ddavisgt is offline
Old 10-18-2013, 02:39 PM   #205
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
OK. Based on my calculations, this make the wheel poke out 58mm further than my current setup with OEM 05-07 BBS. And they will be 6mm closer to the strut as well.
kpluiten is offline
Old 10-18-2013, 02:43 PM   #206
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
I use this calculator a bit. Its great for comparing 2 setups. It gives you alot of info on clearance and tire size.
http://www.rimsntires.com/specs.jsp
ddavisgt is offline
Old 10-18-2013, 02:46 PM   #207
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Yup I have had to replace 1 front wheel bearing in 100k with about 6 years of auto-x too. Granted I wasn't on lower offset wheels, but this will be a bit of a test anyway to see if that actually changes anything.
Like I mentioned though I am upgrading to different knuckles so I won't have to worry about that in the front at least.
Exactly. It was pretty much a consensus from everyone in the 04/05 group and they were good with the setup I was planning on running noted above. Some people may try to fit wider or not, but we all thought this was a good size to build them at. Going to be some trial and error for people trying different setups just like how the sedan guys are doing it now.
k-dogg is offline
Old 10-18-2013, 03:00 PM   #208
juandering
Member#: 330389
05 Saabaru
Any idea how well the fronts would fit on an 05 saabaru? The rears I think look close enough but the fronts I think might be off
juandering is offline
Old 10-18-2013, 03:06 PM   #209
kpluiten
Member#: 120273
06 WRBWRXWGN
How much will the fender flare cover the planned tire?
kpluiten is offline
Old 10-18-2013, 04:13 PM   #210
MattyQ610
Member#: 288729
Im gonna be running some mach v awesomes 17x9, +42 offset on 275s will the flares be too big?
MattyQ610 is offline
Old 10-18-2013, 04:57 PM   #211
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
It will be pretty flush. This guy is running a 245/45/17 17x9 +42
http://forums.nasioc.com/forums/show....php?t=1668222
So that looks like a max fitment under stock wagon fenders. If I compare that size to what the donor is running (18x10.5 285/30/18) with this tool http://www.rimsntires.com/specs.jsp it shows that the donors car will poke out the fender 40mm more. Add 10mm push out for the sti control arms hes running also and your looking at 50mm poke out (1.9685 inches). If the flares are 2 inches wide, sounds pretty spot on.
ddavisgt is offline
Old 10-18-2013, 05:05 PM   #212
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
You will have about a 1 inch space from the tire to the flare if your on a wider track control arm. 1.37 inch if your on wagon arms.
ddavisgt is offline
Old 10-18-2013, 05:19 PM   #213
MattyQ610
Member#: 288729
So I take it that that wont look right? I saw some pictures of guys running 275s on the karlton fender flare gallery forum n it looked okay, so do I need to go with wider control arms? Any suggestions?
Old 10-18-2013, 05:39 PM   #214
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
If you saw a sedan with Karltons running that size, then that would be a pretty close representation as long as they didnt have spacers on it. Even though sedan arms stick out 10mm more then wagon arms, their fenders also stick out 10mm more. So the end result would have the wheel falling the same distance from the fender edge, if that makes since. sedan (fender and wheel both push out 10mm) vs wagon (fender and wheel pushed in 10mm). Either way the relation of the wheel to the fender stays the same.
You could use wheel spacers to push it more out if you wanted, but using big spacers are debated alot. You could add sti or sedan control arms, but you would also need sedan axles (in the rear, front is debatable) / sedan swaybars/ sedan endlinks/ & lateral links in the rear to push the rear track so it matches the front.
Or just get a different fitting wheel
ddavisgt is offline
Old 10-18-2013, 08:14 PM   #215
kpluiten
Member#: 120273
06 WRBWRXWGN
You guys are going to laugh, but I just don't want to have to run too much tire. The cars lose some of their fun and "flickability/tossability" with mega wide rubber on them. Plus the wheels and tires get pretty heavy.
kpluiten is offline
Old 10-18-2013, 08:28 PM   #216
inthenameofweez
Member#: 201374
2004 Broken down
slow ass wagon
Whose paypal do I need to send money to? I want Karlton flares on my 2004 more than anything right now.
Just bought 18x9.5 + 27 and 275/35/18 tires. NEED HELP FITTING.
inthenameofweez is offline
Old 10-18-2013, 08:39 PM   #217
erok81
Member#: 300717
2004 WRX
JBP
Originally Posted by inthenameofweez View Post
Whose paypal do I need to send money to? I want Karlton flares on my 2004 more than anything right now. Just bought 18x9.5 + 27 and 275/35/18 tires. NEED HELP FITTING.
PM'd.
erok81 is offline
Old 10-20-2013, 02:07 AM   #218
NickG21
Member#: 298524
2002 wrx wagon
white
im still down for the 02/03.
NickG21 is offline
Old 10-20-2013, 02:15 AM   #219
sc00by4life
Member#: 97135
Dude.
That's why you research before you buy.
sc00by4life is online now
Old 10-20-2013, 09:36 AM   #220
fear_noEVO
Member#: 193654
'09 FXT Limited
'07 LGT Spec B
I'm so in!! Too bad my saabaru has a different rear bumper. I'll probably have to mix and match the 05+ sedan rear flares and make the 04/05 fronts fit. That's better than making the sedan fronts fit like I was going to. I have a full STi 6spd swap so I too am limited by the wider rear track. This is pre-6 speed, but you can see the lower part of the bumper.
fear_noEVO is offline
Old 10-22-2013, 04:16 PM   #221
MattyQ610
Member#: 288729
Thanks For the info man I already have alot of sti suspension parts so thats probaly the route ill go, how hard is it to swap out the axels? DIY er PRO job?
Old 10-22-2013, 04:17 PM   #222
MattyQ610
Member#: 288729
whats good with the hawkeyes?
Old 10-22-2013, 10:11 PM   #223
Ethanwrxwagon
Member#: 270948
2005 wrx wagon
I'm really interested I just don't have the funds for a while to even put down:/ please make these! Haha I'm in an 05 wagon
Ethanwrxwagon is offline
Old 10-22-2013, 11:13 PM   #224
LoganG1K
Member#: 78618
I'm sure they will be more made after the first 6 are made. The first 6 should get numbered dash plaques like 1 of 6, 2 of 6... Haha
LoganG1K is offline
Old 10-23-2013, 12:08 AM   #225
rymaggi
Member#: 253442
When's eta of finished project?
rymaggi is offline
Closed Thread
Would you buy these hoses? Whoa!ShutItDown Newbies & FAQs 22 03-04-2010 08:24 PM
Spotted heaps of WRC products in Greek equivalent Home Depot. Would you buy these? Subaruman5 North West Impreza Club Forum -- NWIC 16 08-31-2009 04:09 PM
Wagon Owners: Would You Buy A 27mm FSB? scoobydrew06 Brakes, Steering & Suspension 64 05-15-2008 10:41 AM
Mudflaps, would you buy these? phong Mid West Subaru Owners Club Forum -- MWSOC 5 10-01-2004 07:42 PM
If these were made would you buy? stentorian Interior & Exterior Modification 6 05-08-2002 03:23 AM
