Old 09-28-2013, 07:03 PM   #1
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
Default Crazy hot under hood after tune / turbo upgrade / no power
catless up and down pipe
front mount intercooler
Cold air intake
sti 2.5 block and heads no avcs (wrx cam gear)
DEATSCHWERKS 750 top feed
WALBRO 255LPH FUEL PUMP
grimmspeed 3 port boost con.
05 wrx ecu
My car is a 05 wrx. when i first got it i had an sti block and heads installed. It ran good with the tdo4, sti pinks, and wrx fuel pump. so later on the upgraded to an 18g and took it to a new tuner (new to me) and it did not make anymore power and was much more laggy. but the worst part was the under hood temps were hot hot! my cold air intake pipe even is super hot to the touch. So i thought maybe that turbo was just junk and i took it off and got a stock oem vf39 and took it back to have it retuned. and same as before hot hot! no better power but it spools up faster then the 18g. He told me it was leaning out so i installed a WALBRO 255LPH FUEL PUMP and DEATSCHWERKS 750 top feed, and took it back for retune. we started a pull and it leaned out so bad that we could not even do any pulls.
So i put a new oem fpr on it and did a fuel tank filter delete and install the filter under the hood. have not gone back to tune but it runs like crap so i dont know. any ideas?
AFAP_Nor_CA is offline   Reply With Quote
Old 09-28-2013, 07:07 PM   #2
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
Perhaps take it to a different tuner or consider an e-tune. You shouldn't be leaning out with the walbro. Sounds like it's issues with the tune.
Chaz2.5 is offline   Reply With Quote
Old 09-28-2013, 09:41 PM   #3
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
that is my thoughts as well any other ideas before i go telling him he did a bad tune on my car?
Old 09-30-2013, 03:26 PM   #4
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
thoughts?
Old 09-30-2013, 05:52 PM   #5
02nismokiller
Member#: 322963
04 wrx
psm
Just don't tell him anything and get in contact with STI Mikey ASAP!!!!!
02nismokiller is offline   Reply With Quote
Old 10-05-2013, 06:23 PM   #6
chimaira4deth
Member#: 329194
2005 Legacy GT
Dark Matter
Maf sensor. Replace it
chimaira4deth is offline   Reply With Quote
Old 10-18-2013, 04:10 PM   #7
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Could be anything.... Could be an intake leak.. Could be a boost leak, could be a bad maf... Could also be a bad tune... Can't tell without logs and a rom.
Bamofo is offline   Reply With Quote
Old 10-19-2013, 01:56 AM   #8
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
tuner said maf was fine he was getting a reading, did boost leak test, no leaks, compression test was good, intake leak? i don't understand what that is you meen b4 it goes into the turbo?
Old 11-02-2013, 10:27 AM   #9
sidewayz
Member#: 5810
2001 S366 2.5RS
Did your tuner smoke test the entire system starting at the intake?
I see a lot of cars come in from "tuners" that have many pre turbo air leaks
sidewayz is offline   Reply With Quote
Old 11-28-2013, 06:06 PM   #10
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
a pre turbo air leak on the intake? your asking if the intake just past the filter sucking in air from some where other then the filter? is that what your talking about?
Old 03-06-2014, 04:08 AM   #11
AFAP_Nor_CA
Member#: 234270
99 sti swap
gray
it was a TGV. The TGV sensor was installed wrong (w/o the twist) and it was reading stuck open but it was stuck closed . this did all that crazy stuff i listed off. now its running cool and lots of power. if you are having this same problem, check it or better yet do a TGV delete.
Old 03-07-2014, 12:27 PM   #12
SharpTuning
Member#: 333363
And this, folks, is why this is horrible advice:
TGV Deletes FTW.
SharpTuning is offline   Reply With Quote
