Welcome to the North American Subaru Impreza Owners Club Wednesday October 22, 2014
Old 10-18-2013, 02:25 PM   #1
Dillinja666
Member#: 332644
07 STI
It's white
Default Phantom knock
SO I've been looking around for how to tune out my phantom knock. MY car pulls 12.75 degrees in the same spot/load range and is reproduce-able. I've checked for knock with my scope ( chassis ears ) and I'm not knocking. So, is there a way to turn down knock sensitivity or something to clear this knock up. If you want I can go log real quick if you wanna see what I'm dealing with.
Dillinja666 is offline   Reply With Quote
Old 10-18-2013, 03:59 PM   #2
nmlittlebigman
Member#: 321409
2015 WRX LTD
I would trust your knock sensor unless and until you can prove that what it is picking up is not detonation. Go buy a wideband and log your AFR's to make sure that it is not fueling related.
Old 10-18-2013, 04:05 PM   #3
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Can you either post the log where it pulls it or send us a rom to double check it? Thst much timing being pulled is normally blown up motor.. Or terrible tune... Or bad tune and 87 octane.
Bamofo is offline   Reply With Quote
Old 10-18-2013, 05:12 PM   #4
Dillinja666
Member#: 332644
07 STI
It's white
I have chassis ears ( the head phones you can mount mics around the car and listen for stuff, great for knocks ) and I'm not hearing anything. You can hear the crankshaft spin they work so well its crazy. Anyways I'll post the log... the tune is...meh, not dangerous I don't think, most people seeing the logs say its actually very conservative.
https://docs.google.com/spreadsheet/...3c&usp=sharing
I did reading before and saw that everyone says to check for stuff rattling around. I have EL headers wrapped so no heat shields, and everything on the motor is bolted down tight. I have a light weight crankpully but tried swapping it for the stock and still had the same phantom knock. I have my tune so my timing can be pulled back 12 degrees instead of the stock 6 or 4 or whatever in case of knock and the car tries to pull max timing.
edit: mod list is Tomei EL headers, catless dp, CBE, turbo inlet with stock air box and MAF housing and accordion tube after MAF.
Old 10-19-2013, 08:51 AM   #5
cowboy_Rob
Member#: 194062
2003 Impreza WRX
What rpm range is your knock occurring? Or is it load dependant more then rpm.
cowboy_Rob is offline   Reply With Quote
Old 10-19-2013, 05:00 PM   #6
Dillinja666
Member#: 332644
07 STI
It's white
rpm more then load, I posted the log, If I floor it from before the knock zone it doesn't knock but partial throttle I get this.
Old 10-21-2013, 12:14 AM   #7
Dillinja666
Member#: 332644
07 STI
It's white
any suggestions?
Old 10-27-2013, 12:34 AM   #8
Joshwrx04
Member#: 135429
'05 CGM STi cornfed
'82 s-10 (427'nd soon)
I'm am dealing with this same issue
Joshwrx04 is offline   Reply With Quote
Old 10-27-2013, 01:15 AM   #9
rocketperson7
Member#: 283968
MBP
I've fought phantom knock all last summer, exactly like this
A few things I've noticed: (this is for a 2.slow, so take with a large grain of salt)
1. It liked to be leaner
2. It didn't like baby timing
3. It liked consistent, smooth transistions both in timing and afr, no big jumps (I tried to not have any cell have a bigger than 3 degree change in any direction)
It still does it, especially as I move to gas, so I don't know if I'm a crap tuner or my knock sensor is bad, but I've thought of replacing mine since the "phantom" knock is so bad sometimes, and it's never knocked at any higher rpm/load range
Old 10-27-2013, 09:45 PM   #10
Dillinja666
Member#: 332644
07 STI
It's white
So I got rid of 90% of my knock by trying somethings:
Removed the exhaust bracket that goes from the transmission crossmember to the exhaust.
Reduced AVCS in the area's with my knock problem.
leaned the mixture out a bit.
Increased tip in enrichment.
The car runs much better now, just the slightest knock .75-1.0 in a really small place higher up in the RPMs then my phantom knock. Give this a shot and see how you guys end up Joshwrx04 and Rocketperson7
