Old 10-20-2013, 11:36 AM   #1
jay bee
Member#: 364809
2016 Legacy Limited
Crystal White Pearl
Default Engine mgmt adjust for higher octane? 2013 n/a Sport
2013 Impreza Sport. In the owner's manual it says 87 octane or higher. Is the computer doing anything for HP or torque changes if higher octane is used?
jay bee is offline   Reply With Quote
Old 10-20-2013, 11:47 AM   #2
ToneWrx02
Member#: 239095
2002 Wrx
From wjat i read too high of octane will actualöy start resulting in loss of power.
ToneWrx02 is offline   Reply With Quote
Old 10-20-2013, 12:33 PM   #3
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
It's not really so much about the octane number; it's more about what they put into the fuel.
Or, in different terms: the computer will adjust for different octane fuels (ie. advance or pull timing depending on whatever knocking it detects), but whether you lose power or torque depends on the fuel composition.
FWIW, I'm currently on my 2nd tank of 94 octane (zero ethanol) fuel. There's less apparent fuel consumption based on the first tank of 94 vs. the last few tanks of 91 octane (with unknown - but definitely existing - ethanol content). No detectable difference in power from my butt dyno.
lymphomaniac is offline   Reply With Quote
Old 10-20-2013, 01:25 PM   #4
jay bee
Member#: 364809
2016 Legacy Limited
Crystal White Pearl
True if no other changes are made. Higher octane is harder to burn. But if the computer adjusted the spark timing, fuel mixture and possibly cam position for it, there would be more power and/or torque.
Old 10-20-2013, 01:35 PM   #5
jay bee
Member#: 364809
2016 Legacy Limited
Crystal White Pearl
So the computer will dial it for the knock sensor? I am pretty familiar with gasolines, they are really about the additive package, much like motor oils these days. Interesting about your car. Every now and then I put in 89, no detectable difference to me.
I am a new Subie newbie but not new. I worked on a lot of cars in the 70s to the 90s. DIY until past couple of years, now I just pay good people and do my own stuff once in a while. And I did have a 79 Subaru hatchback 4wd 20 years ago, hated it. LOL
Old 10-20-2013, 03:00 PM   #6
lymphomaniac
Member#: 334451
DGM (sedan)
I actually ran 87 for the first 10 or so tanks, and 89 for the next 10 or so after that. I'd been running 91 for the 30 or so tanks preceding my switch to 94. Not sure if that matters.
My butt dyno tells me that the car on 91 was definitely more peppier than the car on 87 or 89. It also consumed less fuel for the same distance travelled. For both of these points, I blame the ethanol content. 87 was supposed to have up to 10% ethanol; 89 had perhaps less. As mentioned, I couldn't discern any power or torque difference between 91 octane and 94 octane, but I'm only 2 tanks into 94 octane.
On a side note, I used to have the hard-starting issue when running 87 and 89 octane. It pretty much disappeared with the 91 octane fuel. I blame the ethanol content.
Not sure what area you're in (you might want to update your profile ). Here in Canada, we have a trim level called the "touring package", which translates to approximately the premium trim level in the States. Pretty sure the engine and computer are the same configuration for all trim levels, though.
Did I mention I blame the ethanol content?
Old 10-20-2013, 05:54 PM   #7
jay bee
Member#: 364809
2016 Legacy Limited
Crystal White Pearl
I hear you on the ethanol content... Maryland - just starting to cool down now, my nose has not detected winter blend fuel yet.
Old 10-21-2013, 08:40 AM   #8
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
Originally Posted by jay bee View Post
Higher octane is harder to burn spontaneously ignite.
High octane burns just fine once you light it. Like, say, with a spark plug.
MCarp22 is offline   Reply With Quote
Old 10-21-2013, 12:46 PM   #9
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
In Minnesota it's completely impossible to find any gasoline without ethanol as far as I know.
I've found one station and the premium (non ethanol) was $1.50 more than regular which is bull**** and not worth anything.
goregasm is offline   Reply With Quote
Old 10-21-2013, 12:48 PM   #10
Angelus911
Member#: 89967
2012 Impreza Sport
IMO buying anything over 87 is probably just the placebo effect and not worth the extra money. If we're talking about ethanol free gas, then that's a whole other discussion...
Old 10-21-2013, 01:26 PM   #11
lymphomaniac
Member#: 334451
DGM (sedan)
Ethanol belongs in my drink, not in my engine.
