Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 09-14-2013, 01:36 PM   #101
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Originally Posted by Vjaramillo View Post
Anyone interested in a oem rear swaybar from a limited 2013 impreza? Just installed sti one.
How much and do you have all the hardware to install it?
VegasSubie is offline   Reply With Quote
Old 09-14-2013, 04:19 PM   #102
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I'm guessing he doesn't have everything you need to install it, as he used all that stuff to install the 19mm STI bar.
I was in the same situation. I installed an STI bar, and the guy who bought my original 16mm bar had to buy the end links, appropriate bolts, clamps, and so on in order to complete the installation.
His bar probably includes the 16mm bushings that you'll need, as his STI bar probably came with 19mm bushings.
Old 09-17-2013, 04:06 PM   #103
tspunk
Member#: 345444
2013 Impreza 5-door
i have the stock bar itself if anybody needs it cheap. the 16mm bar only. Massachusetts.
tspunk is offline   Reply With Quote
Old 09-19-2013, 02:02 PM   #104
wuzin
Member#: 368795
2013 Impreza Premium
Dark Gray Metallic
I have installed 19mm STi RSB, feels much better, it took me about 30 mins to get it installed on the ramp.
If anyone looking for Stock Premium pkg 16mm RSB, let me know.
wuzin is offline   Reply With Quote
Old 09-19-2013, 11:29 PM   #105
LegionSpecter
Member#: 353258
2013 XV Crosstrek
Bright effin Orange
finally installed my 19mm rsb tonight. will be testing it out tomorrow. i cant sleep, i just wanna go out and drive.
LegionSpecter is offline   Reply With Quote
Old 10-07-2013, 01:01 PM   #106
twotwntytwo
Member#: 367043
Hi Guys.
I'm looking to install an STI 19mm bar in the back. Will be buying all the OEM endlinks, bushing, nuts and bolts. Would anyone be as kind to help me out with the torque specs? I don't have the shop manuals. If no one has exact torque specs, would I follow the STI shop manual specs or the regular base Impreza specs?
twotwntytwo is offline   Reply With Quote
Old 10-07-2013, 01:07 PM   #107
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Go till it's tight then go a little more haha. Sorry I never torque but that's just me. And I think your safe to use sti specs.
SIA_worker is offline   Reply With Quote
Old 10-14-2013, 12:14 PM   #108
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
On Craigslist there's a 2013 wrx low mileage 19mm OEM rsb near me with end links. What should I offer?
goregasm is offline   Reply With Quote
Old 10-16-2013, 12:15 AM   #109
shredjesse
Member#: 369265
2013 Impreza 2.0L
Pearl White
Where is everyone finding 19mm bars to convert from their OEM 16mm bars for $100?!?!?
I can't find that price anywhere.
shredjesse is offline   Reply With Quote
Old 10-16-2013, 02:51 AM   #110
wuzin
Member#: 368795
Dark Gray Metallic
Originally Posted by shredjesse View Post
Where is everyone finding 19mm bars to convert from their OEM 16mm bars for $100?!?!? I can't find that price anywhere.
I got mine from here : http://heubergersubaruparts.com/part...iagram=7593803
Old 10-17-2013, 12:36 AM   #111
shredjesse
Member#: 369265
2013 Impreza 2.0L
Pearl White
Alright, and a follow up question:
If I already have a 16mm bar, which of those parts do I need exactly for the conversion? 1 2 and 3 I presume, but not 4?
Old 10-17-2013, 08:54 AM   #112
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
1 and 2x2 only
Old 10-18-2013, 11:06 AM   #113
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
What would make more of a difference in how fast I can corner, tires with a lower aspect ratio and stiffer sidewall, or a rear sway bar?
Old 10-18-2013, 11:42 AM   #114
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Are you dissatisfied with your cornering speed right now? Do you find the car breaks traction now?
I didn't before upgrading my RSB. The car stuck to the road very well. I just didn't like the amount of body lean, so I upgraded the RSB. I don't think I'm cornering any faster than before, but I like the flatter body roll now.
But perhaps you approach the car's limits much more-so than I do, so your results might vary. I've never pushed the car hard enough to make the tires squeal on a dry road.
Old 10-18-2013, 11:44 AM   #115
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
I go around ramps at the maximum speed I can before I'd slide off sometimes (obviously when there's no traffic) which happens to be ~46mph but I find Toyota rav4s keeping up with me sometimes. A small car with a low center of gravity feels like it should be able to take ramps at 65 with warm tires. Maybe even 75 with a huge rsb and stiff ass summer tires.
Old 10-18-2013, 11:45 AM   #116
Eminaga
Member#: 370430
2013 Impreza Sport
Marine Blue Perl
so is the wrx RSB 19mm also or just the STI? I would think STI would have 19mm and WRX 16 just like Sport.
Eminaga is offline   Reply With Quote
Old 10-18-2013, 11:55 AM   #117
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
My advice: Get the sway bar now, get better tires when your current tires wear out. That's what I'm doing.
I'm not sure how much the sway bar increased my car's limits, but it definitely made it much more predictable and controllable around the limit.
soobie doo is offline   Reply With Quote
Old 10-18-2013, 12:37 PM   #118
Eminaga
Member#: 370430
2013 Impreza Sport
Marine Blue Perl
Do you recommend getting the stock swaybar from the WRX/STI or getting an aftermarket one that is an upgrade to WRX/STI? I wonder if quality would be better with aftermarket 19mm swaybar?
Old 10-18-2013, 12:47 PM   #119
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Do you have a rear bar right now? And what tires, the stock yokos are not good at all for handling.
Old 10-18-2013, 12:49 PM   #120
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
How often do sway bars break? I broke one on my Buick (34mm bar!) But it wasn't the bar, it was a weld where the endlink connects, and that was after 150k of my driving
Old 10-18-2013, 02:13 PM   #121
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
150k is reasonable for something like this to break. That's why if you buy a used one off a wrx/STi you should get super low mileage. It was almost certainly beat up.
Old 10-18-2013, 03:57 PM   #122
Eminaga
Member#: 370430
2013 Impreza Sport
Marine Blue Perl
to clarify; I meant as far as better for performance not just qualify
Old 10-18-2013, 05:37 PM   #123
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't know if the $$$$/performance ratio is as good. I would love to try out a 22mm bar, but financially it didn't make sense since I spent 90 for a brand new sti car, and after changing the tires it really shines
Old 10-21-2013, 03:24 PM   #124
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
What parts other than the RSB itself fit the 2012+ imp coming from the 08+ wrx/STi?
Old 10-24-2013, 04:52 PM   #125
wuzin
Member#: 368795
Dark Gray Metallic
Hm, I have premium impreza and installed 19mm rear sway bar about a month ago.
Also suspension is lowered with Epic Engineering springs.
Recently noticed that I am getting clunk noise from the rear when I make quick turn or go over the bump with either passenger/driver side only, like only one side is going over the bump.
Checked under the car today, couldn't find anything but took off the sway bar and drove for a while, then no clunk.
Is it because my suspension is lowered and stock endlinks are too long for it?
Can I use aftermarket endlinks which fit on 08+ WRX?
