Old 10-18-2013, 10:34 AM   #1
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Default DCCD with 08+ 5sp trans?
So i know some old 5spd DCCD tail housings/diffs exist. yes i know they are rare, but that is irrelevant to my question.
can you use this tail housing on the 08+ WRX transmission? will it bolt up? is the bolt pattern the same? i see people always referring to it by "phase 1" and "phase 2", but how does that compare to the 08+ trans? is the 08+ trans a "phase 2"?
while we are at it. what are the exact reasons that a 5speed DCCD diff will not work in the non-DCCD tail housing? is it just the matter of no passthrough hole for the wiring? or will it physically not fit?
please no "your wasting your time" posts. this is informational/hypothetical at this point.
Old 10-19-2013, 11:23 AM   #2
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Anyone have any info?
Old 10-19-2013, 11:37 AM   #3
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
You should probably ask Andrewtech...They would know better than most people.
-- Dave
AcquaCow is offline   Reply With Quote
Old 10-19-2013, 08:18 PM   #4
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
And, if you do get an answer, please post back here.
Schikane is offline   Reply With Quote
Old 10-19-2013, 09:07 PM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I talked to Andrew about it myself, but it was for different year trannys... He had a few ideas and some spare parts depending on year.
Old 10-20-2013, 02:36 PM   #6
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
What was the conclusion? Possible? Your reply is pretty vague. What year tranny were/are you trying to add DCCD to?
Old 10-20-2013, 11:08 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
To the best of my knowledge, the bolt pattern and basic design is the same.
Both and neither. Both in the way that the phase I DCCD will not fit in a phase II housing and there is nowhere to pass the harness outside. Neither when looking at a later DCCD unit, but I havent come across one to compare the housings. (ie: did they keep the old style housing and diff unit, or use a different setup with the phase II style unit and housing).
I'd look at scoobynet.uk for first hand information. They are the folks who have had 5sp DCCD's for awhile......
Jay
Old 10-20-2013, 11:11 PM   #8
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
JDwhiteWRX is offline   Reply With Quote
Old 10-21-2013, 08:35 AM   #9
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Thanks for the info guys. This seems like it IS possible.
My idea is basically this. 08+ WRX trans, with PAR/PPG gears + UK spec DCCD + DCCD controller. Should be a lot lighter than a 6sp and Bolt up, won't have to change everything else needed for a 6sp swap (clutch/flywheel/axles/driveshaft/shifter/wiring/etc)
Old 10-21-2013, 03:49 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
Pretty much what I did, except I went with an 05 LGT mainshaft and 03WRX 3/4/5's in a Impreza brighton case with the UK spec DCCD. Hybrid if ever there was one!
Jay
Old 10-22-2013, 04:50 AM   #11
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Have you upgraded your front and rear diffs yet? I would be doing those before the center diff.
Old 10-22-2013, 06:00 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Jay
that's awesome
Old 10-22-2013, 08:12 AM   #13
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Would be doing both (and likely the rear) at the same time.
Why open it up twice?
Old 10-24-2013, 06:17 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
Of course...... Helical front and 2 way plated rear, which will be a 1 and 1.5 way here in the next couple months.
The DCCD replaced the Cusco Tarmac center diff I didn't like too much.
Jay
