Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Closed Thread
Old 10-22-2013, 12:21 PM   #501
enjoilife1991
Member#: 322400
03 WRX 360whp
Originally Posted by KillerBMotorsport View Post
When we start on the GR setup, there shouldn't be a difference from the WRX to STi models across the years. As far as I know the engine compartments are the same
The intake manifolds are different so they will require different intercooler pipping.
enjoilife1991 is offline
Old 10-22-2013, 12:51 PM   #502
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
True, but since intercooler tubing can be had in universal DIY parts/pieces we hadn't even planned on including it with the kit, and you can make any configuration you like.
KillerBMotorsport is offline
Old 10-22-2013, 12:52 PM   #503
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Actually they are not.. Same intake manifold on both cars, slightly different mounting tabs for stuff like the EBC.
Junior2JZ is offline
Old 10-22-2013, 12:59 PM   #504
Leafy
Member#: 330625
2006 WRX
I think he means the wrx.
Leafy is offline
Old 10-22-2013, 01:06 PM   #505
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Reading > Jrtuned lol
Sorry, carry on.. Nothing to see here
See ya shortly Mr. KillerB
Old 10-22-2013, 03:21 PM   #506
Superaison
Member#: 257982
02 Impreza
Is there any videos yet?
Superaison is offline
Old 11-20-2013, 07:54 AM   #507
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Made a stooped mistake and I don't want to talk about it Engine is out of the car to be disassembled soon
In the mean time, revising prints to reflect changes that took place during fabrication and laying out fixturing plans.
Some exhaust pics for your visual enjoyment...
Just this one for now with the single scroll setup.
From the limited testing we got with the twin scroll it provided a ~400RPM gain in spool, but comparing both mid sized housings the twin scrill will not provide as much ultimate power. Going to the larger twin scroll housing should come close to equaling the power of the mid sized single scroll housing, but it's going to take a couple hundred RPM hit in spool. So at that point I question of the twin scrolls ~200RPM gain in spool is worth the extra cost. Especially considering the single spools/performs better than a comparable OEM or rotated location setup already.
None of these results reflect the recent change to delete the cat, so those numbers should go up some because of that as well. Surprisingly the sound levels have not increased a noticeable amount in the cabin and it's still much quieter than our catted stage II+ 2012 STi
Intercooler design also changed some. It grew a wee bit in height and now has cast end tanks. Air filter is bigger. I'm also working on routing the oil drain scavenge pump into the PCV just for fun. Don't know why I never took advantage of the vacuum source sooner
Old 11-20-2013, 08:30 AM   #508
Leafy
Member#: 330625
2006 WRX
I'm surprised that these was so little gain with the TS. Is it possible that Your lengths of primaries and secondaries are just making a bad set of pressure waves?
Leafy is offline
Old 11-20-2013, 08:36 AM   #509
bilt2run
Member#: 134211
^^^The way I see it, this system isnt going to be for everyone anyhow and at that higher price point I would care less paying a few hundred more and knowing I got the most out of that setup..twin scroll FTW
bilt2run is offline
Old 11-20-2013, 08:55 AM   #510
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
What kinds of gains would you be expecting going TS? The turbo is definitely more responsive than single (which you don't see on a dyno plot) and spools better. TS isn't known for making more power than SS, just different power.
Drivability wise, it's noticeable. The single scroll would swing from vacuum to 0 and then build boost. The TS version swings to 7-10psi immediately and builds more boost. So for scooting through traffic and low RPM non-downshift acceleration, it's a noticeable advantage. If I were to speculate... If I had 2 exact cars in a drag race, the TS would likely pull some in the first 2 gears, but the larger power of the SS would win the race.
I can see how the weekend auto-x guys would prefer TS, but for road coarse guys I don't any significant advantage. We've also seen more than a few track dedicated cars go from TS to SS to save weight, complexity, less things to fail, leak, wear, replace, and they see no hit in their times.
Old 11-20-2013, 09:28 AM   #511
Leafy
Member#: 330625
2006 WRX
I was expecting the TS gains you got with the smaller housing you used with the larger housing that flowed the same as the SS. Basically same power, 400ish rpm sooner on the power and better transient response.
Leafy is offline
Old 11-20-2013, 09:43 AM   #512
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
The reason that there is not as much of a difference between the TS and SS low mount is because the design of Chris's header is so good and efficient it tends to negate the perceived advantages normally seen with the JDM TS type design. I could see a little bit of transient response benefit from the TS but probably not much and not worth the added cost and complexity.
After having owned a KBHH with both a VF and a larger 60ish lb/ min turbo as well as a few other headers, I can tell you his design is far superior in performance in every way!
I'll take a Tial vband housing in .85 AR on mine please! I'm ready to do some testing for you sir!
manitou is offline
Old 11-20-2013, 11:24 AM   #513
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
At the same time let's be honest with ourselves... Anyone that is auto crossing competitively is going to be using a smaller turbo anyways because of class reasons / spool up etc.
Jr & Paul made me realize this for my car too, I had a twin scroll 6262 and like they said, you don't use that power. It looks cool on paper to say i hit xx psi at 4,xxx RPM but in a drag or road course you're never there anyways. Having said all this, I'm going back with a 6266 vband and some secret goodies
Layvon is offline
Old 11-20-2013, 11:30 AM   #514
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ agreed. As a street driver my favorite setup that has been on the car so far is the 3071. Response was near instant and FLAT curve from 3,800-7,000RPMs
Old 11-20-2013, 11:31 AM   #515
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here's the plot...
Old 11-20-2013, 11:36 AM   #516
Leafy
Member#: 330625
2006 WRX
I still want the widest powerband I can get. The wider you can make the powerband the better. Its almost disappointing in this day an age when a turbo 4 car cant make over 300ftlbs for at least 4000 rpms.
Leafy is offline
Old 11-20-2013, 12:00 PM   #517
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Take the above setup, swap in the mid-sized turbine housing and add E85. You'd have what you're looking for and well over 400whp to a higher redline. With E85 though it's kinda cheating though.
Old 11-20-2013, 12:07 PM   #518
Leafy
Member#: 330625
2006 WRX
Yeah, e85 is kind of cheating. You could do it on 93 with an SS EFR with this manifold no sweat with just a higher redline.
Leafy is offline
Old 11-20-2013, 12:14 PM   #519
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Maybe, but until we see lots more data coming back from EFR setups (besides from the guys selling them) it's speculation.
Old 11-20-2013, 12:21 PM   #520
manitou
Member#: 193757
2006 XTI Limited
Yeah, I agree but for a street/ touring car you want response and a wide power band. You are building a more dedicated drag/ track type car and that's fine. we all don't want the same type of performance out of our cars.
Now that you've driven my car you commented that power delivery was a smooth, linear and a steady rush from 2500-redline. The response is very good and that's what I was designing the build to do. It drives very well on the street as a DD for almost 600whp. It came out better than expected! Sure the 9.6:1 CR helps a bunch but I attribute a good bit of the performance to the KB Holy Header!
I think I can improve on this performance with the low mount kit that Chris is working on with a similar or slight larger turbo. I do not want twin scroll, i want to keep it simple. The design of the KBHH is such that the pulses match and work to come the closest that I've seen to TS designs and it's proven in the KB testing.
I can keep my 60ish lb turbo in it's efficiency range much longer than folks with bigger turbos and it's response is amazing between shifts. I'm in the next gear and gone while others are waiting for spool to happen in a lower gear. Perfect for a road/ touring DD type car!
My response on 93 PG is very similar with a larger stock location turbo, 300wtq at 37-3800, peaking at 400wtq and holding 300 out to redline on 22 psi of boost!
The graph above is a 93 pump gas plot. I make 400wtq from 4000 to almost 8000 with a Killer B Holy Header and a stock location Blouch 3.5xtr on E85. If you want that kind of torque/ power you have to use the right fuel.
manitou is offline
Old 11-20-2013, 12:25 PM   #521
Leafy
Member#: 330625
2006 WRX
Does it have to be for subarus? I think with your header we can actually look at data from other engines as meaningful. Unlike the the 3 feet of piping between the engine and turbo like we have on stockish location setups. We already have the 6758 doing 300+ftlbs for more than 4000 rpms on a log manifold on a 1.9 liter, and it should be capable of doing that for 5000-5500 rpms on the same engine with e85, which is what I'm banking on it my racecar once I have a tranny in it that wont grenade at at over 250ftlbs.
Then of course with this low mount header a 6758 would be making 300ftlbs at or below 3000 rpm, like it should on a 2.5 liter.
Leafy is offline
Old 11-20-2013, 12:31 PM   #522
manitou
Member#: 193757
2006 XTI Limited
I don't see that 6758 holding the power out for even 4K let alone 5-5500. Why try to rev it out that far without making good power. For those revs you need way more flow than that turbo will provide.
I really like the what I'm seeing in the EFR7163 EWG v-band housing. That would make a great DD turbo with this low mount kit! It should have great response and very good top end power!
manitou is offline
Old 11-20-2013, 12:33 PM   #523
Leafy
Member#: 330625
2006 WRX
It'll hold that torque out on the 1.9 liter in my racecar, not on a 2.5. It should still be able to still hold over 300ftlbs out to the stock redline on a 2.5. I'd still want a 7163 with the IWG on a low mount if I was trying to build a monster on a subaru.
Leafy is offline
Old 11-20-2013, 12:38 PM   #524
manitou
Member#: 193757
2006 XTI Limited
Why IWG? It adds length to the housing that makes it hard to fit and I'd rather have a separate dump for the waste gate any way. You'll make more torque and power sooner with the EWG and it might even fit this low mount kit!
I doubt though that Chris will make accommodations for the EFR's but if you did the EWG housings would be the way to go!
manitou is offline
Old 11-20-2013, 12:54 PM   #525
Leafy
Member#: 330625
2006 WRX
I like the IWG for the simplicity. Its normally easier to deal with the slightly longer turbine than have to cram and ewg line either back behind the driver with its own muffler (required in a whole bunch of racing series) or integrate it back into the down pipe. And then you have to worry about the damn egw tube cracking. I do wish that BW would release the damn 0.64A/R vband housing for the 58mm turbine that they already make, because indycar uses it.
Chris seems pretty dead set on using garrets, which is fine. But now we know that a low mount setup fits and vaguely what it looks like, I'm sure other people will come out with different flavors.
Leafy is offline
Closed Thread
