Old 10-11-2013, 01:33 AM   #26
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Hales46 View Post
Nice job! Any idea where the GTX 2867 comes in?
Is this a trick question?
Old 10-11-2013, 09:52 AM   #27
Lam3
Member#: 322979
2012 WRX hatch
Red
Nice job guys, this is awesome to see all in one place and will definitely make my own personal sticky list
Lam3 is offline   Reply With Quote
Old 10-17-2013, 03:13 PM   #28
Daggernomad55555
Member#: 343485
2008 TT VR6 GTX4202r
Sticky ?
Daggernomad55555 is offline   Reply With Quote
Old 10-18-2013, 09:24 PM   #29
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Awesome comparison, maybe include retail price?
Tyrial is offline   Reply With Quote
Old 10-21-2013, 03:36 PM   #30
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated the first posts. Added MHI and IHI info. Some of this may not be perfect, because it can be hard to find, but it is hopefully good enough to use as a point of reference when comparing to the larger offerings out there. I also added a column for whether or not the turbo is offered in a stock location Subaru mount.
Old 10-21-2013, 05:31 PM   #31
manitou
Member#: 193757
2006 XTI Limited
Good ideas!
As you all may know the EFR exducer dimensions are not published anywhere that I can find. I inquired with Full Race but they could not supply them. So I've added the calculated EFR exducer dimensions based on the known turbine inducer dimensions and known trim. I listed them with a comment and I added them to xluben's latest spread sheet. So that he could update those EFR exd. cells in the chart.
Borg Warner is keeping this turbine wheel info close to their chest, so to speak. They do say that the 55, 58, 64 and 70mm wheels are all of the same design but just different sizes. On those four wheels the listed trims are 88-89%. I rounded them off at 88.5% to average it. The 74mm wheel is 87% and the 80mm wheel is 92%. So I am qualifying these dimensions as close/ calculated but not exact!
Old 10-22-2013, 01:11 AM   #32
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Are you sure the Blouch Dom 5.0XT-R is a 84mm Compressor>
Blouch states its a 82 wheel
west_minist is offline   Reply With Quote
Old 10-22-2013, 06:52 AM   #33
manitou
Member#: 193757
2006 XTI Limited
I'm pretty sure on the Dom 5.0XT-R specs. I did not measure the wheels myself but I did get them straight from Mike Malin at Blouch. The turbine wheel is a Garrett GT35r and the compressor wheel is unique to Blouch.
Old 10-22-2013, 09:16 AM   #34
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Fantastic! Stuck to the top of the page
Scooby921 is offline   Reply With Quote
Old 10-22-2013, 10:31 AM   #35
manitou
Member#: 193757
2006 XTI Limited
Wow, That's a great spot for it!!
It was/ is Ben's baby and I am glad to have assisted in it!
Allan
Old 10-23-2013, 11:52 PM   #36
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
I have what I believe is a BW 8070 its larger than my 7670 with the same exhaust wheel I need to call Raffi at full race and see what we can come up with as a size before I post info on it though
seanathanq83 is offline   Reply With Quote
Old 10-24-2013, 12:22 AM   #37
manitou
Member#: 193757
2006 XTI Limited
That sounds like a nice turbo with those wheel pairings! I'd like to hear more about it!
Old 10-24-2013, 09:11 AM   #38
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Thanks guys for the work you put into this. It really helps when it comes time to chose a turbo to know what the specs are for the turbo you're looking at in comparison to the turbo you have. Great job and thanks again.
Drewswrx is offline   Reply With Quote
Old 10-24-2013, 07:01 PM   #39
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Awesome resource! Great work.
TheColorCute is offline   Reply With Quote
Old 10-24-2013, 08:19 PM   #40
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
+1234 great work! Curious of course where the HTA68 fits in...
Old 10-24-2013, 08:24 PM   #41
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks everyone.
I would assume the HTA68 is similar to the HTA71, but with a 68mm compressor exducer instead of 71mm. I don't know all the specs for sure though. Since it's not current it is not as easy to find. Maybe manitou would be able to figure it out.
Old 10-24-2013, 08:41 PM   #42
Dave D.
Member#: 130990
06 Red Ltd.Wagon
I found this in an old thread, the original hta68 thread:
...It is obvious this thing is not bigger than a 20g. A 20g inducer is 52.5mm, and the exducer is 68mm. As previously mentioned, the name (HTA68) probably indicates the exducer is the same. The inducer, however, is OBVIOUSLY smaller than 52.5mm, and looks to be smaller than an 18g inducer as well. That is why the HTA68 is "comparable to a 16g;" it is similarly sized, and that is probably why it spools so fast. When people say "they should make an HTA counterpart of the 20g," what they are saying is they should make something similarly sized to a 20g, aka with a ~52.5mm inducer. It would probably have similar spool characteristics as the 20g, but would flow more. It would not, however, be "bigger."
Also, it's supposed to be a 47lb/min turbo.
Old 10-24-2013, 09:18 PM   #43
manitou
Member#: 193757
2006 XTI Limited
Quite a few of my tuner friends have been kind of down on the HTA68's performance. I saw a few dyno graphs from them when they were getting some press and they did not impress. I think that it was an ok turbo on 92-93 pump gas and it woke up a bit more on E85. I don't know much about them but I think they worked well on the DSM's and Evo's but did not produce on our Subaru's. I guess that's why they revised it into the HTA71.
Why not just run an 18gxt or a 20gxt/ xtr?
What kind of power have you made with your HTA68 Dave D.?
Old 10-24-2013, 09:33 PM   #44
Dave D.
Member#: 130990
06 Red Ltd.Wagon
I've been luckier than most:
http://forums.nasioc.com/forums/show...=hta68+maxwell
Mostly just curiousity. I'd like to run a Dom 1.5, but I've had my hta68 for quite some time and it does pretty well for now. Just waiting for some extra cash.
Old 10-24-2013, 10:21 PM   #45
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Those seem like pretty optimistic dyno numbers for pump gas. That's more like what I'd expect from that turbo on E85. My brother is running the 68HTA on his Bugeye (hybrid motor, 6MT, etc). It's a pretty peppy car with good amount of torque. Once I get my Bugeye back up it will be an interesting comparison (I will be on some type of 20G variant).
As for the specs I think the only one that can answer that is FP. If anyone wants to get the info from them I would be happy to add it to the list. If I had to guess I would think it's a somewhat watered down 20G in hopes of increasing spool. Most I've seen make power somewhere between a VF and a normal 20G.
Old 10-25-2013, 01:39 AM   #46
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Well, you've seen my vid of 50-100 at 6 seconds flat, and that was with a large cargo box on top. I hand-timed a 5.4 run without the box one day, easy to do as it was all in the same gear. Puts it right close to your 20xgt run. But my motor has every possible non-ported breathing mod as well as cams on the exhaust. I'd love to dyno it on E-85, but since I daily drive it on pump it would really be more trouble that it's worth.
Even at a video'd 6.0 seconds, the numbers don't lie -- weren't you over 400whp with that setup that ran the 5.3? I'm under 400 on mine.
Old 10-25-2013, 08:44 AM   #47
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are my results:
http://forums.nasioc.com/forums/show...0#post38563100
20psi (400WHP Dynojet): 5.4 seconds
24psi (440WHP Dynojet): 4.9 seconds
27psi (480WHP Dynojet): 4.4 seconds
So the times you're reporting are within the ballpark. Mid to upper 5 second range should be around 400WHP. That's pretty good for that turbo I would think. I should have my brother give it a shot. Are you just doing a straight 4th gear pull with the short gears?
Old 10-25-2013, 01:10 PM   #48
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
good info to have will definetly make pivking a new turbo easier thanks
alexandern05 is offline   Reply With Quote
Old 10-25-2013, 04:47 PM   #49
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Yes, all in 4th. It's right in the powerband and shifting only slows me down. I video'd some with a 4-5 shift and the best I could do was 6.6. That cargo box really pulls me down with even a fraction of a second off throttle. Almost feels like I have the brakes on. I guess it is an "air brake."
Old 10-25-2013, 05:23 PM   #50
manitou
Member#: 193757
2006 XTI Limited
That's pretty good and short gearing to do the 50-100 pull in 4th. It's funny with my long ratio gearing and tall tires I do the 50-100 in 3rd gear. My third gear goes out to 110 at a bit over 8k.
You should take that box off and do a pull!
