Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-17-2013, 12:35 AM   #1
Octavios
Member#: 327580
2008 Impreza WRX Sti
Default Nexus 7 install - no head unit!
Ive had the itch to do this for awhile but finally bit the bullit!
Ill attempt to answer as many questions as i can but check out youtube for most of this!
I am skipping the head unit by feeding my Alpine PDX-V9 directly from the 3.5mm jack on the tablet (dock). Alpine has a bass knob for the amp for sub control and ive found a few good android apps to do most of my sound tuning. Alpine amps have the bare minimum when it comes to dials and settings. If needed JL Audio makes an line driver that should give me a bit clearer sound but we will see if its needed.
Parts:
Nexus 7 ($100 from a friend)
Official Nexus 7 dock ($34.95 from tigerdirect)
4 or 5 channel amp (PDX-V9)
Fiberglass and all its hardeners and what not (lowes/homedepot)
rare earth magnets (steal them from broken hard drives!)
First few shots of the dock mod, basically just cutting all the excess since they packed all the essential in a nice corner. THANKS!
here is the good stuff:
this way i can just drop the tablet in, without fiddling for cords or using bluetooth
The back of the tablet just snaps off so that made this part easy, used some left over trim adhesive to stick them on:
Should start the dash bezel here soon and update this post accordinly
any tips are greatly appreciated!
Octavios is offline   Reply With Quote
Old 04-17-2013, 12:46 AM   #2
konradlip
Member#: 324795
2004 WRX wagon
Looks good. Can't wait to see how it ends up. My tip-keep up the good work
konradlip is offline   Reply With Quote
Old 08-28-2013, 05:34 AM   #3
hozouria
Member#: 332388
2014 Whiteout FRS
2014 BMW 328d
Any updates on this?!
hozouria is offline   Reply With Quote
Old 09-02-2013, 02:42 AM   #4
ScoobyJD
Member#: 185910
2007 WRX TR
ScoobyJD is offline   Reply With Quote
Old 10-22-2013, 02:21 PM   #5
Octavios
Member#: 327580
Sorry guys! School crept up on me and work got busy so I have not had time to finish this project. Instead I started another though....
Added AirPlay to my car for better wireless music streaming:
Parts needed:
Apple AirPlay Express - Craigslist $40
USB Cable - Laying around the house
Voltage regulator or Potenometer
soldering gun, solder and a steady hand
Basically all your doing is replacing the power supply with the usb cable, the airport needs (in this version) 5 volts and 3.3 volts to run. USB from my aftermarket headunit is 5 volts so you need the pot to step it down to 3.3
---------------- USB is ONLY used for power - you can use and USB cigarette adapter for power too, you DO NOT need an aftermarket head unit just a usb power somewhere and a 3.5mm AUX input jack -------------------------
plug it into the computer first for inition setup and testing, break it open, pull the PSU out and look at the board to see where to tap your power into, put it back together tape it up and your good to go.
Also if you plan on using and iPhone for your source then you need to change a couple setting in the wifi menu so you can have local airplay and LTE/3G at the same time
The finished product it just a black taped up box, but if someone really wants to see it i can take a few pics lol
Any question on this one just send me a PM
And for comparison Bluetooh A2DP music streaming peaks around 80kps thus why it doesnt sound near as good as a cable. This one does 320kbps sounds as close to CD quality as music streaming can get right now for <$50
Old 10-26-2013, 12:43 PM   #6
DrSnazzy
Member#: 368848
Im also doing a nexus 7 install. Using a equalizer then to my amps! WIll post thread when finished
DrSnazzy is offline   Reply With Quote
Old 10-26-2013, 02:03 PM   #7
Octavios
Member#: 327580
Keep us/me updated!
Old 10-15-2014, 01:42 PM   #8
Octavios
Member#: 327580
Well this has been awhile! I switched from a nexus to an iPad mini, and am about a week from having the bezal finished. I will add pictures here tonight!!!!! Excited to finally get this done!
Switches cars since the original post, this will now go in my 08 Sti hatch
Old 10-15-2014, 10:39 PM   #9
Octavios
Member#: 327580
Old 10-20-2014, 11:02 PM   #10
grizirg
Member#: 387036
2015 wrx
dgm
nice work. i might end up stealing a screen off a tablet and using that with openelec. but then i would have to run amps which is all cost i am not looking for. keep it up.
grizirg is offline   Reply With Quote
Old 10-25-2014, 02:07 PM   #11
Octavios
Member#: 327580
Kenwood makes a good 4 channel amp for around $160 you could run straight from the tablet. And no power wire to run. Alpine also makes one but I thinks it's a bit more.
Sent from my iPhone using NASIOC
