Old 10-22-2013, 03:21 PM   #1
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
Default does this look like a good buy?
NJReppin is online now   Reply With Quote
Old 10-25-2013, 06:46 AM   #2
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
bump?
need some advice on this...
very clean car but high miles and can't tell if it is worth it or not...
Old 10-25-2013, 08:25 AM   #3
Notch 8
Member#: 355254
When was all the work done?
Head gaskets(if done correctly) shouldn't be a problem again...but with 200k miles, it's ready for another timing belt, water pump, etc, etc.
If you can get it for $3k, and you want it to be a reliable car, depending on how much work you can do yourself, figure another $1k-$2k in preventive maintenance immediately.
Tires?
I'm not a fan of any aftermarket HID setup either. They can be problematic at best, and burn your car to the ground at worst.
Accidents? Clean title?
Make sure to Carfax that baby.
Receipts are worth gold when dealing with any high mileage car. If he doesn't have any, assume NOTHING has been done.
Notch 8 is offline   Reply With Quote
Old 10-26-2013, 07:49 AM   #4
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
Thanks for the response man.
I think I will be leaving that one...
I need something a little cheaper...
that is a beautiful car though IMO... hard to pass it up...
Old 10-27-2013, 12:36 PM   #5
96outback
Member#: 241659
1992 lagacy wagon
white
Good call on not going with this, unless they have ample receipts and proof that all the work that was done is done.
96outback is offline   Reply With Quote
