View Poll Results: Any difference?
Improved fuel economy 4 26.67%
Smoother operation / reduced noise 6 40.00%
Reduced oil consumption 0 0%
No difference 5 33.33%
Will continue treating fuel 5 33.33%
Will not continue treating fuel 5 33.33%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Old 10-28-2013, 03:01 PM   #176
Angelus911
Member#: 89967
2012 Impreza Sport
I'm interested to see if this helps with oil consumption at all - I have mild consumption, about 1/2 - 3/4 qt per 5000 miles, but just did an oil change on Saturday, so this will be the first full oil change with TC-W3 as well
Old 10-28-2013, 03:11 PM   #177
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Scientific, closed testing is impossible in the real world. Temp/pressure/alititude/air density/wind/humidity/driver/traffic conditions/etc etc. Are always changing and for the most part uncontrollable. All we can do is take averages over multiple tanks and compare.
I suppose we could start taking logs if obd2 data, and I might on 2 of my cars, but there is a lot of work there sifting through it.
Recently all my averages have tanked and I suspect winter blend is back, historically all my vehicles take a 7-10% on winter blend which is where they are all sitting now, but using tcq3 seemed to have reduced the negative effects of ethanol on 3 of my vehicles, plus small engines.
Old 10-28-2013, 03:54 PM   #178
eliminster
Member#: 371089
Originally Posted by Commander Keen View Post
It's actually 0.7%, but I haven't made any decision. I've only posted a tank of E0 and E10. Since both were treated with TC-W3 there's nothing to compare yet. This is something that affects entire tanks, and over a tank, many different things can affect mileage. Flyboy has posted plenty of data, including blind testing on his wife's car. If you want to join in and conduct your own experiment, feel free.
Sorry but have already been running different fuels for several years in my wrx and truthfully it comes down to if the gas station gets a more RON sided rating or MON sided rating cause the number octane you see at the pump is an average of the two or did you not look at the R+M/2 on their. Also as to the benefits of lubrication of tcw3 is well known in the other community I deal with since most of us premix on a ratio of 1oz to 1 gallon in our rotaries. I just got tired of people randomly posting my fuel changed by blank and it was this when it could have been temp differences, humidity, fuel quality from the pump, or a million others. And being at least as much as possible scientific in this it will alleviate some of these variables, just trying to help since there is some good info but also a lot of pages of assumptions.
eliminster is offline   Reply With Quote
Old 10-28-2013, 04:50 PM   #179
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I haven't claimed a numeric improvement. All I've posted are raw tank numbers.
(R+M)/2 means R and M are represented in equal parts. What do you mean by MON sided rating?
Assuming the fuel is at least 87 octane, BTU content is going to have a greater impact on fuel economy than octane.
Because there are all these factors adding noise to our results, collecting useful information is going to take months. I'm not going to list every traffic jam and thunderstorm I drive through.
You're welcome to try this on your car and post the data in any form you see fit.
Old 10-28-2013, 06:58 PM   #180
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
So I started experimenting with TC-W3. I added 3 ounces to my tank when I filled up today.
Just a couple of quick questions. Are most of you following the reccomended 1oz per 5 gallons, or are you using more? Also, is it necessary to add the tc-w3 at every fill up to get the maximum benefits?
Old 10-28-2013, 09:05 PM   #181
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
on my buick and our jetta, the negative effects are seen at the next fuel up (so essentially yes add at every fill)
I have been using 1oz per 4 gals because it is easier to just round up rather than say 2.4oz with a 12gal fill
Old 11-05-2013, 04:37 PM   #182
jr0bb5
Member#: 315353
5MT OBP/DGM
So I'm on my third tank with TC-W3 and I really haven't noticed any difference in mpg, or anything else for that matter. I'm wondering if my first tank using it also happened to be the first tank of winter blend gas that went into my car this season.
I'll keep using the tc-w3 until my quart is empty. Once its gone, I should be able to tell if it was making a difference or not.
Old 11-05-2013, 06:45 PM   #183
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
The impreza seems to handle fuel variations better than everything wise I own that burns unleaded. My Buick gets driven a little more weekly than my impreza, abd there is a significant differ between using/not using tcw3. The jetta as well, I would say on average it is looking like about 7%. The impreza, maybe 1-2%. Need more testing, but now on winter gas, dropping temps, etc it will be hard to get consistent conditions for testing. I think due to chewing properties I will keep using it however.
Old 11-21-2013, 11:14 AM   #184
Commander Keen
Member#: 319157
10/11/2013 87E0 40.2 MPG
10/23/2013 87E10 39.9 MPG
11/21/2013 87E0 38.7 MPG
I excluded a tank before the last one because the driving varied too much. Cold weather is starting to have an effect.
Old 11-21-2013, 01:59 PM   #185
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Cold weather + winter blend is killing me. I'm down about 15%, even running 91e0 I can't get the same mpg as e10 summer gas, then I'm down about 10%. Going back to e10 next tank
Old 11-21-2013, 09:16 PM   #186
jr0bb5
Member#: 315353
5MT OBP/DGM
I hear ya man! My last two tanks have dropped about an average of 3 mpg per tank! Was hovering close to 29 mpg per tank, now all of a sudden I'm lucky to get 26.
Old 11-21-2013, 10:11 PM   #187
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yup, only i was just over 30mpg, and my last fill was something like 23 all highway (with speeding and lots of wind)
Old 11-27-2013, 11:01 AM   #188
Commander Keen
Member#: 319157
11/27/2013 87E0 36.6 MPG
Sliding further...
Old 11-27-2013, 11:13 AM   #189
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Sliding further...
i've given up on any further testing until spring, I'm still using TCw3, but other than fuelly not tracking it as this year looks like a much sharper drop off due to switching to mandatory e10 and winter blend at same time
Old 11-27-2013, 12:37 PM   #190
Commander Keen
Member#: 319157
Right. Between this weather and mystery fuel, the numbers are just too unstable.
Old 11-28-2013, 05:11 PM   #191
jr0bb5
Member#: 315353
5MT OBP/DGM
I'm also going to stop using the TC-W3 after my quart is gone. If I notice a big drop in MPGs after stopping, I may start using it again. It's too difficult to tell if it was making a difference or not with the colder weather and winter blend fuel.
Old 11-28-2013, 05:17 PM   #192
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm going to keep using it because the extra lubrication is beneficial, just not worried about mpg differences right now, when everything stabilizes again in 6 months I will.
I know for a fact my Buick idles smoother and injectors are night and day quieter.
Old 12-24-2013, 01:45 AM   #193
ans2k
Member#: 315631
2012 Impreza Sport
So it has been 10,000 miles on this experiment. It was almost impossible to determine if gas milage has increased due to the season changing. I have been using the same gas station the majority of the time and only 87e10. Oddy, before starting the experiment 10,000 miles ago, oil consumption was less than one quart per 7,500 miles. Oil consumption is currently 1 quart every 5,000 miles. The only noticeable change has been the smoother running engine.
Old 01-03-2014, 09:13 PM   #194
jr0bb5
Member#: 315353
5MT OBP/DGM
I'm officially done with my tcw3 experiment. I finished the quart at my last fill-up. Unfortunately, I have not noticed a lick of improvement in any area so I do not plan to continue using it.
I know some of you will argue that it still helps to lubricate the fuel system even if there's no noticeable difference, but to me, it's not worth the messy hassle of measuring out the perfect amount every fill-up. I'll probably just use a fuel system treatment like seafoam every once in a while.
Old 05-02-2016, 01:12 AM   #195
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
Is anyone still using TC-W3 fuel treatment? Wondering if anyone has used it all this time and still vouch for it?
Old 05-02-2016, 07:59 AM   #196
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No im not, just use a little of what i have left in my small engines, lawn mower etc. Helps smooth them out.
Old 05-03-2016, 09:41 AM   #197
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Have noticed it helps smooth out my 20yro 4stroke mower and often run it through my '99 VFR motorcycle to good effect, doesn't seem to caused any harm to either for the last 3 yrs.
John451 is offline   Reply With Quote
Old 05-04-2016, 02:24 PM   #198
CLL_OBP
Member#: 310435
'12 Sp Limited
M1 EP 0W20 104,640 miles
Originally Posted by CLL_OBP, 09-15-2013 01:28 PM View Post
I look forward to seeing what any experimenters have to say. I debated added TC-W3 or MMO to the fuel back in February and went with MMO. They both appear to be good for the benfits listed above but I felt the designed purpose of MMO made it safer to use. Seven months later, I still add 3oz every half tank.
Still at it for over three years now. I've since gone to 2oz MMO and 1oz TC-W3 for 8 gallons. Been using the Pennzoil Marine XLF Syn blend.
I continue mainly because it lubricates the fuel system parts and counteracts the effects of ethanol.
CLL_OBP is offline   Reply With Quote
Old 05-04-2016, 07:51 PM   #199
Commander Keen
Member#: 319157
I'm still using it. Due to a new commute, I'm filling with mostly 87E10+TCW3 now.
My small engines still get 87E0+TCW3. Mower started on the first pull this spring with a tank from last fall.
Old 05-04-2016, 09:36 PM   #200
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yup, still running my 1994 Toro I inherited from my father. original engine and still starts on 1 pull it loves no ethanol and TCW3
maybe I will try it again in the car. doesn't really hurt anything
