Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 10-30-2013, 12:33 PM   #1
Justajester
Member#: 372327
Default 1982 Brat Oil in Aircleaner from breather?
Hey guy and gals, I am new to the club so I should say my name is Tom and I just purchased my 1982 Brat GL 3 weeks ago, running and in sort of decent shape for $900(not bad). Anyways, the car has the 31 year old blues right now with a myriad of rubber and plastic parts messed up, and general wear and tear items going out.
I'm working out most of those problems but, currently I'm rebuilding the carburetor(which is not in good shape) and got to wondering about the oil in the air cleaner. It's clearly motor oil and since there is a lot of oil in the passenger side valve cover breather hose and the inlet on the air cleaner I know it' coming from there. now I've read in some forums about other cars(Chevy big blocks mostly) that this can be cause by worn rings, vacuum problems, bad pcv valve, various other things. I'm curious to know what exactly can cause it in the brat and if I'm missing any parts that should be there.
I know the PCV valve in the engine is bad but, it's not connected to that hose in anyway. There is no filter or valve in that hose of any sort(should there be?). Other than that the engine does have quite a few vacuum leaks, missing vacuum and emissions hoses, is in bad need of a tune up, has bad ignition coil, etc...All of this seems to be causing missing, occasional backfire, and stalling. Could any of that be causing the oil to come through the breather? Anything else I should look at?
Thanks in advance for any answers!
-Tom
Justajester is offline   Reply With Quote
Old 10-30-2013, 12:38 PM   #2
Justajester
Member#: 372327
Sorry just rereading my post...to clarify a hair I meant the PCV valve isn't connected to that particular breather hose, it's connected to the breather on the driver side only.
Old 10-30-2013, 12:45 PM   #3
rexspeedworthy
Member#: 26965
2013 XV crosstrek
Ultimatesubaru.org
They are there for all your old skool needs.
Pics of Brat please.
rexspeedworthy is offline   Reply With Quote
Old 10-30-2013, 05:07 PM   #4
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
just a quick question but are the head gaskets blown?
Kevint143 is offline   Reply With Quote
Old 11-07-2013, 02:22 AM   #5
TurboneX
Member#: 21676
RX 02Foz,05OB
If the HG's were bad there would be frothy/milky oil in the breather.
Blow-by is common with the EA81's, a little bit of oil in the air box wont hurt anything.
TurboneX is offline   Reply With Quote
